Beginner code question
Would on of you guys mind giving me a code example to control a relay with a single button? My device is defined as Fountain = 5001:4:0 and I would like to use a single button one push for on and the next push for off. I would also like to have on off status for the button. Any help would be appreciated! Thanks.
  • jazzwyldjazzwyld Posts: 199
    Try this
    I believe one of these will work for ya.
    dvFountain = 5001:4:0 // Water Thingy
    dvTP = 10001:1:0 // Touch Panel Thingy
    WATER
    BUTTON_EVENT[dvTP,101] // Single button event for water fountain
    SELECT
    ACTIVE (WATER=0): // if water fountain is off turn it on
    ON[dvFountain,1]
    WATER =1 //setting variable for the toggle
    ACTIVE(WATER=1): //if water fountain is on turn it off
    OFF[dvFountain,1]
    WATER =0 // setting variable for the toggle
    BUTTON_EVENT[dvTP,101] // here's another way...just depends on what you're going for.
    [dvFountain,1]=![dvFountain,1]
    DEFINE_PROGRAM
    [DVTP,101]=[dvFountain,1]
  • Thanks Jeff for the information it really helps! Question though. In the first example what part of the code controls button feedback?
    The relay is controlling the feedback. You could make the variable WATER also, but that's not real feedback. At the DEFINE_PROGRAM. You see that the touchpanel will be on/off when the relay is on/off.
    Keep it simple.
    BUTTON_EVENT[dvTP, nFoutainButton]
        PUSH : [dvRelays, FOUNTAIN_RELAY] = ![dvRelays, FOUNTAIN_RELAY] // toggles relay state
    // In your feedback section, timeline or DEFINE_PROGRAM
    [dvTP, nFountainButton] = [dvRelays, FOUNTAIN_RELAY]
    In my example, FOUNTAIN_RELAY is a constant assigned the relay number. I'm sure the rest is self-explainitory.
    Do you use a timeline for feedback as opposed to define program?
    Usually, but if it's really basic (no send_commands, just channels and levels), I'll put in in DEFINE_PROGRAM. You absolutely do not want it in DEFINE_PROGRAM if there are any send_commands, or send_strings ... you'll bog the system down with all the spam. My normal procedure is to create a function call for feedback. I'll call it in DEFINE_PROGAM for the simple systems, but once they reach a level where that isn't feasible (my jobs all have a tendency to evolve - the company just loves selling upgrades), I'll move it to a timeline.
    I really hate even mentioning puting feedback in DEFINE_PROGRAM, because if you aren't extremely careful with it, it can and will blow up your system. It is probably a good general rule not to play fast and loose with it like I do until you are very familiar with what is happening in your system and you are absolutely positive of what you can get away with.
  • So when you're using a timeline do you just set it up repeat every 10ms or something like that? Do you create it in DEFINE_START? I've been trying to migrate more and more stuff out of define program and this is an interesting option, I'm just curious about it's implementation.
  • mpullinmpullin Posts: 949
    If you just want a function to run at regular intervals, another option is just to put it in DEFINE_PROGRAM with a wait. e.g.
    DEFINE_PROGRAM
    wait 100 fnFountainUpkeep(); // runs this function every 10 sec
    Yes, create it in DEFINE_START. Depending on the project, I set it to repeat every 500ms. 10 is kinda fast if there is a lot going on. But I also try write my UI's so that button presses and reactions update immediately, and the feedback routine is strictly for non-interactive updates. If you are pressing a button, even a half second is noticeable (though, it can be argued, still not a huge delay). But for states updated by the device, it's more than acceptable.
