MIO Pinnacle "On" state for item in listbox?
fogled@mizzou
I have a static listbox table defined in a MIO Pinnacle project:
It's port address and display address are both defined as 6. I can display and scroll through the list just fine on a MicPresets page. I get the right button_events from the channel and switching the preset works, but... how do I actually highlight the selected entry in the list on the touchpanel?
on[dvMIO_TP,221] does not work.
^LVP-6,1 will make sure the selection is visible, but that doesn't equate to a highlight - i.e. white on black instead of black on white.
In fact, I can't even find a place where I can specify different states for ON vs. OFF for lists or list entries.
This is the first time I've used a list like this where I need to get channel feedback - i.e. ON/OFF state - for an item in the list (I use lists all the time for single-line volume level displays that don't need on/off feedback). I must be missing something simple... can someone point out what it is?
Entry Port Channel -------------- ---- ------- Sure RS25 1 221 Audio Technica 1 222 MiPro LAV 1 223 ... Custom 1 229 RESET 1 230
