been awhile
i remember having this issue before. when i go to load it says cannot find .src file. I'm using the latest netlinx and have a ni-2000. my source file is .axs can i just change it to .src? it's set as netlinx master file.
  • yuriyuri Posts: 861
    did you compile it? ;)
  • oh yea, build active system, compile i've tried em all and it compiles, my changes are made, but it gives me that error and i dunno why
  • it says sending empty.src
    It just means you have not checked the option to "Build With Source" in the "Netlinx Compiler" tab under Preferences so there is no source code to download, it will only download the compiled code.
    HTH
  • ah yes, that is definitely it. thank you so much.
