Keyboard in UI modules
adys
in MAX by AMX
As mention here http://www.amxforums.com/showthread.php?t=2537
the string that are coming from the panel is coming only on port 1 system 1.
I change the code to support my TP ports (40) and system 0, but I get nothing from the panel - the keyboard is not working...
Any limit for the port?
Any tip how to solve that?
thanks
Ady.
thanks
Ady.
If you have other pages in your system you will want to do a find/replace to change all channels/ports to a different number like 2 before adding the MAX pages in.
I have 10 systems with the appropriate ports.
Everything is working like magic, only the keyboard strings are making me problems.
I don't mind working with port 1 only for the keyboard if I must.
Dave wrote here about the hard coded, I found it and changed it but I still have problems
But does keyboard strings must be on port 1? (not only for MAX)
update:
I moved back all keyboard buttons to port 1
I change code to support system 0 instead of system 1
Everything is working, thanks!
Ady.
Not true - I have a large system with a lot of panels, all running on port 13. String outputs from a panel always come in on port one, but that is a panel issue, and the MAX UI module allows for this. It's the system number in the module that was mistakenly hard coded ... you have no choice about using port 1 for the strings.
Dave, can you please tell what is the exactly code that you are runing to solve the offline zone issue?
I have lot of troubles with that offline online issue...
Ady.
