Home AMXForums Archive Threads AMX Hardware MAX by AMX
Max-mms & Max-avm
I have MAX-MMS 125 and three AVMs. The problem is that sometimes one AVM's sound isn't good (it's crackin') while playin' MP3 or DVD. The vendor said that i have to update server's firmware, but i hasn't find any firmware kit for MAX-MMS on amx.com.
May be u know how to fix the problem or where to get firmware updates?
Thanks a lot!
    Call AMX, and they will instruct you to connect the MAX to them via the admin menu. They update it remotely. Depending how old your server is, it could be 15 minutes to an hour or so. I believe the most recent version updates itself, so you may only have to do this once. But you aren't going to find MAX updates you can install yourself. They use a different paradigm than other AMX devices. Remember, MAX was developed independently from AMX, and was an acquisition. At the core, this is a different manufacturer's product with an AMX label on it.
