MSP8 Softwire Panel
ondrovic
Guys,
I am having issues with a MSP8 Softwire Panel. I have 8 regular MSP8 Keypads and 1 MSP8 Softwire Panel. The programming works perfectly on the regular MSP8's but im not getting any kind of control via the softwire panel. It says the device is online. Any ideas? I will post the code if you guys think it will help solve the problem. Just let me know. Thanks as always
Chris
Chris
ejm
PROGRAM_NAME='Head End'
(* FILE_LAST_MODIFIED_ON: 04/05/2006 AT: 09:00:25 *)
(* System Type : NetLinx *)
(* REV HISTORY: *)
$History: $
8.30.2007 - Started on reprogramming
Defined audio devices
Defined video devices
Defined virtual devices
Defined control devices
Defined keypads
Defined Touch Panels
Defined Source Constatns
Defined Place Holder Constants
Defined TP Offset
Defined Room Buttons
Defined Source Buttons
Defined External Buttons
Defined Power Buttons
Defined XM Preset Buttons
Defined CD Buttons
Defined Source Inputs
Defined Display Devices
Defined Rooms Structure
Defined Rooms
Setup Room Button Pop-ups
Setup Source Button Page Filps
Setup System Variables For Tracking
Setup Touch Panel Arrays
Setup Mutually Exclusive Buttons For Rooms
Setup Debug Function
Started Display On Function
Started Display Off Function
8.31.2007 - Continued on reprogramming
Defined SunRoom Devices
Defined Cd Player Buttons
Defined Cable Buttons
Defined Dvd Player Buttons
Wrote Code to send proper ir channel for cd player
Wrote Code to send proper ir channel for cable box
Wrote Code to send proper ir channel for dvd player
Added Code for Ada Suite 16 Switcher; Module
Added Code for Ada Tune Suite Tuner; Module
Added Code for IPort; Module
Added Code for External Button Push; Push & Hold
Added Code for MSP8; Module
Added Source Selection For MSP8
Added Volume Control For MSP8
Added Power Off For MSP8
Add Source Function For MSP8
Added Feedback For MSP8
9.4.2007 - Started reuploading code & panel files
updated firmware on both masters & touch panel
NI 900 - Dropped offline & isnt coming back online
Power Off button not switching room off - fixed power off issue
XM & AM FM - no feedback
Volume Levels different between differenet sources
IPod Testing MVP7500 - Works
AM / FM Testing MVP7500 - Controls Fine; No Feedback; working on feedback; feedback corrected
XM Testing MVP7500 - Controls Fine; No Feedback; working on feedback; feedback corrected
CD Testing MVP7500 - no cd will test tommorrow
IPod Testing Keypad - will test tommorrow
AM / FM Testing Keypad - will test tommorrow
XM Testing Keypad - will test tommorrow
CD Testing Keypad - will test tommorrowy
Added Mute Toggle Button; Added Mute Toggle Code - Tested -
Working on Video Equipment
Worked out issue where source mapping was incorrect
Added power on / off commands to correct calls
Testing Calls; On; Source; Off; - All Working correctly -
9.5.2007 - Testing Cable Box Functions; channel up / down & cursor buttons not working, keypad not working - fixed
Testing Dvd Player Functions; next / previous chapter & cursor buttons not working - fixed
Cable Cursor Up / Down Hold ( Page Up / Page Down ) not working - fixed
DVD Menu Button Not Working - fixed
Fixed Source Switching Error
Testing Cd Functions MVP7500 - Functions not working; - fixed
Testing Keypad functions for Cable; added buffer, and string parsing for the cable entry
Adding Favorites to cable page; Added correct icons to touch panel; added cable favorites to program; working fine -
Tested Radio & XM Keypad Input - works fine -:)
Working On MSP8's
Sources Are Switching Correctly
Feedback is working correctly
Power Off is working correctly
Source Functions aren't working correctly; iPod only thing thats not working
Source Function isn't working correctly; iPod only thing thats not working
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
//System : Equipment
dvADA_PORT = 5001:1:1 /// Serial Port For ADA-Bus adapter
dvIPod = 5001:3:1 /// iPod Device Control
dvCd = 5001:9:1 /// Denon DCM 280 - IR port # 2
dvSunRoom_TV = 5002:2:2 /// Sun Room Tv On System # 2
dvSunRoom_Cable = 5002:3:2 /// Sun Room Cable On System # 2
dvSunRoom_Dvd = 5002:4:2 /// Sun Room DVD On System # 2
dvSunRoom_IO = 5002:5:2 /// I.O Port - Cable Sense
//System : Virtual Devices
vdvADA_BUS = 33001:1:1 /// Bus Communication Driver
vdvADA_BUS2 = 33002:1:1 /// Bus Communication Driver
vdvADA_Suite16 = 33003:1:1 /// Virtual Switcher
vdvTuner1 = 33004:1:1 ///
vdvTuner2 = 33005:1:1 ///
vdvTuner3 = 33006:1:1 ///
vdvTuner4 = 33007:1:1 ///
vdvIPod = 41000:1:1 /// IPod Communication Driver
//System : Control Devices
dvRelay = 5001:8:1 /// Relay to turn on amps
//System : Keypads
dvKeypad_1 = 6001:1:1 /// Living / Dining Room
dvKeypad_2 = 6002:1:1 /// Sunroom
dvKeypad_3 = 6003:1:1 /// Master Bedroom
dvKeypad_4 = 6004:1:1 /// Master Bathroom
dvKeypad_5 = 6005:1:1 /// Bedroom # 2
dvKeypad_6 = 6006:1:1 /// Kitchen
dvKeypad_7 = 6007:1:1 /// Office
dvKeypad_8 = 6008:1:1 /// Bedroom # 5
dvKeypad_9 = 169:1:1 /// Bathroom # 2
vdvKeypad_1 = 33021:1:1
vdvKeypad_2 = 33022:1:1
vdvKeypad_3 = 33023:1:1
vdvKeypad_4 = 33024:1:1
vdvKeypad_5 = 33025:1:1
vdvKeypad_6 = 33026:1:1
vdvKeypad_7 = 33027:1:1
vdvKeypad_8 = 33028:1:1
vdvKeypad_9 = 33029:1:1
//System : Touch Panels
dvPanel_1a = 10001:1:1 /// System Control Port
dvPanel_1b = 10001:2:1 /// TuneSuite Control Port
dvPanel_1c = 10001:3:1 /// iPod Control Port
dvPanel_1d = 10001:4:1 /// CD Control Port
dvPanel_1e = 10001:5:1 /// Cable Control Port
dvPanel_1f = 10001:6:1 /// DVD Control Port
//System : Virtual Panels for MSP8
