data events for module devices
When if I define a touch panel(1000:2:0) combine it with a virtual device(32001:1:0)in a main code file.when the touch panel receives a event the data,string event fires.
but when I pass the touch panel to a module and define the data event in the module and not in the main program the event never fires. any ides?
    I don't believe the association passes through to the module. There are other ways of linking devices together that might work better.
    For example creating a DEV
    example:
    10001:01:0  =  TP_1
    10002:01:0  = TP_2
    33001:01:0  =  vTP_1
    DEV dev_TP=[]
    TP_1,
    TP_2,
    vTP_1
    BUTTON_EVENT[dev_TP,1]
      SEND_COMMAND dev_TP, 'ADBEEP'
    This little routine will send a double beep command to all the touch panels if any of the panel's button 1 is pushed.
    The advantage of this is that you can easily address multiple devices with one reference. However, the devices are still unconnected and can still send and receive separate commands.
    another example
      TP_DEVICE=Button.Input.Device.Number
      SEND_COMMAND TP_DEVICE:01:0, 'ADBEEP'
      SEND_COMMAND dev_TP, 'TEXT1-Somebody pushed button 1'
    This will send a double beep command to only the device that the button was pushed but will send a text message for all the TPs button number 1
    there are other things to look at as well such as DEVCHAN and DEVLEV.
    give those a look in the help file ans see if it helps you out.
  • samossamos Posts: 106
    This does not help really. I need to pass a device as a module parameter. Then in the module write a data event for device. The data events string event only seems active when in the main source
    example that works
    PROGRAM_NAME='STANDERD_SRC'
    dvTP = 10001:2:0
    vdvTP = 32001:2:0
    define_combine(vdvTP,dvTP)
    DATA_EVENT[vdvTP]
    string:
    if(1) send_string 0, 'data.text
    example that does not work
    dvTP = 10001:2:0
    vdvTP = 32001:2:0
    DEFINE_MODULE 'Login' mdlLogin(vdvTP)
    MODULE_NAME='Login'(dev vdvTP)
    DATA_EVENT[vdvTP]
    string:
    i have a touch panel has four buttons with there string output port on each set as 2
    then there string out is set to 1,2,3,4.
    now in netlinx diagnostics i see a event for 10001:2:0 and 32001:2:0
    like this
    Line 72 :: String From [10001:2:1]-[1] - 11:24:57
    Line 72 :: String From [32001:2:1]-[1] - 11:24:57
    when the data event is not in the module and in the main_src the data.text is displayed in telnet, and when the data event is in the module the data is not displayed in telnet.
  • Works fine for me
    Mainline:
    dvTP = 10001:1:0
    vdvTP = 32001:1:0
    DEFINE_MODULE 'mSandpit' mdlLogin(vdvTP)
    Module:
    MODULE_NAME='mSandpit'(dev vdvTp)
    define_event
    DATA_EVENT[vdvTP]
    string:
      send_string 0, data.text
    BTW I used a G3 browser panel not a real one
    example that works
    dvTP = 10001:2:0
    vdvTP = 32001:2:0
    DATA_EVENT[vdvTP]
    string:
    dvTP = 10001:2:0
    vdvTP = 32001:2:0
    DATA_EVENT[vdvTP]
    string:
    like this
    A virtual device by default only has 1 port (and only 255 channels, and 8 levels). To have more ports, you have to set them by SET_VIRTUAL_PORT_COUNT(vdvTP,2) for 2 ports, either in the ONLINE handler of the virtual device, or in DEFINE_START (a virtual device is online at DEFINE_START)
    Next issue may be that panel internal strings will sent back on port 1 only. So i.e. a keypad string AKEYP-123 from the panel's internal keypads always is sent on port 1.
