New Precis Code
Anyone tried it yet, I see it was just updated. Wondering if it is good enough to stop working on my own homebrewed version yet...
On a seperate note, some features I would like to see added to the module:
Doorbell/paging support. This should be a command that switches all outputs marked for Paging/Doorbell to the designated input at a predetermined vol level. Then another command that reverts to the original status/vol of each output.
Support for the DSP and preferably 3 or so preset DSP configurations.
Stable support for grouping of zones to allow relative volume raising and input switching via a single virtual zone. (also DSP settings)
I think that ends my list of suggestions. Keep in mind that my opinions are based on working with the PRECIS LT unit.
P.S.
I have the first two almost completely functional, it's just a little messier than I like right now. The last one, I vaguely recall running into problems in having the precis LT work the way I interpreted the BCS commands should function.
SEND_STRING dvSwitch,"'DL2O1T'" //Disconnect
SEND_STRING dvSwitch,"'CL2I1O1T'" //Connect
SEND_STRING dvSwitch,"'CL2O1VS+T'" //Vol Up
SEND_STRING dvSwitch,"'CL2O1VS-T'" //Vol Dn
SEND_STRING dvSwitch,"'CL2O1VMT'" //Mute
SEND_STRING dvSwitch,"'CL2O1VUT'" //Mute Off
My problem is implementing the DATA_EVENT to work for the volume and gain.
How are you guys capturing the volumes from the PrecisLT and connecting them to bargraphs in a touch panel?
Do you query for all volumes at startup? How are you handling the DB ranges?
Can the PrecisLT w/DSP handle simultaneous volume ramping on different zones?
Since this piece will be mostly used in a Whole House Audio, I think AMX should create a specific module to support the DSP functions as well multiple TPs. Should I consider something else Vaux, ADA or knox? Any help on the volume feedback will be very appreciated.
Sincerely,
Ricardo
Ricardo
Greetings to the AutoPatch Group. You should monitor this forum. There are great questions here, and now since you are under the AMX roof, We (the users, installers, designers, programmers and salesmen) want more then just a great performing product. We need a great product from an integration standpoint.
Oh yeah, any chance you can increase the speed of the RS-232 on Precis Products? Its to easy to flood the port when ramping the volume. Thanks
One thing extremely lacking in this module is the ability to control and see feedback for bass and treble control. Does anyone have any complete working module or demo programming for the Precis w/ DSP that they would like to share?
Why wait to know what the volume is? To me, a generic volume +/- command is basically saying, "device, will you please increase your volume for me, and when you're finished also tell me what volume you're at?" C'mon guys, we're in the CONTROL business; control the thing, and TELL it what volume to go to. This eliminates you "waiting and wondering" what the volume is.
Now, if the device doesn't allow you to do that, and isn't reliable enough to accept a bombardment of discrete volume commands, then it's not worth controlling. I've been using a code block I received from a friend about a year ago that's controlling the Precis - and let me tell you - it's perfect. I've never run into a problem with it. I'm actually very surprised there are problems with the module.
Well and good until someone walks up to the device and turns the volume to 80%, and you panels says it's still at 30%. Your point is valid if you are the only one controlling it, but that is not always the case, and for those exceptions, you need to have real feedback.
I dunno - I guess real feedback on volume should only as a back up IMHO. I guess it just boils down to style and how you want the system to work.
I always assume that the user will operate by its front panel anything that can be reached. Who are we to tell them not to? Do we expect them to RTFM? I certainly don't.
This means, for instance, that you can assume nothing about the state of IR controlled gear.
Most serial controlled gear will give you state change feedback so you can just change it back if you really want to!
I also never tell a customer, "do it the way I told you, or it won't work right." I consider it my job to accommodate them, not the other way around. If they want to poke at the front panel manually, it's their business ... and when that happens, I need real feedback.
Don't get me wrong: I'm not trying to come down on anyone else's way of doing things; I'm just offering another point of view. Take it or leave it, whatever works for you and your company is what works for you.
jjames wrote: It is the preferred method of control to have the controlled device respond with its state and not simply assume our command have been acted upon becasue we said so. That is what seperates us from the crowd.
The Precise w/ DSP has no problem responding fast enough for almost instant volume feedback and my feedback bargraph are pretty smooth. The problem I think most people have is when they try to increment or decrement the volume cuz you then have to poll or query the level but why do that when you can send absolute levels. Increment and decrement in you code and send that as an absolute value and the Precis will respond (echo) that value in its response immediately. No waiting, no querying, no polling. It works great!
I maintain mini bargraphs for each output as well as a larger bargraph for my currently selected and they all update fine using this method.
That's a cool interface Vining.
I would love to be able to set the EQ from an 8400 instead of dealing with a laptop and 232 direct to the matrix and I really don't have to time to write the module from scratch (I wish I could give back to the community more, but I'm only a newb programmer with a limited amount of time).
Thanks.
I've never experienced that problem. The way the code I use works is that it doesn't send another command out until the response has a "T". Use a busy flag or a timed wait to send out the commands, then whenever you see the "T" come in from the device, turn off the flag or cancel the wait and send the next command.