//System : Virtual Panel : MSP8 : Living Room
dvPanel_2a = 10002:1:1 /// System Control Port
dvPanel_2b = 10002:2:1 /// TuneSuite Control Port
dvPanel_2c = 10002:3:1 /// iPod Control Port
dvPanel_2d = 10002:4:1 /// CD Control Port
//System : Virtual Panel : MSP8 : Sun Room
dvPanel_3a = 10003:1:1 /// System Control Port
dvPanel_3b = 10003:2:1 /// TuneSuite Control Port
dvPanel_3c = 10003:3:1 /// iPod Control Port
dvPanel_3d = 10003:4:1 /// CD Control Port
//System : Virtual Panel : MSP8 : Master Bedroom
dvPanel_4a = 10004:1:1 /// System Control Port
dvPanel_4b = 10004:2:1 /// TuneSuite Control Port
dvPanel_4c = 10004:3:1 /// iPod Control Port
dvPanel_4d = 10004:4:1 /// CD Control Port
//System : Virtual Panel : MSP8 : Master Bathroom
dvPanel_5a = 10005:1:1 /// System Control Port
dvPanel_5b = 10005:2:1 /// TuneSuite Control Port
dvPanel_5c = 10005:3:1 /// iPod Control Port
dvPanel_5d = 10005:4:1 /// CD Control Port
//System : Virtual Panel : MSP8 : Bedroom # 2
dvPanel_6a = 10006:1:1 /// System Control Port
dvPanel_6b = 10006:2:1 /// TuneSuite Control Port
dvPanel_6c = 10006:3:1 /// iPod Control Port
dvPanel_6d = 10006:4:1 /// CD Control Port
//System : Virtual Panel : MSP8 : Kitchen
dvPanel_7a = 10007:1:1 /// System Control Port
dvPanel_7b = 10007:2:1 /// TuneSuite Control Port
dvPanel_7c = 10007:3:1 /// iPod Control Port
dvPanel_7d = 10007:4:1 /// CD Control Port
//System : Virtual Panel : MSP8 : Office
dvPanel_8a = 10008:1:1 /// System Control Port
dvPanel_8b = 10008:2:1 /// TuneSuite Control Port
dvPanel_8c = 10008:3:1 /// iPod Control Port
dvPanel_8d = 10008:4:1 /// CD Control Port
//System : Virtual Panel : MSP8 : Bedroom # 5
dvPanel_9a = 10009:1:1 /// System Control Port
dvPanel_9b = 10009:2:1 /// TuneSuite Control Port
dvPanel_9c = 10009:3:1 /// iPod Control Port
dvPanel_9d = 10009:4:1 /// CD Control Port
//System : Virtual Panel : MSP8 : Bathroom # 2
dvPanel_10a = 10010:1:1 /// System Control Port
dvPanel_10b = 10010:2:1 /// TuneSuite Control Port
dvPanel_10c = 10010:3:1 /// iPod Control Port
dvPanel_10d = 10010:4:1 /// CD Control Port
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
//System : Touch Panel Offset
TP_Offset = 10000
TP_Offset_2 = 10001
//System : Place Holders
Temp_Port = 0
Temp_Channel = 0
Temp_Dev = 0
//System : Source Input Constants
AM_FM = 1
XM = 3
iPod = 4
CD = 2
Satellite = 0
Cable = 12
DVD = 13
//System : Source Constants
SC_IPOD = 1000
SC_XM = 1001
SC_AM_FM = 1002
SC_CD = 1003
//System : Room Buttons
INTEGER nRoom_Buttons[]=
1101, /// Living Room / Dining Room
1102, /// Sun Room
1103, /// Master Bedroom
1104, /// Master Bathroom
1105, /// Bedroom # 2
1106, /// Kitchen
1107, /// Office
1108, /// Bedroom # 5
1109 /// Bathroom # 2
//System : Source Buttons
INTEGER nSource_Buttons[]=
1000, /// AM / FM
1001, /// CD
1002, /// XM
1003, /// iPod
1004, /// ReQuest
1005, /// <OPEN>
1006, /// <OPEN>
1107, /// <OPEN>
1108, /// <OPEN>
1109, /// <OPEN>
1010, /// Satellite
1011, /// Cable
1012 /// DVD
//System : Touch Panel Display Buttons
//System : Touch Panel External Buttons
INTEGER nExternal_Buttons[]=
2010, /// 1st Left Button
2011, /// 2nd Left Button
2012, /// 3rd Left Button
2013, /// 4th Left Button
2014, /// Up Button
2015, /// Down Button
2016, /// Left Button
2017, /// Right Button
2018 /// Center Button
//System : Powere Off Button
INTEGER nPower_Buttons[]=
2000 /// Power Off
//MSP8 : Keypads
INTEGER nKeypad_Source_Buttons[]=
1, //Source 1
2, //Source 2
3, //Source 3
4 //Source 4
INTEGER nKeypad_Volume_Buttons[]=
6, //Volume Up
7 //Volume Down
INTEGER nKeypad_Power_Buttons[]=
5 //Power off - **
INTEGER nKeypad_Function_Buttons[]=
8 //Function
//TuneSuite : Preset Buttons
INTEGER nTuneSuite_Presets[]=
38, /// Preset 1
39, /// Preset 2
40, /// Preset 3
41, /// Preset 4
42, /// Preset 5
43 /// Preset 6
//CD Player : Buttons
INTEGER nCD_Buttons[]=
//-- uses nButton
1, /// Play
2, /// Stop
3, /// Pause
4, /// Skip >>
5, /// Skip <<
6, /// Scan >>
7, /// Scan <<
//-- uses nButton + 2
8, /// 10
9, /// 1
10, /// 2
11, /// 3
12, /// 4
13, /// 5
14, /// 6
15, /// 7
16, /// 8
17, /// 9
18, /// 10+
//-- uses nButton + 5
19, /// Volume +
20, /// Volume -
//-- uses nButton + 29
21, /// Disc Skip +
22, /// Disc Skip -
23, /// Disc Select
//-- uses nButton + 31
24, /// Repeat
25, /// Random
26, /// Prog/Direct
27, /// Time
//-- uses nButton + 40
28, /// Open/Close
//-- uses nButton + 91
29 /// Call
INTEGER nCD_Disc_Buttons[]=
30, /// Disc 1
31, /// Disc 2
32, /// Disc 3
33, /// Disc 4
34 /// Disc 5
//Cable Box : Buttons
INTEGER nCable_Buttons[]=
//-- uses nButton
1, /// Play
2, /// Stop
3, /// Pause
4, /// Forward
5, /// Rewind
6, /// Record
7, /// Power (TOG)
8, /// 0
9, /// 1
10, /// 2
11, /// 3
12, /// 4
13, /// 5
14, /// 6
15, /// 7
16, /// 8
17, /// 9
18, /// Channel +
19, /// Channel -
//-- uses nButton + 24
20, /// Menu
21, /// Cursor Up
22, /// Cursor Dn
23, /// Cursor Lf
24, /// Cursor Rg
25, /// Cursor Sel
//-- uses nButton + 30
26, /// Live
27, /// Replay
//-- uses nButton + 94
28, /// Guide
29, /// Info
30, /// Page Up
31, /// Page Dn
32, /// Exit
33, /// Settings
34, /// A
35, /// B
36, /// C
37, /// Last
38, /// PIP On/Off
39, /// Pip Swap
40, /// Pip Move
41, /// PIP Channel +
42, /// PIP Channel -
43, /// Video Source
44, /// *
45, /// #
46, /// List
47 /// Fav
//Cable Box : Favorites
Integer nCable_Favorites[]=
51, /// Preset 1
52, /// Preset 2
53, /// Preset 3
54, /// Preset 4
55, /// Preset 5
56, /// Preset 6
57, /// Preset 7
58, /// Preset 8
59, /// Preset 9
60, /// Preset 10
