PDP-4270 Volume?
jjamesjjames Posts: 2,908
This is our first time having to control the volume on a Pioneer plasma. I know the protocol like the back of my hand and know how the device works. I for some reason cannot get volume control of the thing. I've tried several different strings, and it still doesn't work. Any tips or pointers would be extremely greatful. I really don't want to have to revert to IR control ONLY for volume.
Here's what I'm using:
SEND_STRING dvPDP,"$02,'**VOL050',$03"
I recieve back "$02,'**XXX',$03" from the Plasma. Now, I know that if I send a power on command while it's on or send it the same input twice, I recieve that same string from the Pioneer.
Anyway, I'm a little confused here. Any help would be appreciated.
    I had this before - some of the volume commands just will not function as expected... I will look up what happened / how we got round it and come back... Do recall it being very odd and very frustrating!!
    Had a look - the commands we had issues with was the VOLUPn and VOLDWn
    I've just tried with a system here and "$02,$30,$31,'VOL050',$03" returns
    Line 28 :: String From [5001:5:1]-[$02VOL050$03] - 18:55:34
    first time and
    Line 29 :: String From [5001:5:1]-[$02XXX$03] - 18:56:08
    every subsequent time
    Not sure if that helps... the VOLUPn and VOLDWn just would not work with a 42"
    Excellent! So if the absolutely volume strings work, I can just keep track of it in a variable. How did you come up with / find the $30,$31 portion of the string? Is that in place of the '**' prior to the command?
  • Re: Pioneer PDP volume
    Just tested the 5070 that I have here in our showroom.
    The single step volume up and down work correctly with the following commands:
    "$02,'**VOLUP1',$03"
    "$02,'**VOLDW1',$03"
    Sending these I get single stepping of the volume bar on the TV.
    I did not test the 10 step, or the max/min commands.
    Brad
    I thought I tried those on the 4270 without any luck. Do you have a serial protocol document for the xx70 series? My most recent one is the xx50 series.
    The '**' is a global ID / wildcard and $30,$31 ('01') is just a specific ID... Just habit as the PDP won't send back valid data on request if the ID is not used.
    Yeah, the Up / Down worked fine on the 50"s just not on the 42"s...
    Thanks guys! I'll post results as soon as we try this. Hopefully that'll be sometime today. Thanks again! :D
