HD Radio?
TrikinCurt
Anyone know of any RS232 (or IP) HD Radios out there? The only one I know of is from ADA - which would fit the bill but I can't see becoming an ADA dealer just for a tuner!
Curt
Curt
http://integrahometheater.com/model.cfm?m=TUN-3.7&class=Tuner&p=i
I've been wanting to test this piece, but just haven't had a chance to get one.
Kevin D.
http://usa.denon.com/Denon_CI_Products_Release_-_Sept_07_-_Final.pdf
Curt
I have not had similar experiences. All of the HD simulcasts of the analog signal that I have heard sound quite compressed. They usually include quite a bit of aliasing, and typically lack the high-frequency detail and imaging of the original analog signal.
Most of the HD radio stations that I have sampled are running two HD streams. There is usually a digital simulcast of the analog HD1 as well as a completely different program on HD2. Maybe if they only had one HD stream, they would have the digital bandwidth for better quality audio.
The only time I have truly appreciated an HD radio simulcast was a jazz station I heard somewhere. In that case, the analog signal had obviously been put through very heavy multiband limiting and clipping, probably to maintain a competitive volume with other stations. The digital stream was very obviously taken from somewhere before all of that brickwall processing, thus preserving the openness of the music and lacking all of the distortions presents in the overly-processed analog signal.
"Digital Quality" is the oxymoron of the new generation.
They also have a modular tuner coming out with three card slots, that was what I was referring to. The DRA is a stereo receiver.
Curt