61, /// Preset 11
62 /// Preset 12
//Dvd Player : Buttons
INTEGER nDvd_Buttons[]=
//-- uses nButton
1, /// Play
2, /// Stop
3, /// Pause
4, /// Skip >>
5, /// Skip <<
6, /// Forward >>
7, /// Rewind <<
8, /// 0
9, /// 1
10, /// 2
11, /// 3
12, /// 4
13, /// 5
14, /// 6
15, /// 7
16, /// 8
17, /// 9
18, /// 10+
//-- uses nButton + 8
19, /// Power On
20, /// Power Off
//-- uses nButton + 21
21, /// A/B
//-- uses nButton + 22
22, /// Menu
23, /// Cursor Up
24, /// Cursor Dn
25, /// Cursor Lf
26, /// Cursor Rg
27, /// Cursor Sel
//-- uses nButton + 23
28, /// Title Menu
29, /// Clear
30, /// Return
31, /// Angle
32, /// Subtitle
//-- uses nButton + 25
33, /// Display On Screen
//-- uses nButton + 44
34, /// Zoom
//-- uses nButton + 45
35, /// Open / Close
//-- uses nButton + 46
36, /// Random; Shiffle
//-- uses nButton + 47
37 /// Setup; Action
//ADA Suite 16 Digital Switcher
VOLATILE INTEGER NX_NO_BUTTON = 256
//XM Guide : Preset Buttons
Integer XM_GUIDE_BUTTONS[]=
100, /// Preset 1
101, /// Preset 2
102, /// Preset 3
103, /// Preset 4
104, /// Preset 5
105, /// Preset 6
106, /// Preset 7
107, /// Preset 8
108, /// Preset 9
109, /// Preset 10
110, /// Preset 11
111, /// Preset 12
112, /// Preset 13
113, /// Preset 14
114, /// Preset 15
115, /// Preset 16
116, /// Preset 17
117, /// Preset 18
118, /// Preset 19
119, /// Preset 20
120, /// Preset 21
121, /// Preset 22
122, /// Preset 23
123, /// Preset 24
124, /// Preset 25
125, /// Preset 26
126, /// Preset 27
127, /// Preset 28
128, /// Preset 29
129, /// Preset 30
130, /// Preset 31
131, /// Preset 32
132, /// Preset 33
133, /// Preset 34
134, /// Preset 35
135, /// Preset 36
136, /// Preset 37
137, /// Preset 38
138, /// Preset 39
139, /// Preset 40
140, /// Preset 41
141, /// Preset 42
142, /// Preset 43
143, /// Preset 44
144, /// Preset 45
145, /// Preset 46
146, /// Preset 47
147, /// Preset 48
148, /// Preset 49
149, /// Preset 50
150, /// Preset 51
151, /// Preset 52
152, /// Preset 53
153, /// Preset 54
154, /// Preset 55
155, /// Preset 56
156, /// Preset 57
157, /// Preset 58
158, /// Preset 59
159, /// Preset 60
160, /// Preset 61
161, /// Preset 62
162, /// Preset 63
163, /// Preset 64
164, /// Preset 65
165, /// Preset 66
166, /// Preset 67
167, /// Preset 68
168, /// Preset 69
169, /// Preset 70
170, /// Preset 71
171, /// Preset 72
172, /// Preset 73
173, /// Preset 74
174, /// Preset 75
175, /// Preset 76
176, /// Preset 77
177, /// Preset 78
178, /// Preset 79
179, /// Preset 80
180, /// Preset 81
181, /// Preset 82
182, /// Preset 83
183, /// Preset 84
184, /// Preset 85
185, /// Preset 86
186, /// Preset 87
187, /// Preset 88
188, /// Preset 89
189, /// Preset 90
190, /// Preset 91
191, /// Preset 92
192, /// Preset 93
193, /// Preset 94
194, /// Preset 95
195, /// Preset 96
196, /// Preset 97
197, /// Preset 98
198, /// Preset 99
199, /// Preset 100
200, /// Preset 101
201, /// Preset 102
202, /// Preset 103
203, /// Preset 104
204, /// Preset 105
205, /// Preset 106
206, /// Preset 107
207, /// Preset 108
208, /// Preset 109
209, /// Preset 110
210, /// Preset 111
211, /// Preset 112
212, /// Preset 113
213, /// Preset 114
214, /// Preset 115
215, /// Preset 116
216, /// Preset 117
217, /// Preset 118
218, /// Preset 119
219, /// Preset 120
220, /// Preset 121
221, /// Preset 122
222, /// Preset 123
223, /// Preset 124
224, /// Preset 125
225, /// Preset 126
226, /// Preset 127
227, /// Preset 128
228, /// Preset 129
229, /// Preset 130
230, /// Preset 131
231, /// Preset 132
232, /// Preset 133
233, /// Preset 134
234, /// Preset 135
235, /// Preset 136
236, /// Preset 137
237, /// Preset 138
238, /// Preset 139
239, /// Preset 140
240, /// Preset 141
241, /// Preset 142
242, /// Preset 143
243, /// Preset 144
244, /// Preset 145
245, /// Preset 146
246, /// Preset 147
247, /// Preset 148
248, /// Preset 149
249, /// Preset 150
250, /// Preset 151
251 /// Preset 152
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
//System : Room Structure
STRUCTURE _ROOMS
INTEGER Index /// Stores the room index #
CHAR Name[30] /// Stores the actual room name
INTEGER Audio_Stat /// Stores whether or not the room has audio control; 1=True; 0=Flase
INTEGER Video_Stat /// Stores whether or not the room has video control; 1=True; 0=Flase
INTEGER Lighting /// Stores whether or not the room has lighting control; 1=True; 0=Flase
INTEGER Cur_Source /// Stores the current source for the indexed room
INTEGER Source_Mapping[30] /// Stores the sources for the indexed room
Source_Index[1] = the iPod index
Source_Index[2] = the XM index
Source_Index[3] = the AM/FM index
Source_Index[4] = the CD index
Source_Index[5] = the Request index
Source_Index[9] = the Satellite TV index
Source_Index[10] = the Cable TV index
Source_Index[11] = the DVD index
Rooms[1].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[1].Source_Mapping[2] = CD /// CD Input - 2
Rooms[1].Source_Mapping[3] = XM /// XM Input - 3
Rooms[1].Source_Mapping[4] = iPod /// iPod - 4
Rooms[1].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[1].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[1].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[1].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[1].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[1].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[1].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[1].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[1].Source_Mapping[13] = Dvd /// Dvd Input - 13
//System : XM Guide Structure
