Here is a module I made that works out of box to control that equipment Be very careful about something, if you send a new command when tuner is still processing a previous command, you'll crash it and only way to get it back to life is to unplug power on it
Hope it helps
Vinc?n
MODULE_NAME='Tuner' (dev dvTuner, dev dvTP)
(* FILE CREATED ON: 05/01/2007 AT: 17:02:10 *)
(* FILE_LAST_MODIFIED_ON: 10/18/2007 AT: 19:37:50 *)
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
dvMaster = 0:1:0
(* VARIABLE DEFINITIONS GO BELOW *)
CONSTANT INTEGER INTERRO = 1 // Timeline number
LONG TEMPO[1] = 1000 // 1 s
INTEGER FREQUENCY
INTEGER PRESET
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
([dvTP,3],[dvTP,4]) // Stereo/Mono Buttons
([dvTP,7],[dvTP,8]) // AM/FM Buttons
([dvTP,18]..[dvTP,23]) // Presets Buttons
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
(* THE EVENTS GO BELOW *)
DATA_EVENT[dvTuner] // Init of RS-232 port
ONLINE:
SEND_COMMAND DATA.DEVICE,'SET BAUD 9600,N,8,1 485 DISABLE'
SEND_STRING DATA.DEVICE,"'00_10_01_02',$D" // Put Tuner on at startup
TIMELINE_CREATE(INTERRO,TEMPO,1,TIMELINE_ABSOLUTE,TIMELINE_REPEAT)
STRING:
IF (FIND_STRING(DATA.TEXT,'AM',1)) // AM Mode
ON[dvTP,8]
IF (FIND_STRING(DATA.TEXT,'FM',1)) // FM Mode
ON[dvTP,7]
IF (FIND_STRING(DATA.TEXT,'MONO',1)) // Mono Mode
ON[dvTP,4]
IF (FIND_STRING(DATA.TEXT,'STEREO',1)) // Stereo Mode
ON[dvTP,3]
IF (FIND_STRING(DATA.TEXT,'FREQ',1)) // Frequency of current station
FREQUENCY = ATOI(MID_STRING(DATA.TEXT,FIND_STRING(DATA.TEXT,'FREQ',1),15))
IF ([dvTP,7]) // We are in FM so we need dot ;)
SEND_COMMAND dvTP,"'TEXT1-',ITOA(FREQUENCY/100),'.',ITOA(FREQUENCY MOD 100)"
ELSE IF ([dvTP,8]) // We are in AM so no dot
SEND_COMMAND dvTP,"'TEXT1-',ITOA(FREQUENCY)"
IF (FIND_STRING(DATA.TEXT,'PRESET',1)) // Active Preset
PRESET = ATOI(MID_STRING(DATA.TEXT,FIND_STRING(DATA.TEXT,'PRESET',1),11))
IF (PRESET)
ON[dvTP,PRESET + 17]
ELSE
TOTAL_OFF[dvTP,18] TOTAL_OFF[dvTP,19] TOTAL_OFF[dVTP,20] TOTAL_OFF[dvTP,21] TOTAL_OFF[dvTP,22] TOTAL_OFF[dvTP,23]
TIMELINE_EVENT[INTERRO]
SEND_STRING dvTuner,"'00_10_11_05',$D" // Request Status of Tuner
BUTTON_EVENT[dvTP,0]
CANCEL_WAIT 'TIMELINE'
TIMELINE_PAUSE(INTERRO)
SWITCH(BUTTON.INPUT.CHANNEL)
CASE 10:
WAIT 5
SEND_STRING dvTuner,"'00_10_9_1',$D" // Auto-tune up frequency Seek +
CASE 11:
WAIT 5
SEND_STRING dvTuner,"'00_10_9_2',$D" // Auto-tune up frequency Seek -
CASE 12:
WAIT 5
SEND_STRING dvTuner,"'00_10_9_3',$D" // Step +
CASE 13:
WAIT 5
SEND_STRING dvTuner,"'00_10_9_4',$D" // Step -
CASE 16:
WAIT 5
SEND_STRING dvTuner,"'00_10_2_3',$D" // Change Band
CASE 18:
WAIT 5
SEND_STRING dvTuner,"'00_10_3_1',$D" // Preset 1010 Wins
CASE 19:
WAIT 5
SEND_STRING dvTuner,"'00_10_3_2',$D" // Preset AM 820
CASE 20:
WAIT 5
SEND_STRING dvTuner,"'00_10_3_3',$D" // Preset Jazz 99
CASE 21:
WAIT 5
SEND_STRING dvTuner,"'00_10_3_4',$D" // Preset WFAS 103.9
CASE 22:
WAIT 5
SEND_STRING dvTuner,"'00_10_3_5',$D" // Preset WNYC 93.9
CASE 23:
WAIT 5
SEND_STRING dvTuner,"'00_10_3_6',$D" // Preset WQXR 96.3
WAIT 20 'TIMELINE'
TIMELINE_RESTART(INTERRO)
(* END OF PROGRAM *)
(* DO NOT PUT ANY CODE BELOW THIS COMMENT *)
Could some one tell me how to properly channel map this Module? I
I did that module in a hurry for a job, so I did not take time to get channels mapped in a DEVCHAN so you'll need to either use same channels than me or add a devchan in program, remove dvTP reference
Hope it helps
Vinc?n
