IR Emitter Polarity Test
A good test for IR emitter polarity is to use your DMM (Digital Multi-Meter) in diode check mode.
With the IR emitter wires disconnected from the control system, connect the DMM leads to the IR emitter wires. If you don't see around 1.5V, flip the leads.
Red = Signal
Black = Ground
The reason this works is that an IR emitter is just a light emitting diode (LED) in the infrared spectrum.
Red = Signal
Black = Ground
--John
An easy quick check to see if your emitter is sending anything is to use your
cell phone camera to watch the emitter.
Dont forget, the human eye cannot see IR wavelengths, but a cameras pickup
device is sensitive to IR and shows it very well.
Regardless, this shouldn't be a problem - not sure why AMX (or the manufacturer) would all of a sudden change polarities. Certainly something we should haven't to test for. That'd almost be like . . . hmm, are pins 2 & 3 on the NIs transmit/recieve or recieve/transmit this time? Just something we shouldn't have to deal with.
Yeah, digicams too, but they don't seem to work on IR emitters, just on the regular remotes - ?
Listen anywhere on the wire, from output to emitter. It makes a very distinctive sound when IR data is being generated.