STRUCTURE _XM_GUIDE
INTEGER Index /// Index number
CHAR Chan[3] /// Stores the Channel Number
CHAR Name[45] /// Stores the Channel Name
CHAR Description[500] /// For future use
CHAR Genre[45] /// For future use
//System : Cable Favorites Structure
STRUCTURE _Cable_Presets
INTEGER Index /// Index Number
Char Chan[3] /// Stores the Channel Number
Char Name[25] /// Stores the Channel Name
Char Description[200] /// For future use
Char Genre[15] /// For future use
(* VARIABLE DEFINITIONS GO BELOW *)
//System Structures
_ROOMS Rooms[9] /// Stores the number of total rooms
_XM_GUIDE XM_GUIDE[152] /// Stores the number of total channels
_Cable_Presets Cable_Index[12] /// Stores the number of total channels
//System Wide Variables
INTEGER nRoom_Index[9]
INTEGER nTv_Power[9]
INTEGER nPanel_Address
INTEGER nPanel_Index
INTEGER nButton
INTEGER nIR_Cmd
CHAR strZn_Pwr[16]
//System Keypad Variables : XM
Integer nNumber1 /// Stores the first number of a channel preset
Integer nNumber2 /// Stores the second number of a channel preset
Integer nNumber3 /// Stores the third number of a channel preset
Char strKPValue[25] /// Stores the returned system keypad number
//System Keypad Variables : Cable
Char strTP_Buffer[1000] /// Buffer for touch panel
Integer nNumber1a /// Stores the first number of a channel preset
Integer nNumber2a /// Stores the second number of a channel preset
Integer nNumber3a /// Stores the third number of a channel preset
Char strKP[25] /// Stores the returned system keypad number
//MSP8 : Keypads
Integer nCntl_Panel_Address /// Stores the control panel address
Integer nTemp /// Stores temporary button for msp8
Integer nKP_Index /// Stores the keypad index
Integer nKP_Address /// Stores the address of the keypad
VOLATILE INTEGER NL_NO_BUTTON // NO BUTTON DEFINITION
VOLATILE INTEGER ADA_BUTTONS[]=
1, //1 - ALL ROOM OFF
2, //2 - ROOM OFF
3, //3 -
4, //4 -
5, //5 - INPUT 1
6, //6 - INPUT 2
7, //7 - INPUT 3
8, //8 - INPUT 4
9, //9 - INPUT 5
10, //10- INPUT 6
11, //11- INPUT 7
12, //12- INPUT 8
13, //13- INPUT 9
14, //14- INPUT 10
15, //15- INPUT 11
16, //16- INPUT 12
17, //17- INPUT 13
18, //18- INPUT 14
19, //19- INPUT 15
20, //20- INPUT 16
21, //21-
22, //22-
23, //23- MUTE ON
24, //24- MUTE OFF
25, //25- SELECT ROOM BUTTON
26, //26- OK BUTTON ON MAIN PAGE
27, //27- VOLUME UP
28, //28- VOLUME DOWN
29, //29- AUDIO COMMANDS / VIDEO COMMANDS BUTTON
30, //30- AUDIO CONTROLS BUTTON ON MAIN PAGE
31, //31- VIDEO CONTROLS BUTTON ON MAIN PAGE
32, //32- SETUP CONTROLS BUTTON ON MAIN PAGE
33, //33- ADVANCED BUTTON ON MAIN PAGE
34, //34- PAGING BUTTON ON MAIN PAGE
35, //35- BASS UP ON AUDIO CONTROLS PAGE
36, //36- BASS DOWN ON AUDIO CONTROLS PAGE
37, //37- TREBLE UP ON AUDIO CONTROLS PAGE
38, //38- TREBLE DOWN ON AUDIO CONTROLS PAGE
39, //39- LOUDNESS CONTOUR ON AUDIO CONTROLS PAGE
40, //40- STEREO ENHANCE ON AUDIO CONTROLS PAGE
41, //41- BALANCE LEFT ON AUDIO CONTROLS PAGE
42, //42- BALANCE EQUAL ON AUDIO CONTROLS PAGE
43, //43- BALANCE RIGHT ON AUDIO CONTROLS PAGE
44, //44- STEREO ON AUDIO CONTROLS PAGE
45, //45- MONO ON AUDIO CONTROLS PAGE
46, //46-
47, //47- TONE RECALL 1 ON AUDIO CONTROLS PAGE
48, //48- TONE RECALL 2 ON AUDIO CONTROLS PAGE
49, //49- TONE RECALL 3 ON AUDIO CONTROLS PAGE
50, //50- TONE RECALL 4 ON AUDIO CONTROLS PAGE
51, //51- TONE STORE 1 ON AUDIO CONTROLS PAGE
52, //52- TONE STORE 2 ON AUDIO CONTROLS PAGE
53, //53- TONE STORE 3 ON AUDIO CONTROLS PAGE
54, //54- TONE STORE 4 ON AUDIO CONTROLS PAGE
55, //55- VOLUME RECALL 1 ON AUDIO CONTROLS PAGE
56, //56- VOLUME RECALL 2 ON AUDIO CONTROLS PAGE
57, //57- VOLUME RECALL 3 ON AUDIO CONTROLS PAGE
58, //58- VOLUME RECALL 4 ON AUDIO CONTROLS PAGE
59, //59- VOLUME STORE 1 ON AUDIO CONTROLS PAGE
60, //60- VOLUME STORE 2 ON AUDIO CONTROLS PAGE
61, //61- V0LUME STORE 3 ON AUDIO CONTROLS PAGE
62, //62- VOLUME STORE 4 ON AUDIO CONTROLS PAGE
63, //63- ROOM SELECT ON VIDEO CONTROLS PAGE (VIDEO INPUTS TO FOLLOW AUDIO)
64, //64- VIDEO INPUT 1 TO FOLLOW AUDIO
65, //65- VIDEO INPUT 2 TO FOLLOW AUDIO
66, //66- VIDEO INPUT 3 TO FOLLOW AUDIO
67, //67- VIDEO INPUT 4 TO FOLLOW AUDIO
68, //68- VIDEO INPUT 5 TO FOLLOW AUDIO
69, //69- VIDEO INPUT 6 TO FOLLOW AUDIO
70, //70- VIDEO INPUT 7 TO FOLLOW AUDIO
71, //71- VIDEO INPUT 8 TO FOLLOW AUDIO
72, //72- VIDEO INPUT 9 TO FOLLOW AUDIO
73, //73- VIDEO INPUT 10 TO FOLLOW AUDIO
74, //74- VIDEO INPUT 11 TO FOLLOW AUDIO
75, //75- VIDEO INPUT 12 TO FOLLOW AUDIO
76, //76- VIDEO INPUT 13 TO FOLLOW AUDIO
77, //77- VIDEO INPUT 14 TO FOLLOW AUDIO
78, //78- VIDEO INPUT 15 TO FOLLOW AUDIO
79, //79- VIDEO INPUT 16 TO FOLLOW AUDIO
80, //80- SELECT TRIGGER ON VIDEO CONTROLS PAGE
81, //81- TRIGGER ASSIGNED TO VIDEO INPUT 1
82, //82- TRIGGER ASSIGNED TO VIDEO INPUT 2
83, //83- TRIGGER ASSIGNED TO VIDEO INPUT 3
84, //84- TRIGGER ASSIGNED TO VIDEO INPUT 4
85, //85- TRIGGER ASSIGNED TO VIDEO INPUT 5
86, //86- TRIGGER ASSIGNED TO VIDEO INPUT 6
87, //87- TRIGGER ASSIGNED TO VIDEO INPUT 7
88, //88- TRIGGER ASSIGNED TO VIDEO INPUT 8
89, //89- TRIGGER ASSIGNED TO VIDEO INPUT 9
90, //90- TRIGGER ASSIGNED TO VIDEO INPUT 10
91, //91- TRIGGER ASSIGNED TO VIDEO INPUT 11
92, //92- TRIGGER ASSIGNED TO VIDEO INPUT 12
93, //93- TRIGGER ASSIGNED TO VIDEO INPUT 13
94, //94- TRIGGER ASSIGNED TO VIDEO INPUT 14
95, //95- TRIGGER ASSIGNED TO VIDEO INPUT 15
96, //96- TRIGGER ASSIGNED TO VIDEO INPUT 16
97, //97- SELECT ROOM NUMBER ON VIDEO CONTROLS PAGE (ASSIGN TRIGGER FOR ROOM OUTPUT)
98, //98- ASSIGN TRIGGER 1
99, //99- ASSIGN TRIGGER 2
100, //100-ASSIGN TRIGGER 3
