Universal IR Learner ? Know Engo Product ?
Hi,
I just discovered that product that looks very interesting when you work both on AMX and C* systems. Would someone have already used it ? and know if it works well ?
http://engo.com/productdetail.aspx?p=1001
Vinc
  • ekeppelekeppel Posts: 37
    An old black and white Philips Pronto remote works well also. You can get one on eBay for around $50 (or maybe even less now). Just download the ProntoEdit software and you're good to go. It's a bit slower to use, since you have to cut and paste the actual HEX code instead of learning it directly into IREdit, but I have used them in a pinch when I didn't have an IRIS with me.
    --Eric
  • yuriyuri Posts: 861
    looks very nice.
    The option to use it for AMX and ******** is very nice, so i don't have to carry 2 units with me all the time...
  • vincenvincen Posts: 526
    Thanks for the tip Eric but I'm looking for a simple and quick way to do :)
  • nickmnickm Posts: 152
    There's a software program out there called Vert. I believe it is available from RemoteCentral. Anyway, it very conveniently and successfully converts AMX ir files to the other guys and vice-versa. This is very handy if you work on both and only have one type of IR learner.
    again, nice :D
  • sling100sling100 Posts: 123
    I've just bought one so I'll let you know how I get on. The IRIS I've got is just huge and you need external PSU etc etc so I'm quite excited by this little thing.
    Simon
    Yes please :) thanks :D
  • Engo unit
    I picked one up about 2 years ago. It is great having one box for two systems but it does not work very fast with the edit software from AMX.
  • GSLogicGSLogic Posts: 562
    How much more time does it take?
    Have you had any issues with capturing IRs?
    Simon
    Did you ever get your IR learner?
    If so, how is it working?
  • SensivaSensiva Posts: 211
    Thoug it is RS232
    Global Cache IRLearner is more smaller, and cheaper 120USD
    http://www.globalcache.com/products/ir-index.html
    but Engo has a pretty much advantages, IRL integrated, ability to test learned IR codes, no need for RS232 adapter if using RS232less notebooks :)
  • dthorsondthorson Posts: 103
    The Vert application works nicely.
    But now only works from AMX to C**** not the other way around.
    Since system builder, they added some extra info to the .ir files that breaks the AMX outputted file.
