Home Duet/Cafe Duet
NXI - 'GET' Send Commands
I'm seeing some problems getting string responses from NXI ports in Duet.
If I define "dummy" event handlers in NetLinx, the Duet code will receive string events from NXI ports. I am aware that once Duet claims a NetLinx device, the NetLinx code no longer has affect.
If I don't define "dummy" event handlers in NetLinx, the Duet code will never receive a string event from NXI port.
Send Commands that return a string with an Axlink touch panel work fine. No "dummy" event handler required in NetLinx.
	private NetLinxDevice dvIR = null;
        // bundle constructor
	dvIR = new NetLinxDevice(new DPS("5001:8:0"),false);   // not a virtual port...
	dvIR.initialize();
        protected void doAddNetLinxDeviceListeners() {
                if(dvIR != null) {
 		        dvIR.addDataListener(new DataHandler());
        // else where in code send command is called
	dvIR.sendCommand("GET MODE");
	public class DataHandler implements IDataListener {
		public void handleDataEvent(Event evt) {
			switch(evt.type) {
			case Event.E_STRING: {
				String msg = new String((byte[]) evt.dataValue);
				System.out.println("E_STRING [" + msg + "]");
				break;
How can I make this work without the dummy NetLinx events?
  • joelwjoelw Posts: 175
    I forgot to mention my software versions.
    NetLinx Studio v2.5 Build 2.5.0.163
    Cafe Version 1.8.85 Build Number: 85
    Platform Version 1.9.194 Build Number: 194
    Runtime Version 1.9.194 Build Number: 194
    NXI v1.00.22
    NXC-ME260/64 v3.21.354
    My exchange with engineering didn't resolve this. I'm sending a test case to reproduce this. Perhaps they will find an error in my code.
