Include Files Breaking Debugger
Can no longer DEBUG?.after using .axi files
I?m using 2 include files in a program for plasma control. But doing so seems to prevent me from stepping through code and debugging.
I?ve tried to include the files in different locations DEFINE_DEVICE, DEFINE_START with no luck.
Is there a work around for this, or is it something in my code?
    I find debug w/ break points hit or miss. Some times they work great inside modules and includes and some times I can't get them to work in the main.axs. I remember in Pro-II the instructor had a hard time with it so I don't know what the secret is. I can go an entire day w/o getting a break point to work and the next day it's fine.
    If any of you smart programmers types know the secret or have any tips or trick feel free to share!
  • mpullinmpullin Posts: 949
    suggestion for debugging w/ includes
    1) Replace each #include some_file.axi; line with the entire contents of that axi.
    2) Debug.
    3) Make changes.
    4) Repeat steps 2-3 as often as desired.
    5) Put the #includes back in. Test once more for posterity.
  • dthorsondthorson Posts: 103
    Well that did the trick. Thanks for the work around, it's exactly what I was looking for.
    It's not a permanent fix but I can get by with it.
    Thanks!
    I've had the same experience. I've just kinda came up with different ways to debug a program, myself. I'll load values into dummy variables to watch the process or send a bunch of messages to the master via port 0. After I've determined what's going on, I'll delete out all the diagnostic stuff, recompile and call it good.
