Home AMX Technical Discussion
Did anyone have RS232 terminal software which is not need to install?
If you have it, please tell me.
Thanks a lot!
    Thanks a lot!
    If you mean that it does not have to be installed to harddisk for usage, PuTTY may be your choice.
    http://www.chiark.greenend.org.uk/~sgtatham/putty/
    Nice little tool supporting Telnet/ssh but also serial terminal. Basically you only need the putty.exe, additionally you may download the helpfile or the full zip archive.
  • AMXJeffAMXJeff Posts: 450
    I am a big PUTTY fan... I use Putty for SSH/Telnet connections. There is also a puttytel.exe for telnet and serial connection. No installation needed, just runs the executable. Also you can get SOURCE!!!!!!!!!!!!!!!!!!!!!
