Set_outdoor_temperature
I think there is a major issue with the SET_OUTDOOR_TEMPERATURE function in NetLinx. No matter how hard I try, I can not modify the outdoor temperature using this function.
Currently it is 74 degrees outside, I want it to be more like 72, I use this function and it stays 74. I even walked my NI3100 outside to see if that would work! Any ideas?
BUTTON_EVENT[TP,1]
SET_OUTDOOR_TEMPERATURE(72);
"At this time, only the PLK-DMS takes advantage of the outdoor temperature."
so you probably need one of those to make it work. I guess you would have to install it outside.
It also says in the PLK-DMS blurb
"Includes built-in temperature sensor"
Now that's a bit weird. I guess there could be a lag between setting the temp and having the world catch up so the sensor would tell you how much progress you had made.
BTW 72 seems a little warm, 25 was just right here yesterday. Oh hang on, the help says
"It is up to the programmer to provide the correct temperature scale"
so that's OK.
What happens if the guy next door sets a different temp?
Do you have anything to do with this Global Warming? Stop playing around with the Outdoor Temp!
Call 'Get_CO2_Levels' IF(CO2_levels_temp>CO2_Levels_Current){ SET_OUTDOOR_TEMPERATURE (Current_Outdoor_Temperature+1) CO2_Levels_Current=CO2_levels_temp }There is no parameter for location, I could be raising the temperature over the north poll and would not even know it... I could be the cause of global warming...
No single raindrop believes it is to blame for the flood.
I might be dating myself with that one a bit...
