NI-700 dead before it?s time?
in AMX Hardware
Do I assume my NI-700 has been murdered if the status, output, and input LEDs are solid on? Is there anyway to revive it? I can?t ping it, telnet, or anything, not even a serial connection. I can?t believe the dang thing is dead already.
Any suggestions?
Man I sure picked the wrong time to quit smoking (day 3). I?m already plenty on edge and now I want to toss this dang NI-700 through the window.
ARGH!
Any suggestions?
ARGH!
We've had the odd MVP-8400 with dead flash/corrupt file system, but I'm pretty sure these were DOA.
I can't see anything in the NI-700 manual relating to status light error codes, but I always seem to miss the bits I'm looking for in AMX manuals. A search for "light" in the AMX technotes turned up the following gems:
http://www.amx.com/techsupport/techNote.asp?id=444
and somewhat interestingly:
http://www.amx.com/techsupport/techNote.asp?id=290
EDIT:
Check out http://www.amxforums.com/showthread.php?t=3193 (specifically first and second last posts).
EDITEDIT:
Found the front panel blink patterns I was looking for in the NetLinx NI-x100 Hardware Reference Manual:
Modes and LED Blink Patterns
STATUS - OUTPUT - INPUT = (green - red - yellow)
OS Start - Starting the operating system (OS). On On On
Boot - On-board Master is booting. On Off On
Contacting DHCP server. On Off Fast Blink
Unknown DHCP server. Fast Blink Off Off
Downloading Boot firmware. Fast Blink Fast Blink Fast Blink
No program running On Normal Normal
So it does look like corrupt/dead compact flash could well be at fault as the OS can't start...
This problem we have every 6 months. (Last week, we had 2 dead NI700!!!!)
If all LEDs are still on - the NI700 is deffently dead and can only fixed by AMX.
We think, that there is a problem with the "onboard-flash" on the NI700.
Unfortunately we newer get an answer from AMX, why the NI700 while normaly operating suddenly dies.
We were able to observe that there are more problems with the NI700, where they are often unplugged from power.
We hope, that AMX can find the reason and can fix it asap!
Is the anyone with the same experience like me???
Greetings from swizzerland :-)
