Home AMX Technical Discussion
Radio Ra Module
Anyone else having problems with the Netlinx Radio Ra Module cuaing a very slow boot?
Once the system is up everything works fine but it takes up to 10 minutes to boot when I have the Radio Ra module included. If I comment it out it boots right up.
Error messages I see indicate :
000019
(0000044536) Co
(0000044687) Ref Error ^RASENDQ Index to large Line=241NDQ Index to large Line=241g (Referenc
(0000044384) Co
(0000044688) Ref Error ^RASENDQ Index to large Line=241r 1 Tk=0x0000
mm
(0000199678) GetString - Error 1 T
(0000044688) GetString - Error 1 Tk=0x0000large Line=241D=0x0000opyString (Reference)
(0000044689) CopyString (Reference) - Error 2 S=0x0000 D=0x00000x0000large Line=241o large Line=24199679) Ref Er
(0000044538) Co
(0000044689) Ref Error ^RASENDQ Index to large Line=241NDQ Index to large Line=241^RASENDQ Ind
(0000044386) Co
(0000044690) Ref Error ^RASENDQ Index to large Line=241r 1 Tk=0x0000or 1 Tk=0x0000large
>sseenndd__ccoom
(0000044690) GetString - Error 1 Tk=0x0000large Line=241D=0x0000x0000 e
(000019
(0000044240) Co
(0000044392
(0000044697) GetString - Error 1 Tk=0x0000SENDQ Index to large Line=241g (Ref
Any ideas what might cause this?
Thanks.
    It looks like a buffer index overflow on the outgoing queue. All the errors are probably what's bogging you down. Contact AMX; an out-of-the-box module shouldn't have those kinds of problems. I've had them get back to me with corrected modules in the past. Since you don't have the source, there isn't much else you can do with it besides re-write it yourself.
  • glr-ftiglr-fti Posts: 286
    I recently upgraded Studio to 2.5.0.163 and the NI2000 firmware to 3.21.343 and the problem mysteriously went away just in case anyone else has a similar problem.
    I updated this too soon. The problem is still there. I have sent an email to AMX support for ideas.
  • flcusatflcusat Posts: 309
    Any feedback on this issue?
    I've recently used the RadioRa module with no problems. It's in a working system right now.
    I stopped using the module and just created my own.
