IO impuls control
VladaPUB
I need to control climates device that can recognize only impulse from IO ports, so for example if I want to turn FAN to speed 1 I need to send impulse like this
IO port 1
4 seconds closed, 1 second open, 1 second closed
Or if I want to set fan speed to speed 3 I need to send
IO port 1
4 seconds closed, 1 second open, 1 second closed, 1 second open, 1 second closed, 1 second open, 1 second closed
And for temperature I for example 24 I need to send
IO port 1
2 seconds closed, 1 second open and than 1 second closed and 1 second for 14 times (desired temperature - 10)
Also I need counter to see what desired temperature is.
I have written it like
dvPanel = 10001:1:0 //mali touch panel
dvIO = 5001:4:0 //IO portovi
DEFINE_CONSTANT
DEFINE_TYPE
DEFINE_LATCHING
DEFINE_MUTUALLY_EXCLUSIVE
SET_PULSE_TIME (10)
CREATE_BUFFER dvPANEL,cPANEL_BUFFER
BUTTON_EVENT[dvPanel,1] //TEMP 20 digress
ON[dvIO,1]
WAIT 20
OFF[dvIO,1]
WAIT 30
PULSE[dvIO,1]
WAIT 50
PULSE[dvIO,1]
WAIT 70
PULSE[dvIO,1]
WAIT 90
PULSE[dvIO,1]
WAIT 110
PULSE[dvIO,1]
WAIT 130
PULSE[dvIO,1]
WAIT 150
PULSE[dvIO,1]
WAIT 170
PULSE[dvIO,1]
WAIT 190
PULSE[dvIO,1]
WAIT 210
PULSE[dvIO,1]
BUTTON_EVENT[dvPanel,2]
ON[dvIO,1]
WAIT 40
OFF[dvIO,1]
WAIT 50
PULSE[dvIO,1]
WAIT 70
PULSE[dvIO,1]
WAIT 90
PULSE[dvIO,1]
BUTTON_EVENT[dvPanel,3]
ON[dvIO,1]
WAIT 40
OFF[dvIO,1]
WAIT 50
PULSE[dvIO,1]
WAIT 70
PULSE[dvIO,1]
BUTTON_EVENT[dvPanel,4]
ON[dvIO,1]
WAIT 40
OFF[dvIO,1]
WAIT 50
PULSE[dvIO,1]
Question is how to optimize code ?!
IO port 1
IO port 1
IO port 1
DEFINE_CONSTANT
DEFINE_TYPE
DEFINE_LATCHING
SET_PULSE_TIME (10)
ON[dvIO,1]
WAIT 20
OFF[dvIO,1]
WAIT 30
PULSE[dvIO,1]
WAIT 50
PULSE[dvIO,1]
WAIT 70
PULSE[dvIO,1]
WAIT 90
PULSE[dvIO,1]
WAIT 110
PULSE[dvIO,1]
WAIT 130
PULSE[dvIO,1]
WAIT 150
PULSE[dvIO,1]
WAIT 170
PULSE[dvIO,1]
WAIT 190
PULSE[dvIO,1]
WAIT 210
PULSE[dvIO,1]
ON[dvIO,1]
WAIT 40
OFF[dvIO,1]
WAIT 50
PULSE[dvIO,1]
WAIT 70
PULSE[dvIO,1]
WAIT 90
PULSE[dvIO,1]
ON[dvIO,1]
WAIT 40
OFF[dvIO,1]
WAIT 50
PULSE[dvIO,1]
WAIT 70
PULSE[dvIO,1]
ON[dvIO,1]
WAIT 40
OFF[dvIO,1]
WAIT 50
PULSE[dvIO,1]
First, if it works, it might be best to leave it alone.
Second, I would never write something like that - I would code something generalised. Give me a day or so (;^) and it would look real good. Fortunately, NetLinx already offers you something to do that - the timeline. Go look it up, and I wish you the best of luck.
Third, it's not quite that simple. If I were to pick up your touchpanel and press a bunch of random buttons the result would, I presume, be ghastly, because everything would fire at once. So you need to address that issue with a queue, or better with a state monitor.
Both have been extensively detailed on various fora.
I am new at programing, so any help is great
BUTTON_EVENT[myTP, myBtn]
IF(!TIMELINE_ACTIVE(myTml))
// start the timeline, pulse the first relay
//here you pulse the following relays
TIMELINE_EVENT[myTml]
read the help about the event handlers TIMELINE.REPETITION and TIMELINE.SEQUENCE.
