Random Number Generator
I need to somehow come up with a random number generator for a non-malicious purpose. What I'm trying to do is have my program cause an Alcorn McBride 8-Traxx player to play tracks at random based on other input events. Basically, a button push would trigger a play command, but I want to randomly pick what track is to be played. It's not possible to randomly play the tracks on the 8-Traxx box itself...all I can do is send serial strings to tell it what track numbers to play. My only other alternative would be to just call the files in a seemingly random order and hope nobody notices the pattern, which is highly likely as these sound files are quite short and there are not that many of them, and I want it to be truly random anyway.
This from the help file.
Num = RANDOM_NUMBER(1000) // 0 <= Num < 1000
Then use any of the stock sorts to create a random/unique list of numbers and go from there.
Hope that helps
If you want to play all the tracks in your list randomly and not have any tracks repeat until all tracks are played once then you might find the following code useful.
Compile, download, and then watch nShuffledPlaylist in the debugger. Every time you push button 1 you?ll see the playlist get shuffled.
I?m sure there are different and better ways to shuffle but this is the approach I?ve used in the past.
DEFINE_DEVICE dvTP = 10001:1:0 DEFINE_CONSTANT INTEGER nMaxTracks = 10 DEFINE_VARIABLE INTEGER nOriginalPlaylist[] = {1,2,3,4,5,6,7,8,9,10} INTEGER nShuffledPlaylist[] = {1,2,3,4,5,6,7,8,9,10} INTEGER nNextTrack //the next track to be played DEFINE_FUNCTION fnShuffleThis (integer nItems[]) { INTEGER x //looping variable INTEGER shufflecount //how many times to shuffle entire list INTEGER index //current position in the list INTEGER rnd //random position in the list INTEGER temp //temporary container so swap can be made INTEGER len //length of list passed in len = LENGTH_ARRAY(nItems) //find out how long the list is shufflecount = RANDOM_NUMBER(11)+10 //get a random number between 10-20 FOR (x=1; x<=shufflecount; x++) { //shuffle the entire list shufflecount times FOR (index=1; index<=len; index++) { //index through the list from start to end rnd = RANDOM_NUMBER(len)+1 //generate a random number between 1 and the number of items in list temp = nItems[index] //make a copy of the data that is stored at the indexed position //let's make the swap nItems[index] = nItems[rnd] //replace the indexed position item with the random positioned item nItems[rnd] = temp //take the indexed positioned item and store it in the random position } } } DEFINE_FUNCTION fnPlayNextTrack() { //Do whatever to play track nShuffledPlaylist[nNextTrack] nNextTrack++ IF (nNextTrack>nMaxTracks) fnResetPlaylist() } DEFINE_FUNCTION fnResetPlaylist () { nNextTrack = 1 //don't really need this next line, it's only for demo purposes //but if you wanted to change the set of tracks to play you could do it here nShuffledPlaylist = nOriginalPlaylist fnShuffleThis(nShuffledPlaylist) } DEFINE_EVENT BUTTON_EVENT[dvTP,1] { PUSH: { fnResetPlaylist() } }HTH
Thanks guys...these did the trick.
