Sorting text alphabetically
Has anyone a good (fast) function for sorting text (min. 100 names) alphabetically?
  • maxifoxmaxifox Posts: 209
    I have not that ready but how about shellsort algorithm?
    http://www.iti.fh-flensburg.de/lang/algorithmen/sortieren/shell/shellen.htm
  • The shellsort algorithm is a good choice. But much better would be a ready to use source code... ;-)
    Bubble Sort
    Here is a Bubble Sort routine. I?m sure there are faster sorts but this is the only one I?ve ever learned to write and it?s been fast enough for my purposes. Perhaps it will be fast enough for you.
    The sort function will alphabetize by last name and then by first name.
    dvTP	= 10001:1:0
    DEFINE_CONSTANT
    INTEGER nMaxProfiles	= 5
    DEFINE_TYPE
    STRUCTURE _sProfile {
       INTEGER 	ID
       CHAR		LastName[32]
       CHAR		FirstName[32]
    _sProfile 	sProfiles[nMaxProfiles]
    DEFINE_FUNCTION fnInitPofiles() {
    sProfiles[1].ID	= 1
    sProfiles[1].FirstName= 'John'
    sProfiles[1].LastName	= 'Doe'
    sProfiles[2].ID	= 2
    sProfiles[2].FirstName= 'Jane'
    sProfiles[2].LastName	= 'Doe'
    sProfiles[3].ID	= 3
    sProfiles[3].FirstName= 'Joe'
    sProfiles[3].LastName	= 'Crow'
    sProfiles[4].ID	= 4
    sProfiles[4].FirstName= 'Bullwinkle '
    sProfiles[4].LastName	= 'Moose'
    sProfiles[5].ID	= 5
    sProfiles[5].FirstName= 'Garfield'
    sProfiles[5].LastName	= 'Goose'
    DEFINE_FUNCTION fnSortByLastName() {
       INTEGER 	x
       INTEGER 	y
       INTEGER 	tempID
       CHAR		tempLastName[32]
       CHAR		tempFirstName[32]
       //bubble sort
       //bubble up the smaller names (alphabetically) by pushing the bigger names down
       FOR (x=1; x<nMaxProfiles; x++) {
          FOR (y=1; y<nMaxProfiles; y++) {
    	 //if position y > position y+ 1 then swap
    	 IF ("sProfiles[y].LastName,sProfiles[y].FirstName" >
    	       "sProfiles[y+1].LastName,sProfiles[y+1].FirstName") {
    	    tempID 			= sProfiles[y+1].ID
    	    tempLastName 		= sProfiles[y+1].LastName
    	    tempFirstName 		= sProfiles[y+1].FirstName
    	    sProfiles[y+1].ID		= sProfiles[y].ID
    	    sProfiles[y+1].LastName 	= sProfiles[y].LastName
    	    sProfiles[y+1].FirstName 	= sProfiles[y].FirstName
    	    sProfiles[y].ID		= tempID
    	    sProfiles[y].LastName	= tempLastName
    	    sProfiles[y].FirstName	= tempFirstName
    fnInitPofiles()
    BUTTON_EVENT[dvTP,1] {  //sort the profiles by last name
       PUSH: {
          fnSortByLastName()
    BUTTON_EVENT[dvTP,2] {  //reset profiles to original order
       PUSH: {
          fnInitPofiles()
  • looks good. thank you, joe!
    You're welcome, Micha. If you come across a faster sort algorithm please post it.
  • i just coded the shellsort algorithm, that maxifox suggested.
    -> http://www.iti.fh-flensburg.de/lang...ell/shellen.htm
    This is definitely a very fast algorithm, but i can't test it right now (no hardware). I will post it, when i'am sure that it works fine (next week?).
    In case i forget it, please send me a mail...
  • frthomasfrthomas Posts: 176
    Quicksort
    Here is an implementation of Quicksort (see http://linux.wku.edu/~lamonml/algor/sort/quick.html for info). It is recursive so don't use it on Netlinx to sort 10'000 items...
    The function DoSort sorts an array of integers (myArray). The function Sort is the one doing the work.
    Note that if you're sorting "large" data sets, swapping elements can be CPU intensive so you're better off sorting an index (and the reason why the sort routine below operates on an integer array). That is, the data is in an array of large structs Data with elements 1..N. You create an integer array DataSorted giving the position of the element in Data (initially, the indexes are the same so DataSorted = i), and you "sort this array" (and access the data in sorted fashion using Data[DataSorted]); that is, the sorted array gives you the sequences of indexes in Data to get Data in sorted fashion (another advantage is that you can maintain multiple sort orders in parallel).
    If you want to do that you need to change in Sort the two comparisons: aInt[iHi] > tempInt AND aInt[iLo] <= tempInt with equivalent comparisons on Data (f.e. Data[aInt[iHi]].last_name > Data[tempInt].last_name), or create functions to compare elements together if you want to sort by last, first name and then by area code and phone number.
    Very fast. On my old NE master I need 6 ticks (GET_TIMER units) to sort 200 elements.
