LG M3701(LCD Display) RS-232 Protocol?
Does anyone have a .pdf they'd be willing to share?
Edit: I should check the CD that comes with the display more often
tha manual too big:
crossed cable ,9600,8,n,1
(Hexadecimal) CCOOMMMMAANNDD11 CCOOMMMMAANNDD22
15. Treble : k r 0 ~64
16. Bass : k s 0 ~64
17. Balance : k t 0 ~64
18. Color Temperature : k u 0 ~3
19. Red Adjustment k v 0 ~50
20.Green Adjustment k w 0 ~50
21. Blue Adjustment k $ 0 ~50
22. Abnormal Status k z FF
23. Channel Tuning m a GGP. 80
24. Channel Add/del m b GGP. 80
25. Key m c GGP. 80
26. Auto Configure j u 1
27. Input select (Main) x b GGP. 80
28.Input select (PIP) x y GGP. 81
DATA
(Hexadecimal)
01. Power k a 0 ~1
02.Aspect Ratio k c GGP. 78
03.Screen Mute k d 0 ~1
04.Volume Mute k e 0 ~1
05.Volume Control k f 0 ~64
06.Contrast k g 0 ~64
07. Brightness k h 0 ~64
08.Color k i 0 ~64
09.Tint k j 0 ~64
10. Sharpness k k 0 ~64
11. OSD Select k l 0 ~1
12. Remote Control 0 ~1
lock mode
13. PIP/DW/POP k n GGP. 79
14. PIP Position k q 0 ~3
k m
hope it helped the commands!!
Hey,
I have used LG plasmas and LCDs RS-232 codes for years and they have always worked and have been the same. We just got a 60PK750 in our office and I can't get it to work. I emailed and called LG tech support and can only get the IR hex commands. Anyone else having problems with these newer LG TVs?
I should also mention that the power supply died within 2 days in this TV. I hope thats not a sign of LG's performance in 2010.
