Home Duet/Cafe Duet
SNMP Duet Example
Here's a sample Duet SNMP module.
To use module
build new program using .axs file in zip file, then upload to Duet enabled processor
Telnet into processor
type: msg on
type: send c vdvSNMP,'192.168.1.1'
(change to IP address of a device that supports SNMP v1)
http://www.indyelectronics.com/AMX.Duet.SNMP.Example.zip
Output looks like this when querying an AMX ME260/64M with v3_21_354 firmware.
send c vdvSNMP,'192.168.1.5'
>(0000807692) Retrieving value corresponding to OID 1.3.6.1.2.1.1.4.0
(0000807732) Retrieved: system.sysContact.0 = AMX Corporation
(0000807735) Retrieving value corresponding to OID 1.3.6.1.2.1.1.1.0
(0000807777) Retrieved: system.sysDescr.0 = NetLinx VxWorks SNMPv1/v2c Agent
(0000807779) Retrieving value corresponding to OID 1.3.6.1.2.1.1.6.0
(0000807822) Retrieved: system.sysLocation.0 = Richardson,TX USA
(0000807824) Retrieving value corresponding to OID 1.3.6.1.2.1.1.5.0
(0000807865) Retrieved: system.sysName.0 = Netlinx
(0000807868) Retrieving value corresponding to OID 1.3.6.1.2.1.1.7.0
(0000807910) Retrieved: system.sysServices.0 = 79
(0000807913) Retrieving value corresponding to OID 1.3.6.1.2.1.1.3.0
(0000807954) Retrieved: system.sysUpTime.0 = 81207
Cobranet Audio control is SNMPv1 based.
VBrick encoders/decoders are controlled via SNMPv1.
If you have a project that could benefit from SNMP control, on-board database, etc, please contact us. We can help.
Joel Winarske
Independent Electronics, Inc.
707-320-4271 Office
  • joelwjoelw Posts: 175
    Peavey CAB 16i/o experiments, etc
    I ran some test with Peavey CAB16i/o boxes.
    It doesn't look good. You assign an IP address to them via CobraNet Discovery. This enables you to query and twiddle to your hearts content via SNMP. The trouble is the IP address is not stored on reboot. So next boot you're back to 0.0.0.0.
    Two options:
    1. Leave CobraNet Discovery running all the time on some PC in the system
    2. Develop a third party box that mimics CobraNet Discovery IP address setting. Quite feasible.
    Grass Valley M Series boxes have nice SNMP coverage. So you can query unit for remaining disc space!
    VBrick control via this SNMP stack is also be possible!
  • dchristodchristo Posts: 177
    There is a variable on the CobraNet card for persistence of read/write variables. It's the flashPersistEnable variable at 1.3.6.1.4.1.2680.1.1.2.7. Any non-zero value will enable persistence.
    --D
    Excellent! I will test that out.
    Thanks!
    It tried this on my Attero Tech CobraNetTM CO2 boards. Cobranet.mib lists flashPersistEnable, but the CS496112 part does not support it. I will test CABs when I'm back on site later this week.
    Example Update
    I updated the example to be a bit more useful. Same download, file has been updated.
    Usage output (send c vdvSNMP,'?' via Telnet with 'msg on' enabled)
    send c vdvSNMP,'walk host [community]'
    send c vdvSNMP,'stop'
    send c vdvSNMP,'getData host [community] oid'
    send c vdvSNMP,'getNext host [community] oid,oid,oid,oid'
    send c vdvSNMP,'getTable host [community] oid'
    send c vdvSNMP,'setData host [community] oid valueType value'
    Example Uses
    Get system information as provided by previous version
    send c vdvSNMP,'getNext 192.168.1.1 1.3.6.1.2.1.1.1,1.3.6.1.2.1.1.2,1.3.6.1.2.1.1.3,1.3.6.1.2.1.1.4,1.3.6.1.2.1.1.5,1.3.6.1.2.1.1.6,1.3.6.1.2.1.1.7'
    Get ifTable
    send c vdvSNMP,'gettable 192.168.1.5 1.3.6.1.2.1.2.2'
    Get MAC address
    send c vdvSNMP,'getData 192.168.1.5 1.3.6.1.2.1.2.2.1.6.2'
    Get sysName
    send c vdvSNMP,'getData 192.168.1.5 1.3.6.1.2.1.1.5.0'
    Set sysName
    send c vdvSNMP,'setData 192.168.1.5 1.3.6.1.2.1.1.5.0 SNMPOctetString me260_64M'
    By default if the community value is omitted, it defaults to 'public' for get, and 'private' for set.
    Valid valueTypes
    SNMPCounter32
    SNMPCounter64
    SNMPGauge32
    SNMPInteger
    SNMPOctetString
    SNMPUInteger32
    This code works with any SNMPv1 device.
    Refer to a MIB browser to retrieve other OIDs. I like MG-SOFT MIB Browser Pro.
    http://www.mg-soft.com/mgMibBrowserPE.html
    Know limitations:
    1. Initial send command response takes a while, subsequent commands are fast. Perhaps send a dummy sequence to prime the bundle, prior to using.
    2. Current version I am only handling the setData value passed as a string. Sometime this week, maybe next I will address this.
    3. Data is not returned to virtual device. Will add this based on user feedback. A step at a time man.
  • pauldpauld Posts: 106
    Wow, thats a great tool. Where did you find the information on SNMP? I have a device that will accept control via SNMP but I would like to control it from a touchpanel. Your Posted Module does communicate with the device but i would like feedback as well. Do you know where i can find more informaion about SNMP? Or some examples of the Get/Set strings would be great.
    Pauld
  • Jorde_VJorde_V Posts: 393
    pauld wrote: »
    Pauld
    Bumping this out of curiosity, as I'm interested in the exact same thing.
  • SNMP Module still available?
    The link to download the SNMP duet sample module does not seem to work any more.
    Does this still exist?
    Regards, Harald
  • svTechsvTech Posts: 44
    I don't believe that Joel is an active participant on this forum any more. You might be able to send a personal email to him but I'm not sure he still uses the same email address either. If anyone downloaded his files back in the day, they might be able to share them with you.
  • travtrav Posts: 188
    Any copies
    Sorry to bump and old thread, but I was wondering if anyone managed to come across a copy of this duet module.
