Run a win *.bat from NetLinx?
Hi together
I want to have a solution to run a batch script on my win server from NetLinx Master.
The Master is ion the same net, so access is no problem.
Perhaps PCLink is the solution, but i can't program vb....
Is there someone who know's a solution?
thanks a lot
john
  • You can use the PCLink-Web solution for this. Pretty easy to install and to use.
    Regards,
    Regards,
    Hi Marc
    Thanks, i will try it!
    so long
    John
