BOSE Media Center AV48
Anyone with the IR file for the AV48?
It is quite troublesome to read the remote control of the Bose as it is run on RF.
Trying my luck here if any of the senior here had tried control Bose media center before using IR.
Many thanks.
  • glr-ftiglr-fti Posts: 286
    I know that I have captured the IR codes but it was for a PHAST system. If I remember correctly there are settings within the Bose that allow you to turn on IR even though you are using the RF remote. You then use an IR learner to get your codes from the Bose unit.
  • Tedious Process
    Actuallly the process is tedious. Need to turn on the IR in the bose system and do the learning. Yet the location for the installed bose system is very inconvienient to place the IR learner. Therefore i choose to ask if anyone who had the IR code here. I'm not being lazy here but just the installed system is not conv to do the learning.
    Thanks for view this thread
    Regards