101, //101-ASSIGN TRIGGER 4
102, //102-ASSIGN TRIGGER 5
103, //103-
104, //104- DWELL TIME
105, //105-CYCLE COUNT
106, //106-ENABLE/DISABLE TRIGGER 1
107, //107-ENABLE/DISABLE TRIGGER 2
108, //108-ENABLE/DISABLE TRIGGER 3
109, //109-ENABLE/DISABLE TRIGGER 4
110, //110-
111, //111-INPUT 1 ON SETUP CONTROLS PAGE
112, //112-INPUT 2 ON SETUP CONTROLS PAGE
113, //113-INPUT 3 ON SETUP CONTROLS PAGE
114, //114-INPUT 4 ON SETUP CONTROLS PAGE
115, //115-INPUT 5 ON SETUP CONTROLS PAGE
116, //116-INPUT 6 ON SETUP CONTROLS PAGE
117, //117-INPUT 7 ON SETUP CONTROLS PAGE
118, //118-INPUT 8 ON SETUP CONTROLS PAGE
119, //119-INPUT 9 ON SETUP CONTROLS PAGE
120, //120-INPUT 10 ON SETUP CONTROLS PAGE
121, //121-INPUT 11 ON SETUP CONTROLS PAGE
122, //122-INPUT 12 ON SETUP CONTROLS PAGE
123, //123-INPUT 13 ON SETUP CONTROLS PAGE
124, //124-INPUT 14 ON SETUP CONTROLS PAGE
125, //125-INPUT 15 ON SETUP CONTROLS PAGE
126, //126-INPUT 16 ON SETUP CONTROLS PAGE
127, //127-LEVEL TRIM BUTTON ON SETUP CONTROLS PAGE
128, //128- OK BUTTON ON SETUP CONTROLS PAGE
129, //129-SELECT ROOM ON ADVANCED CONTROLS PAGE
130, //130-SELECT PARTY 1 (ROOM)
131, //131-SELECT PARTY 2 (ROOM)
132, //132-SELECT PARTY 3 (ROOM)
133, //133-SELECT PARTY 4 (ROOM)
134, //134-SELECT INPUT ON ADVANCED CONTROLS PAGE
135, //135-SELECT PARTY 1 (INPUT)
136, //136-SELECT PARTY 2 (INPUT)
137, //137-SELECT PARTY 3 (INPUT)
138, //138-SELECT PARTY 4 (INPUT)
139, //139-RESET TO FACTORY SETTINGS
140, //140-SOFTWARE VERSION OF THE ADA CARDS
141, //141-PAGE ROOM NUMBER
142, //142-OK BUTTON TO PAGE ROOM NUMBER
143, //143-PAGE GROUP NUMBER
144, //144-EXCLUDE ROOM NUMBER FROM PAGING
145, //145-OK BUTTON TO PAGE GROUP
146, //146-MAKE ROOM NUMBER MEMBER OF PAGING GROUP
147, //147-PAGING GROUP 1
148, //148-PAGING GROUP 2
149, //149-PAGING GROUP 3
150, //150-PAGING GROUP 4
151, //151-PAGING GROUP 5
152, //152-PAGING GROUP 6
153, //153-PAGING GROUP 7
154, //154-PAGING GROUP 8
155, //155-PAGING VOLUME UP
156, //156-PAGING VOLUME DOWN
157, //157-GROUP 7 AUTO PAGE ON
158, //158-GROUP 7 AUTO PAGE OFF
159, //159-AUTO PAGE
160, //160-GROUP 8 MANUAL PAGE
161, //161-GROUP 1-6 PAGE OFF
162, //162-LABEL 1 ON MAIN SCREEN
163, //163-LABEL 2 ON MAIN SCREEN
164, //164-LABEL 3 ON MAIN SCREEN
165, //165-LABEL 4 ON MAIN SCREEN
166, //166-LABEL 5 ON MAIN SCREEN
167, //167-LABEL 6 ON MAIN SCREEN
168, //168-LABEL 7 ON MAIN SCREEN
169, //169-LABEL 8 ON MAIN SCREEN
170, //170-LABEL 9 ON MAIN SCREEN
171, //171-LABEL 10 ON MAIN SCREEN
172, //172-LABEL 11 ON MAIN SCREEN
173, //173-LABEL 12 ON MAIN SCREEN
174, //174-LABEL 13 ON MAIN SCREEN
175, //175-LABEL 14 ON MAIN SCREEN
176, //176-LABEL 15 ON MAIN SCREEN
177, //177-LABEL 16 ON MAIN SCREEN
178, //178-GROUP 7 PAGING ACTIVATED/OFF
179, //179-
// TEXT BOX DEFINITIONS
180, //180-MID NUMBER ON AUDIO CONTROLS PAGE
181, //181-LABEL FOR INPUT 1 ON MAIN PAGE
182, //182-LABEL FOR INPUT 2 ON MAIN PAGE
183, //183-LABEL FOR INPUT 3 ON MAIN PAGE
184, //184-LABEL FOR INPUT 4 ON MAIN PAGE
185, //185-LABEL FOR INPUT 5 ON MAIN PAGE
186, //186-LABEL FOR INPUT 6 ON MAIN PAGE
187, //187-LABEL FOR INPUT 7 ON MAIN PAGE
188, //188-LABEL FOR INPUT 8 ON MAIN PAGE
189, //189-LABEL FOR INPUT 9 ON MAIN PAGE
190, //190-LABEL FOR INPUT 10 ON MAIN PAGE
191, //191-LABEL FOR INPUT 11 ON MAIN PAGE
192, //192-LABEL FOR INPUT 12 ON MAIN PAGE
193, //193-LABEL FOR INPUT 13 ON MAIN PAGE
194, //194-LABEL FOR INPUT 14 ON MAIN PAGE
195, //195-LABEL FOR INPUT 15 ON MAIN PAGE
196, //196-LABEL FOR INPUT 16 ON MAIN PAGE
197, //197-INPUT NUMBER ON MAIN PAGE
198, //198-VOLUME NUMBER ON MAIN PAGE
199, //199-TEXT BOX THAT TELLS WHAT audio INPUT IS IN THE ROOM SELECTED ON MAIN PAGE
200, //200-ROOM NUMBER ON MAIN PAGE
201, //201-BASS NUMBER ON AUDIO CONTROLS PAGE
202, //202-TREBLE NUMBER ON AUDIO CONTROLS PAGE
203, //203-BALANCE NUMBER ON AUDIO CONTROLS PAGE
204, //204-ROOM NUMBER ON VIDEO CONTROLS PAGE (VIDEO INPUTS THAT FOLLOW AUDIO)
205, //205-TRIGGER NUMBER ON VIDEO CONTROLS PAGE
206, //206-ROOM NUMBER ON VIDEO CONTROLS PAGE (ASSIGN TRIGGER FOR ROOM)
207, //207-
208, //208-DWELL TIME NUMBER
209, //209-CYCLE COUNT NUMBER
210, //210-INPUT NUMBER ON SETUP CONTROLS PAGE
211, //211-LEVEL TRIM NUMBER ON SETUP CONTROLS PAGE
212, //212-ROOM NUMBER FOR PARTY
213, //213-INPUT NUMBER FOR PARTY
214, //214-ROOM NUMBER TO PAGE
215, //215-GROUP NUMBER TO PAGE
216, //216-ROOM NUMBER TO EXCLUDE FROM PAGING
217, //217-ROOM NUMBER TO MAKE MEMBER OF A PAGING GROUP
218, //218-PAGING VOLUME
219, //219-CURRENT ROOM NUMBER ON AUDIO CONTROLS PAGE
220, //220-CURRENT ROOM NUMBER ON MAIN PAGE
221, //221- software AUDIO card 1 version
222, //222- software AUDIO card 2 version
223, //223- software AUDIO card 3 version
224, //224- software AUDIO card 4 version
225, //225- software AUDIO card 5 version
226, //226- software AUDIO card 6 version
227, //227- software VIDEO card 1 version
228, //228- software VIDEO card 2 version
229, //229- software VIDEO card 3 version
230, //230- software VIDEO card 4 version
231, //231- software VIDEO card 5 version
232, //232- software VIDEO card 6 version
233, //233- TEXT BOX THAT TELLS WHAT video INPUT IS IN THE ROOM SELECTED ON MAIN PAGE
// EXPANSION BUTTONS FOR PARTY ROOMS 5-8, MIDRANGE CONTROLS
234, //234- SELECT PARTY 5 (ROOM)
235, //235- SELECT PARTY 6 (ROOM)
236, //236- SELECT PARTY 7 (ROOM)
237, //237- SELECT PARTY 8 (ROOM)
238, //238- SELECT PARTY 5 (INPUT)
239, //239- SELECT PARTY 6 (INPUT)
240, //240- SELECT PARTY 7 (INPUT)
241, //241- SELECT PARTY 8 (INPUT)
242, //242- MID UP ON AUDIO CONTROLS PAGE
