Include Files Breaking Debugger
Can no longer DEBUG?.after using .axi files
I?m using 2 include files in a program for plasma control. But doing so seems to prevent me from stepping through code and debugging.
I?ve tried to include the files in different locations DEFINE_DEVICE, DEFINE_START with no luck.
Is there a work around for this, or is it something in my code?
If any of you smart programmers types know the secret or have any tips or trick feel free to share!
1) Replace each #include some_file.axi; line with the entire contents of that axi.
2) Debug.
3) Make changes.
4) Repeat steps 2-3 as often as desired.
5) Put the #includes back in. Test once more for posterity.
It's not a permanent fix but I can get by with it.
Thanks!
I've had the same experience. I've just kinda came up with different ways to debug a program, myself. I'll load values into dummy variables to watch the process or send a bunch of messages to the master via port 0. After I've determined what's going on, I'll delete out all the diagnostic stuff, recompile and call it good.
