ZigBee Gateway/Repeater Antenna Replacement
in AMX Hardware
We just ordered a couple of the optional 3db ZigBee Antennas from AMX (I had someone else order) and I JUST found out about the outrageous prices AMX is charging for them. Over $400 retail for the 3db one and slightly less for th 5db one (for some odd reason the one with more range costs less).
I mean an extra ZigBee Repeater itself costs less than an antenna upgrade?
Does anyone know the lug/screw type/size of the f-connector on the ZigBee units so I can find a third-party higher gain antenna that will fit correctly? These things are available everywhere due to the proliferation of WAPs and wireless everything now-a-days.
Cheers!
Cheers!
Theoretically, you should be able to almost double the range with a $20.00 5.5db Omni Antenna.
Oh, and the connector is SMA, (thanks!), but I think its Reverse Polarity as well. So, it's a RP-SMA.
I'll let you know what I get and how it works out.
if I remember correctly my wireless communication lessons. an antenna Gain ALWAYS is in both direction. the equation was (Power of the Transmitter)*(Sender Gain)*(Transmitter Gain) or something. so you can improve the antenna just on one side. as I do, when I connect to the unsecure Wireless connection of the neighbour to use his broadband internet. I just get an Antenna with more Gain, as I cant change the neighbours antenna
Now if the antennae focuses the power more horizonatlly hows does that affect the way the antennae recevices signals from areas above or below? I would think that would be decreased as well.
http://www.marcspages.co.uk/tech/antgain.htm