243, //243- MID DOWN ON AUDIO CONTROLS PAGE
244 //244- TONE CYCLE ON AUDIO CONTROLS PAGE
//ADA TuneSuite Tuner
INTEGER nTUNE_SUITE_BAUD = 19200 // Normally 19200, set to 1200 for older ADA systems
CHAR cTUNE_SUITE_ADDR = '0' // See below; hex address for the tuner (0-F; default = '0')
VOLATILE INTEGER TP_TuneSuite_BUTTONS[] = // Touchpanel button mapping array
// CHANNEL BUTTONS
6, // 1 SEEK DOWN
7, // 2 SEEK UP
8, // 3 STEREO/MONO
9, // 4 FILTER
10, // 5 TUNER 1
11, // 6 TUNER 2
12, // 7 TUNER 3
15, // 8 TUNER 4
13, // 9 TUNE DOWN
14, // 10 TUNE UP
16, // NUM 1
17, // NUM 2
18, // NUM 3
19, // NUM 4
20, // NUM 5
21, // NUM 6
22, // NUM 7
23, // NUM 8
24, // NUM 9
25, // 20 NUM DECIMAL
26, // NUM 0
27, // NUM OK
30, // PRESET PREVIOUS
31, // PRESET NEXT
28, // 25 BAND TOGGLE
29, // DE-EMPH TOGGLE
32, // NUM CLEAR
33, // PRESET SAVE
34, // PRESET CLEAR
35, // 30 GOTO TUNE
36, // GOTO PRESETS
37, // PRESET 0
38, // PRESET 1
39, // PRESET 2
40, // 35 PRESET 3
41, // PRESET 4
42, // PRESET 5
43, // PRESET 6
44, // PRESET 7
45, // 40 PRESET 8
46, // PRESET 9
47, // PRESET CLR
48, // PRESET OK
49, // XM PREV STATION
50 // 45 XM NEXT STATION
VOLATILE INTEGER TP_TuneSuite_FIELDS[]= // VARIABLE TEXT BUTTONS
1, // 1 TUNER 1 FREQ DATA
2, // 2 TUNER 2 FREQ DATA
3, // 3 TUNER 3 FREQ DATA
15, // 4 TUNER 4 FREQ DATA
4, // 5 TUNER 1 LABEL TEXT
5, // 6 TUNER 2 LABEL TEXT
6, // 7 TUNER 3 LABEL TEXT
16, // 8 TUNER 4 LABEL TEXT
7, // 9 TUNER 1 BAND
8, // 10 TUNER 2 BAND
9, // TUNER 3 BAND
17, // TUNER 4 BAND
10, // VERSION/KEYPAD DISPLAY
11, // TUNER 1 STEREO/MONO
12, // 15 TUNER 2 STEREO/MONO
13, // TUNER 3 STEREO/MONO
18, // TUNER 4 STEREO/MONO
19, // TUNER 1 XM CHANNEL
20, // TUNER 2 XM CHANNEL
21, // 20 TUNER 3 XM CHANNEL
22, // TUNER 4 XM CHANNEL
23, // TUNER 1 XM CATEGORY
24, // TUNER 2 XM CATEGORY
25, // TUNER 3 XM CATEGORY
26, // 25 TUNER 4 XM CATEGORY
27, // TUNER 1 XM STATION
28, // TUNER 2 XM STATION
29, // TUNER 3 XM STATION
30, // TUNER 4 XM STATION
31, // 30 TUNER 1 XM SONG
32, // TUNER 2 XM SONG
33, // TUNER 3 XM SONG
34, // TUNER 4 XM SONG
35, // TUNER 1 XM ARTIST
36, // 35 TUNER 2 XM ARTIST
37, // TUNER 3 XM ARTIST
38 // TUNER 4 XM ARTIST
//Sonance : iPort
INTEGER nCHAN_BTN[] = // CHANNEL BUTTONS ON TOUCH PANEL
1, //Play
2, //Stop
3, //Pause
4, //Next Track
5, //Previous Track
6, //Scan Forward
7, //Scan Reverse
8, //Stop scanning
9, //Menu
10,
11, //Selection 1
12, //Selection 2
13, //Selection 3
14, //Selection 4
15, //Selection 5
16, //Selection 6
17,
18,
19,
20, //Previous Single Display
21, //Next Single Display
22, //Previous Page Display
23, //Next Page Display
24,
25,
26,
27,
28,
29,
30, //Repeat Off
31, //Repeat One Track
32, //Repeat All
33, //Random Off
34, //Random Songs
35, //Random Albums
36, //Play feedback
37, //Stop Feedback
38, //Pause Feedback
39, //Connect
40 //Disconnect
INTEGER nTXT_BTN[] = // TEXT BUTTONS ON TOUCH PANEL
1
VOLATILE INTEGER nLVL_BTN[] = // LEVEL BUTTONS
1
//Touch Panels Arrarys
DEV System_Panel[]= {dvPanel_1a}
DEV TuneSuite_Panel[]= {dvPanel_1b}
DEV IPod_Panel[]= {dvPanel_1c}
DEV CD_Panel[]= {dvPanel_1d}
DEV Cable_Panel[]= {dvPanel_1e}
DEV DVD_Panel[]= {dvPanel_1f}
DEV vdvADA_ARRAY[] = {vdvADA_BUS, vdvTuner1}
//DEV vdvADA_TuneSuite_Array[] = {vdvADA_BUS, vdvTuner1}
DEV vdvTUNER_ARRAY[] = {vdvTUNER1, vdvTUNER2, vdvTUNER3, vdvTUNER4}
DEV dvKeypads[]= {vdvKeypad_1,vdvKeypad_2,vdvKeypad_3,vdvKeypad_4,vdvKeypad_5,vdvKeypad_6,vdvKeypad_7,vdvKeypad_8,vdvKeypad_9}
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
//System : Touch Panel Feedback
([dvPanel_1a,nRoom_Buttons[1]] .. [dvPanel_1a,nRoom_Buttons[9]]) ///Room feedback control for panel 1
//System : MSP8 Keypad Feedback
([vdvKeypad_1,nKeypad_Source_Buttons[1]] .. [vdvKeypad_1,nKeypad_Source_Buttons[4]], [vdvKeypad_1,nKeypad_Power_Buttons[1]])
([vdvKeypad_2,nKeypad_Source_Buttons[1]] .. [vdvKeypad_2,nKeypad_Source_Buttons[4]], [vdvKeypad_2,nKeypad_Power_Buttons[1]])
([vdvKeypad_3,nKeypad_Source_Buttons[1]] .. [vdvKeypad_3,nKeypad_Source_Buttons[4]], [vdvKeypad_3,nKeypad_Power_Buttons[1]])
([vdvKeypad_4,nKeypad_Source_Buttons[1]] .. [vdvKeypad_4,nKeypad_Source_Buttons[4]], [vdvKeypad_4,nKeypad_Power_Buttons[1]])
([vdvKeypad_5,nKeypad_Source_Buttons[1]] .. [vdvKeypad_5,nKeypad_Source_Buttons[4]], [vdvKeypad_5,nKeypad_Power_Buttons[1]])
([vdvKeypad_6,nKeypad_Source_Buttons[1]] .. [vdvKeypad_6,nKeypad_Source_Buttons[4]], [vdvKeypad_6,nKeypad_Power_Buttons[1]])
([vdvKeypad_7,nKeypad_Source_Buttons[1]] .. [vdvKeypad_7,nKeypad_Source_Buttons[4]], [vdvKeypad_7,nKeypad_Power_Buttons[1]])
([vdvKeypad_8,nKeypad_Source_Buttons[1]] .. [vdvKeypad_8,nKeypad_Source_Buttons[4]], [vdvKeypad_8,nKeypad_Power_Buttons[1]])
([vdvKeypad_9,nKeypad_Source_Buttons[1]] .. [vdvKeypad_9,nKeypad_Source_Buttons[4]], [vdvKeypad_9,nKeypad_Power_Buttons[1]])
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
//Debug
Define_Function debug (Char strMsg[])
send_string 0,"'WH Control: ',strMsg"
//System Calls : Tv - On; Off; Source Switch
DEFINE_CALL 'Sun Room TV On'
debug("'Running SunRoom Tv Power On!'")
PULSE[dvSunRoom_TV,27]
PULSE[dvSunRoom_Dvd,27]
IF([dvSunRoom_IO,2] = 1) {PULSE[dvSunRoom_Cable,9]}
nTv_Power[nRoom_Index[nPanel_Index]] = 1
WAIT 20 {Call 'Sun Room TV Source'}
DEFINE_CALL 'Sun Room TV Source'
debug("'Running SunRoom Tv Source Selection!'")
SWITCH(Rooms[nRoom_Index[nPanel_Index]].Cur_Source)
CASE 12: {PULSE[dvSunRoom_TV,91] Break} /// Cable
CASE 13: {PULSE[dvSunRoom_TV,92] Break} /// Dvd
DEFINE_CALL 'Sun Room Tv Off'
debug("'Running SunRoom Tv Power Off!'")
