I haven't tried their own code, but have worked extensively with Kscapes in the past. An excellent piece of hardware. I got the Credits meta data working in our show room the other day, basically Kscape can cue you on were in the movie it is, so say at the end credits you can raise the lights, tre cool I might add!
I have used the code on three installations and love it. The thing to note is that if you are using the same touchpanel as stand alone touchpanel for music and on screen control for movies, you will have to specify two touchpanels in the module and code. If you are always using on screen video then this is not an issue.
