Universal IR Learner ? Know Engo Product ?
vincen
Hi,
I just discovered that product that looks very interesting when you work both on AMX and C* systems. Would someone have already used it ? and know if it works well ?
http://engo.com/productdetail.aspx?p=1001
Vinc
Vinc
--Eric
The option to use it for AMX and ******** is very nice, so i don't have to carry 2 units with me all the time...
Thanks for the tip Eric but I'm looking for a simple and quick way to do
again, nice
Simon
Yes please thanks
I picked one up about 2 years ago. It is great having one box for two systems but it does not work very fast with the edit software from AMX.
Have you had any issues with capturing IRs?
If so, how is it working?
Global Cache IRLearner is more smaller, and cheaper 120USD
http://www.globalcache.com/products/ir-index.html
but Engo has a pretty much advantages, IRL integrated, ability to test learned IR codes, no need for RS232 adapter if using RS232less notebooks
But now only works from AMX to C**** not the other way around.
Since system builder, they added some extra info to the .ir files that breaks the AMX outputted file.
