Channel Code
George Krietsepis
Hi all,
I need to have the possibility to change the channel code of a touch panel button. I mean to have a channel code of 50 for example and then to change that to channel code of 0 and the opposite
Can I do that through NetLinx Studio with a send_command ?
George
George
First of all, you can't have a button with channel code 0. 0 is the code that is used to check for any channel on a device, e.g. BUTTON_EVENT[dvTP,0] will keep track of any button push.
Secondly, you can't change the channel of a button. There are a lot of things you can change about a button but channel isn't one of them. Chances are good that what you're trying to do can be accomplished another way via programming, e.g. changing a flag in your code and having ONE button that does different things depending on what the flag is.
This touch panel command will do that.
"'^ENA-<variable text address range>,<command value>'"
Enable or disable buttons with a set variable text range.
Syntax:
SEND_COMMAND <DEV>,"'^ENA-<vt addr range>,<command value>'"
Variables:
variable text address range = 1 - 4000.
command value = (0= disable, 1= enable).
Example:
SEND_COMMAND Panel,"'^ENA-500.504&510.515,0'"
Disables button pushes on buttons with variable text
range 500-504 & 510-515.
Jeff B
this what I need to do. This is a good idea.
Thanks a lot.
George
this is a good idea too but I need this buton not to be hidden.
George
I've only ever used it on systems with projectors, where I've automated it so much that the user never consciously controls the projector. As a result, I had to find a way to prevent them from trying to start up the system immediately after shutting down the system, giving the projector time to cool down. I created a transparent popup page with a 120 second timeout, and then I put in the code to pop it off if the projector sends a message saying its all cooled down.
I dont know what you're doing and it seems like you've already gotten much more precise advice, but this was a very easy solution to my problem, and the buttons never get stuck in the off position because of the timeout on the page.
J