MODULE_NAME='Tuner' (dev dvTuner, dev dvTP) (***********************************************************) (* FILE CREATED ON: 05/01/2007 AT: 17:02:10 *) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 10/18/2007 AT: 19:37:50 *) (***********************************************************) (***********************************************************) (* DEVICE NUMBER DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_DEVICE dvMaster = 0:1:0 (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE CONSTANT INTEGER INTERRO = 1 // Timeline number LONG TEMPO[1] = 1000 // 1 s INTEGER FREQUENCY INTEGER PRESET (***********************************************************) (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_MUTUALLY_EXCLUSIVE ([dvTP,3],[dvTP,4]) // Stereo/Mono Buttons ([dvTP,7],[dvTP,8]) // AM/FM Buttons ([dvTP,18]..[dvTP,23]) // Presets Buttons (***********************************************************) (* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *) (***********************************************************) (***********************************************************) (* THE EVENTS GO BELOW *) (***********************************************************) DEFINE_EVENT DATA_EVENT[dvTuner] // Init of RS-232 port { ONLINE: { SEND_COMMAND DATA.DEVICE,'SET BAUD 9600,N,8,1 485 DISABLE' SEND_STRING DATA.DEVICE,"'00_10_01_02',$D" // Put Tuner on at startup TIMELINE_CREATE(INTERRO,TEMPO,1,TIMELINE_ABSOLUTE,TIMELINE_REPEAT) } STRING: { IF (FIND_STRING(DATA.TEXT,'AM',1)) // AM Mode { ON[dvTP,8] } IF (FIND_STRING(DATA.TEXT,'FM',1)) // FM Mode { ON[dvTP,7] } IF (FIND_STRING(DATA.TEXT,'MONO',1)) // Mono Mode { ON[dvTP,4] } IF (FIND_STRING(DATA.TEXT,'STEREO',1)) // Stereo Mode { ON[dvTP,3] } IF (FIND_STRING(DATA.TEXT,'FREQ',1)) // Frequency of current station { FREQUENCY = ATOI(MID_STRING(DATA.TEXT,FIND_STRING(DATA.TEXT,'FREQ',1),15)) IF ([dvTP,7]) // We are in FM so we need dot ;) { SEND_COMMAND dvTP,"'TEXT1-',ITOA(FREQUENCY/100),'.',ITOA(FREQUENCY MOD 100)" } ELSE IF ([dvTP,8]) // We are in AM so no dot { SEND_COMMAND dvTP,"'TEXT1-',ITOA(FREQUENCY)" } } IF (FIND_STRING(DATA.TEXT,'PRESET',1)) // Active Preset { PRESET = ATOI(MID_STRING(DATA.TEXT,FIND_STRING(DATA.TEXT,'PRESET',1),11)) IF (PRESET) { ON[dvTP,PRESET + 17] } ELSE { TOTAL_OFF[dvTP,18] TOTAL_OFF[dvTP,19] TOTAL_OFF[dVTP,20] TOTAL_OFF[dvTP,21] TOTAL_OFF[dvTP,22] TOTAL_OFF[dvTP,23] } } } } TIMELINE_EVENT[INTERRO] { SEND_STRING dvTuner,"'00_10_11_05',$D" // Request Status of Tuner } BUTTON_EVENT[dvTP,0] { PUSH: { CANCEL_WAIT 'TIMELINE' TIMELINE_PAUSE(INTERRO) SWITCH(BUTTON.INPUT.CHANNEL) { CASE 10: { WAIT 5 { SEND_STRING dvTuner,"'00_10_9_1',$D" // Auto-tune up frequency Seek + } } CASE 11: { WAIT 5 { SEND_STRING dvTuner,"'00_10_9_2',$D" // Auto-tune up frequency Seek - } } CASE 12: { WAIT 5 { SEND_STRING dvTuner,"'00_10_9_3',$D" // Step + } } CASE 13: { WAIT 5 { SEND_STRING dvTuner,"'00_10_9_4',$D" // Step - } } CASE 16: { WAIT 5 { SEND_STRING dvTuner,"'00_10_2_3',$D" // Change Band } } CASE 18: { WAIT 5 { SEND_STRING dvTuner,"'00_10_3_1',$D" // Preset 1010 Wins } } CASE 19: { WAIT 5 { SEND_STRING dvTuner,"'00_10_3_2',$D" // Preset AM 820 } } CASE 20: { WAIT 5 { SEND_STRING dvTuner,"'00_10_3_3',$D" // Preset Jazz 99 } } CASE 21: { WAIT 5 { SEND_STRING dvTuner,"'00_10_3_4',$D" // Preset WFAS 103.9 } } CASE 22: { WAIT 5 { SEND_STRING dvTuner,"'00_10_3_5',$D" // Preset WNYC 93.9 } } CASE 23: { WAIT 5 { SEND_STRING dvTuner,"'00_10_3_6',$D" // Preset WQXR 96.3 } } } WAIT 20 'TIMELINE' { TIMELINE_RESTART(INTERRO) } } } (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)I did that module in a hurry for a job, so I did not take time to get channels mapped in a DEVCHAN so you'll need to either use same channels than me or add a devchan in program, remove dvTP reference
Vinc
http://modulemarketplace.com/index.php?l=product_detail&p=20 it
