MVP-8400 with WDS
flcusat
I'm wondering what height do you guys use, when installing the WDS for the MVP-8400. I usually install the in-wall TPs to a height between 54" to 60" from the floor to the bottom of the panel, but I would like to here others opinion.
"Eye level" is just too hard to determine if it's used by a lot of people ... fine if the customer is single and lives alone though .
--John
Do we programmers also have to provide a braille back end?
My bank has an ATM with a Braille marked keypad, a headphone jack, and a big sign that says, "For Vehicular Use Only."
As you may know, LCD displays typically have a wider usable viewing angle from side to side vs. top to bottom. I've always felt that in most cases, the users tend to stand or hold the panel right in front of them. So, the side-to-side viewing angle doesn't need to be as wide as say a LCD TV or other display device. However, the verticle viewing angle on a touch panel is quite often quite wide. (From kids to very tall adults.)
I wish they could orient the LCD screen material in touch panels 90 degrees so that the widest viewing angle was top to bottom as apposed to side to side.
the screen material can be oriented either way. It's just optimal for most viewing devices to have the widest angle from side to side.
Well, what would be good is if you could edit the panels orientation as in "Portrait" vs "Landscape" therefore no hardware change is required purely a software solution.
