I know this is a very old post, but did you, or someone else for that matter, ever find out if this is possible?
The reason I ask is that I would like to do the same, but can?t see how I can do it from the telnet commands available, which off cause may just tell me the obvious in that it isn?t possible!
Is there a command available to emulate the push of a touch panel button via Telnet?
Joe
I suppose failing that you could write your own telnet like routine to get the job done. You'd have to pick a different port number but most telnet programs allow you to choose any port you like. But, then again, using something like Netlinx Diagnostics would do the job very well.
Joe,
J
I hacked this out of my environment so you will have to do some work to get it to compile.
Sorry about the ghastly tabbing, it looks fine in my editor!
That's perfect ? this is exactly what I need!
Jesper
