Home AMXForums Archive Threads AMX Hardware MAX by AMX
Zone is going offline
adysadys Posts: 395
On every upload and restart of the Netlinx I must restart the AVM.
if not, I am getting the "zone is offline" message :(
I tried to send "do_push" to the button that select the zone, channel code is 30.
Not working :(
What am i doing wrong?
I asked it before, but maybe some with a new solution?
This a major problem, any help will be very appriciate.
Ady.
    Check if it works in WinMax. If it does not, the problem is in the AVM itself. If it works with Winmax, make sure you have the latest module and server firmware. I had a similar issue a long time back, but with all the upgrades (changed out my MMS's for HT boxes), it went away. The thing is, I'm not entirely sure exactly what changed to resolve it.
  • adysadys Posts: 395
    Thanks Dave
    When playing from winmax its always online.
    The thing is that in some of the controllers after reboot its ok and some are not, with exactly the same code....
    I will call support to make the new firmware update, I hope it will help.
    Thanks, I will update the solution if I will found it...
    Ady.
