iPort Module
wcravenel
Recommend not using this. Use regular NetLinx module instead. I think Jon Parker has a copy.
Slow, outdated, web still shows Duet version as recommended, did not work well for me.
Bill
Bill
I've used Jon Parker's version on several projects and I consider it to be one of the best AMX created modules yet. (IMHO)
This iPort has got to be one of the best products made thus far. Our clients rave about it, and it's becoming almost a standard piece in our bid list. Let's face it, if someone is getting an AMX system, chances are they can afford or already have an iPod. One client even said to us, "what's the point of having a music server?" in reference to having an Escient. I quickly used that opportunity to give a schpiel about Request's ability to integrate / syncronize with an iPod, and he said, "but still, what's the point? I can have all my music with me no matter where I go." I wish I would have thought of it, but the point is sound quailty.
Anyway . . . big post for a simple question: how's Sonance's module?
We are currently using this netlinx module downloaded from the iPort website with the R4 remotes. We have found the module to be quite slow with the R4s due to the zigbee standard. I was just wondering if anyone had found a way in the UI module to slow the rate at which data such as artist and track names etc are sent to the panel as only the first 7 or so appear. Usually when this happens the iPort module then disconnects and becomes unuseable.
Any thoughts on the subject would be very welcome.
Joe
If I understand correctly, I would use a virtual device as a proxy and queue the commands then send them from the queue to the R4.
So in otherwords, replace the R4 device in your code with a virtual. Then use the data_event of the virtual and add the commands to a queue, and pace the commands to the R4.
That is interesting that you bring that up, that might explain problems that I have had with the NetLinx module.
Nick P
It's been a while since I played with iPod control - never (and won't) use AMX's module or iPort's module, but never had a problem with the iPod going to sleep and ceasing to respond.
Or is this something particular with say the nano?
You know, maybe I'm just looking for a reason, but I have had random problems with the NetLinx module from AMX. Unfortunately I don't have the time or money to write my own module to support the iPort.
http://www.iportmusic.com/moduleaccess.html
I'll have to try that, I've haven't even though of trying their version.
I changed the cable and now I have answer of iPort ... but not working yet
Any ideas? Please Help!