PULSE[dvSunRoom_TV,28]
PULSE[dvSunRoom_Dvd,28]
IF(![dvSunRoom_IO,2] = 1) {PULSE[dvSunRoom_Cable,9]}
nTv_Power[nRoom_Index[nPanel_Index]] = 0
//System Calls : System Keypad Entry
DEFINE_CALL 'Direct Channel Entry'
nNumber1 = ATOI(Left_String(strKPValue,1))
nNumber2 = ATOI(Mid_String(strKPValue,2,1))
nNumber3 = ATOI(Right_String(strKPValue,1))
IF(nNumber1 = 0 and nNumber2 = 0)
//send_command vdvTUNER2,"'TUNE=',ITOA(nNumber3)"
send_command vdvTUNER_ARRAY,"'TUNE=',ITOA(nNumber3)"
ELSE IF(nNumber1 = 0)
//send_command vdvTUNER2,"'TUNE=',ITOA(nNumber2),ITOA(nNumber3)"
send_command vdvTUNER_ARRAY,"'TUNE=',ITOA(nNumber2),ITOA(nNumber3)"
ELSE
//send_command vdvTUNER2,"'TUNE=',ITOA(nNumber1),ITOA(nNumber2),ITOA(nNumber3)"
send_command vdvTUNER_ARRAY,"'TUNE=',ITOA(nNumber1),ITOA(nNumber2),ITOA(nNumber3)"
WAIT 25
strKPValue = ''
nNumber1 = 0
nNumber2 = 0
nNumber3 = 0
DEFINE_CALL 'System Keypad Entry'
Select
ACTIVE(LENGTH_STRING(strKP) = 1):
strKP = "'00',strKP"
ACTIVE(LENGTH_STRING(strKP) = 2):
strKP = "'0',strKP"
nNumber1a = ATOI(Left_String(strKP,1))
nNumber2a = ATOI(Mid_String(strKP,2,1))
nNumber3a = ATOI(Right_String(strKP,1))
PULSE[dvSunRoom_Cable,nNumber1a + 10]
Wait 4
PULSE[dvSunRoom_Cable,nNumber2a + 10]
Wait 8
PULSE[dvSunRoom_Cable,nNumber3a + 10]
WAIT 25
strKP = ''
nNumber1a = 0
nNumber2a = 0
nNumber3a = 0
(* STARTUP CODE GOES BELOW *)
//System : Set Startup Defualts
strZn_Pwr = 'FFFFFFFFFFFFFFFF'
Set_Pulse_Time (2)
//System : Buffer Creation
CREATE_BUFFER System_Panel,strTP_Buffer
//System : Set Room Index's
nRoom_Index[1] = 1
nRoom_Index[2] = 2
nRoom_Index[3] = 3
nRoom_Index[4] = 4
nRoom_Index[5] = 5
nRoom_Index[6] = 6
nRoom_Index[7] = 7
nRoom_Index[8] = 8
nRoom_Index[9] = 9
//System : Module Definitions
//ADA : Suite 16 Digital Switcher
NL_NO_BUTTON = NX_NO_BUTTON // NO BUTTON DEFINITION
Define_Module 'ADA_Bus_Comm' ADA_BUS_Comm (vdvAda_array,dvADA_PORT)
Define_Module 'ADA_STE16_DIGI_COMM' Suite16_Com (vdvADA_BUS,vdvADA_Suite16)
Define_Module 'ADA_STE16_DIGI_UI' UI1(dvPanel_1a,vdvADA_Suite16 ,ADA_BUTTONS,NL_NO_BUTTON,nRoom_Index[1])
//ADA : TuneSuite Tuner
Define_Module 'ADA_Tune_Suite_Comm' Tune_Suite_Comm (vdvADA_BUS,vdvTuner_Array,nTune_Suite_Baud,cTune_Suite_Addr)
Define_Module 'ADA_Tune_Suite_UI' Tune_Suite_UI (dvPanel_1b,vdvTuner_Array,TP_TuneSuite_BUTTONS,TP_TuneSuite_FIELDS)
//Sonance : iPort iDock
Define_Module 'Sonance_iPort_Comm_dr1_0_0' DuetCode(vdvIPod,dvIPod)
Define_Module 'Sonance_iPort_UI' TP1(vdvIPod,dvPanel_1c,nChan_Btn,nTxt_Btn,nLvl_Btn)
//MSP8 : Keypads
Define_Module 'MSPMod' modMSP1 (vdvKeypad_1, dvKeypad_1)
Define_Module 'MSPMod' modMSP2 (vdvKeypad_2, dvKeypad_2)
Define_Module 'MSPMod' modMSP3 (vdvKeypad_3, dvKeypad_3)
Define_Module 'MSPMod' modMSP4 (vdvKeypad_4, dvKeypad_4)
Define_Module 'MSPMod' modMSP5 (vdvKeypad_5, dvKeypad_5)
Define_Module 'MSPMod' modMSP6 (vdvKeypad_6, dvKeypad_6)
Define_Module 'MSPMod' modMSP7 (vdvKeypad_7, dvKeypad_7)
Define_Module 'MSPMod' modMSP8 (vdvKeypad_8, dvKeypad_8)
Define_Module 'MSPMod' modMSP9 (vdvKeypad_9, dvKeypad_9)
(* THE EVENTS GO BELOW *)
//System : Room Data Population
DATA_EVENT[0:1:0]
ONLINE:
//Room 1 : Living Room
Rooms[1].Index = 1
Rooms[1].Name = 'Living Room'
Rooms[1].Audio_Stat = 1
Rooms[1].Video_Stat = 0
Rooms[1].Lighting = 0
Rooms[1].Cur_Source = 0
//Room 2 : Sun Room
Rooms[2].Index = 2
Rooms[2].Name = 'Sun Room'
Rooms[2].Audio_Stat = 1
Rooms[2].Video_Stat = 1
Rooms[2].Lighting = 0
Rooms[2].Cur_Source = 0
Rooms[2].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[2].Source_Mapping[2] = CD /// CD Input - 2
Rooms[2].Source_Mapping[3] = XM /// XM Input - 3
Rooms[2].Source_Mapping[4] = iPod /// iPod - 4
Rooms[2].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[2].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[2].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[2].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[2].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[2].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[2].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[2].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[2].Source_Mapping[13] = Dvd /// Dvd Input - 13
//Room 3 : Master Bedroom
Rooms[3].Index = 3
Rooms[3].Name = 'Master Bedroom'
Rooms[3].Audio_Stat = 1
Rooms[3].Video_Stat = 0
Rooms[3].Lighting = 0
Rooms[3].Cur_Source = 0
Rooms[3].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[3].Source_Mapping[2] = CD /// CD Input - 2
Rooms[3].Source_Mapping[3] = XM /// XM Input - 3
Rooms[3].Source_Mapping[4] = iPod /// iPod - 4
Rooms[3].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[3].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[3].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[3].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[3].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[3].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[3].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[3].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[3].Source_Mapping[13] = Dvd /// Dvd Input - 13
//Room 4 : Master Bathroom
Rooms[4].Index = 4
Rooms[4].Name = 'Master Bathroom'
Rooms[4].Audio_Stat = 1
Rooms[4].Video_Stat = 0
Rooms[4].Lighting = 0
Rooms[4].Cur_Source = 0
Rooms[4].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[4].Source_Mapping[2] = CD /// CD Input - 2
Rooms[4].Source_Mapping[3] = XM /// XM Input - 3
Rooms[4].Source_Mapping[4] = iPod /// iPod - 4
Rooms[4].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[4].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[4].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[4].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[4].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[4].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[4].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[4].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[4].Source_Mapping[13] = Dvd /// Dvd Input - 13
//Room 5 : Master Bathroom
Rooms[5].Index = 5
Rooms[5].Name = 'Guest Bedroom # 2'
Rooms[5].Audio_Stat = 1
Rooms[5].Video_Stat = 0
Rooms[5].Lighting = 0
Rooms[5].Cur_Source = 0
Rooms[5].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[5].Source_Mapping[2] = CD /// CD Input - 2
Rooms[5].Source_Mapping[3] = XM /// XM Input - 3
Rooms[5].Source_Mapping[4] = iPod /// iPod - 4
Rooms[5].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[5].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[5].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[5].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[5].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[5].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[5].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[5].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[5].Source_Mapping[13] = Dvd /// Dvd Input - 13
