AMX PLB-AS8, PLB-VS8, PLB-AMP8 Problem
I have PLB-AS8, PLB-VS8 and PLB-AMP8 connected to NI-3000 via PHASTLink Hub. The system works for a long time e.g. 3 months without rebooting, listed devices are visible in NetLinx Studio device list and then all they simultaneously get lost until i reboot the Master Copntroller
Is that PhastLink hub problem? How to fix it?
Thanks a lot!
  • GSLogicGSLogic Posts: 562
    Check to make sure they all have the same version firmware.
  • vincenvincen Posts: 526
    You can also check you get terminator on ICSNet links where your Phast devices are connected ;) it really helps sometimes for stability :D
    Vince