//Room 6 : Kitchen
Rooms[6].Index = 6
Rooms[6].Name = 'Kitchen'
Rooms[6].Audio_Stat = 1
Rooms[6].Video_Stat = 0
Rooms[6].Lighting = 0
Rooms[6].Cur_Source = 0
Rooms[6].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[6].Source_Mapping[2] = CD /// CD Input - 2
Rooms[6].Source_Mapping[3] = XM /// XM Input - 3
Rooms[6].Source_Mapping[4] = iPod /// iPod - 4
Rooms[6].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[6].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[6].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[6].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[6].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[6].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[6].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[6].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[6].Source_Mapping[13] = Dvd /// Dvd Input - 13
//Room 7 : Office
Rooms[7].Index = 7
Rooms[7].Name = 'Office'
Rooms[7].Audio_Stat = 1
Rooms[7].Video_Stat = 0
Rooms[7].Lighting = 0
Rooms[7].Cur_Source = 0
Rooms[7].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[7].Source_Mapping[2] = CD /// CD Input - 2
Rooms[7].Source_Mapping[3] = XM /// XM Input - 3
Rooms[7].Source_Mapping[4] = iPod /// iPod - 4
Rooms[7].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[7].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[7].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[7].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[7].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[7].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[7].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[7].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[7].Source_Mapping[13] = Dvd /// Dvd Input - 13
//Room 8 : Guest Bedroom # 5
Rooms[8].Index = 8
Rooms[8].Name = 'Guest Bedroom # 5'
Rooms[8].Audio_Stat = 1
Rooms[8].Video_Stat = 0
Rooms[8].Lighting = 0
Rooms[8].Cur_Source = 0
Rooms[8].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[8].Source_Mapping[2] = CD /// CD Input - 2
Rooms[8].Source_Mapping[3] = XM /// XM Input - 3
Rooms[8].Source_Mapping[4] = iPod /// iPod - 4
Rooms[8].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[8].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[8].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[8].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[8].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[8].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[8].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[8].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[8].Source_Mapping[13] = Dvd /// Dvd Input - 13
//Room 9 : Guest Bathroom # 2
Rooms[9].Index = 9
Rooms[9].Name = 'Guest Bathroom # 2'
Rooms[9].Audio_Stat = 1
Rooms[9].Video_Stat = 0
Rooms[9].Lighting = 0
Rooms[9].Cur_Source = 0
Rooms[9].Source_Mapping[1] = AM_FM /// AM / FM Input - 1
Rooms[9].Source_Mapping[2] = CD /// CD Input - 2
Rooms[9].Source_Mapping[3] = XM /// XM Input - 3
Rooms[9].Source_Mapping[4] = iPod /// iPod - 4
Rooms[9].Source_Mapping[5] = Temp_Dev /// < OPEN > - 5
Rooms[9].Source_Mapping[6] = Temp_Dev /// < OPEN > - 6
Rooms[9].Source_Mapping[7] = Temp_Dev /// < OPEN > - 7
Rooms[9].Source_Mapping[8] = Temp_Dev /// < OPEN > - 8
Rooms[9].Source_Mapping[9] = Temp_Dev /// < OPEN > - 9
Rooms[9].Source_Mapping[10] = Temp_Dev /// < OPEN > - 10
Rooms[9].Source_Mapping[11] = Temp_Dev /// Satellite Input - 11
Rooms[9].Source_Mapping[12] = Cable /// Cable Input - 12
Rooms[9].Source_Mapping[13] = Dvd /// Dvd Input - 13
//System : XM Guide Data Population
DATA_EVENT[0:1:0]
ONLINE:
//Decades (1)
XM_GUIDE[1].Index = 1
XM_GUIDE[1].Chan = '004'
XM_GUIDE[1].Name = 'The 40s'
XM_GUIDE[1].Description = 'Thirties and Forties Hits'
XM_GUIDE[1].Genre = 'Decades'
XM_GUIDE[2].Index = 2
XM_GUIDE[2].Chan = '005'
XM_GUIDE[2].Name = 'The 50s'
XM_GUIDE[2].Description = 'Fifties Hits'
XM_GUIDE[2].Genre = 'Decades'
XM_GUIDE[3].Index = 3
XM_GUIDE[3].Chan = '006'
XM_GUIDE[3].Name = 'The 60s'
XM_GUIDE[3].Description = 'Sixties Hits'
XM_GUIDE[3].Genre = 'Decades'
XM_GUIDE[4].Index = 4
XM_GUIDE[4].Chan = '007'
XM_GUIDE[4].Name = 'The 70s'
XM_GUIDE[4].Description = 'Seventies Hits'
XM_GUIDE[4].Genre = 'Decades'
XM_GUIDE[5].Index = 5
XM_GUIDE[5].Chan = '008'
XM_GUIDE[5].Name = 'The 80s'
XM_GUIDE[5].Description = 'Eighties Hits'
XM_GUIDE[5].Genre = 'Decades'
XM_GUIDE[6].Index = 6
XM_GUIDE[6].Chan = '009'
XM_GUIDE[6].Name = 'The 90s'
XM_GUIDE[6].Description = 'Ninties Hits'
XM_GUIDE[6].Genre = 'Decades'
//Country & Folk (2)
XM_GUIDE[7].Index = 7
XM_GUIDE[7].Chan = '010'
XM_GUIDE[7].Name = 'America'
XM_GUIDE[7].Description = 'Classic Country'
XM_GUIDE[7].Genre = 'Country & Folk'
XM_GUIDE[8].Index = 8
XM_GUIDE[8].Chan = '012'
XM_GUIDE[8].Name = 'X Country'
XM_GUIDE[8].Description = 'Americana'
XM_GUIDE[8].Genre = 'Country & Folk'
XM_GUIDE[9].Index = 9
XM_GUIDE[9].Chan = '013'
XM_GUIDE[9].Name = 'Willies Place'
XM_GUIDE[9].Description = 'Willie Nelsons Tradition Country'
XM_GUIDE[9].Genre = 'Country & Folk'
XM_GUIDE[10].Index = 10
XM_GUIDE[10].Chan = '014'
XM_GUIDE[10].Name = 'Bluegrass'
XM_GUIDE[10].Description = 'Bluegrass'
XM_GUIDE[10].Genre = 'Country & Folk'
XM_GUIDE[11].Index = 11
XM_GUIDE[11].Chan = '015'
XM_GUIDE[11].Name = 'The Village'
XM_GUIDE[11].Description = 'Folk'
XM_GUIDE[11].Genre = 'Country & Folk'
XM_GUIDE[12].Index = 12
XM_GUIDE[12].Chan = '016'
XM_GUIDE[12].Name = 'Highway 16'
XM_GUIDE[12].Description = 'New Country Hits'
XM_GUIDE[12].Genre = 'Country & Folk'
XM_GUIDE[13].Index = 13
XM_GUIDE[13].Chan = '017'
XM_GUIDE[13].Name = 'US Country'
XM_GUIDE[13].Description = '80s & 90s Country'
XM_GUIDE[13].Genre = 'Country & Folk'
//Pop & Hits (3)
XM_GUIDE[14].Index = 14
XM_GUIDE[14].Chan = '020'
XM_GUIDE[14].Name = 'Top 20 On 20'
XM_GUIDE[14].Description = 'Top 20 Hits'
XM_GUIDE[14].Genre = 'Pop & Hits'
XM_GUIDE[15].Index = 15
XM_GUIDE[15].Chan = '023'
XM_GUIDE[15].Name = 'The Heart'
XM_GUIDE[15].Description = 'Love Songs'
XM_GUIDE[15].Genre = 'Pop & Hits'
XM_GUIDE[16].Index = 16
XM_GUIDE[16].Chan = '025'
XM_GUIDE[16].Name = 'The Blend'
XM_GUIDE[16].Description = 'Lite Pop Hits'
XM_GUIDE[16].Genre = 'Pop & Hits'
XM_GUIDE[17].Index = 17
XM_GUIDE[17].Chan = '026'
XM_GUIDE[17].Name = 'Flight 26'
XM_GUIDE[
HI Guys,
I need to know if any of you knows, or have these keypads (MSP8 - Axlink) for sale in good condition. I have this client, and all his house has keypads everywhere. This project has around 16 years and all the keypads are almost disintegrating. I need to replace them with same or other keypad that could do the job. Suggestions welcome.
Thanks!
There are six for sale on the bay of e as I type this reply.
Thanks!