    HTH
    Fred
    DEFINE_FUNCTION Sort(INTEGER aInt[], INTEGER myLow, INTEGER myHigh)
        STACK_VAR INTEGER iLo;
        STACK_VAR INTEGER iHi;
        STACK_VAR INTEGER Low;
        STACK_VAR INTEGER High;
        STACK_VAR INTEGER tempInt;
        Low  = myLow;
        High = myHigh;
        WHILE (Low < High)
    	iLo     = Low;
    	iHi     = High;
    	tempInt = aInt[Low];
    	WHILE (iLo < iHi)     // split list in two
    	{//GAs[GAsPos[j]].sGA > GAs[GAsPos[i]].sGA
    	FOR (; (aInt[iHi] > tempInt) && (iHi > 1); iHi--);
    	    FOR (aInt[iLo] = aInt[iHi]; (iLo < iHi) && (aInt[iLo] <= tempInt); iLo++);
    		aInt[iHi] = aInt[iLo];
    	} (* While *)
    	aInt[iLo] = tempInt;
    	// sort recursively, the smallest first
    	IF (iLo - Low < High - iLo)
    	    Sort(aInt, Low, iLo - 1);
    	    Low = iLo + 1;
    	ELSE
    	    Sort(aInt, iLo + 1, High);
    	    High = iLo - 1;
        } (* While *)
    DEFINE_FUNCTION DoSort()
        Sort(myArray, 1, LENGTH_ARRAY(myArray));
  • Here is the implementation of ShellSort:
    DEFINE_CONSTANT
    INTEGER hSequence[8] = {701,301,132,57,23,10,4,1} // best known h-sequence (average)
    DEFINE_TYPE
    STRUCTURE STRUCT_PHONEBOOK
      INTEGER phonebookID
      CHAR phonebookName[32]
    VOLATILE STRUCT_PHONEBOOK phonebook[1000] // for example
    DEFINE_CALL'ShellSort'
      LOCAL_VAR VOLATILE STRUCT_PHONEBOOK shellsortSaver
      LOCAL_VAR VOLATILE INTEGER structPhonebookLength,hSequenceLength
      LOCAL_VAR VOLATILE INTEGER i,j,k,h
      hSequenceLength=LENGTH_ARRAY(hSequence)
      structPhonebookLength=LENGTH_ARRAY(phonebook)
      SEND_STRING 0,"'Sorting phonebook...'"
      FOR(k=1;k<=hSequenceLength;k++)
        h=hSequence[k]
        FOR(i=h+1;i<=structPhonebookLength;i++)
          j=i
          shellsortSaver=phonebook[j]
          LONG_WHILE((j>h)AND("phonebook[j-h].phonebookName">"shellsortSaver.phonebookName"))
            phonebook[j]=phonebook[j-h]
            j=j-h
          phonebook[j]=shellsortSaver
      SEND_STRING 0,"'Sorting phonebook...OK'"
  • AMXJeffAMXJeff Posts: 450
    Joe,
    Looks good the only thing I would change, to speed it up, is to not check the sorted array elements again and again. See the "y=x + 1" in the second for loop.
          FOR (y=x + 1; y<nMaxProfiles; y++) {
    Joe Hebert wrote:
    Here is a Bubble Sort routine. I’m sure there are faster sorts but this is the only one I’ve ever learned to write and it’s been fast enough for my purposes. Perhaps it will be fast enough for you.
    dvTP	= 10001:1:0
    DEFINE_CONSTANT
    DEFINE_TYPE
       INTEGER 	ID
       CHAR		LastName[32]
       CHAR		FirstName[32]
    sProfiles[1].ID	= 1
    sProfiles[2].ID	= 2
    sProfiles[3].ID	= 3
    sProfiles[4].ID	= 4
    sProfiles[5].ID	= 5
       INTEGER 	x
       INTEGER 	y
       INTEGER 	tempID
       //bubble sort
    fnInitPofiles()
       PUSH: {
          fnSortByLastName()
       PUSH: {
          fnInitPofiles()
    AMXJeff wrote:
    Joe,
    Good catch Jeff but I think you inadvertently looked at it upside down and the sort will be incorrect. The first time through the array the smallest element will not be at the top. Instead the biggest element will be at the bottom. The smaller elements bubble to the top by pushing the bigger elements down. So?
    Instead of your proposed second loop of:
    I think it should be:
    FOR (y=1; y<=nMaxProfiles-x; y++) {
    And yes that will speed things up since it doesn?t need to check the sorted elements more than once. Thanks for pointing it out.
    I suppose I could have made it potentially event quicker if I added a flag to test if a swap was made in the second loop because if no swaps were made then we can break out since the sort must be complete.
    I haven't been following this thread too well, but would it make sense to create a temporary array that adds a pointer value and then do the sort routine by just moving the pointer. After the array is sorted, write the appropriate values into the original array. I am just thinking that with a larger array, it would be a lot faster to just shuffle a single integer pointer as needed as opposed to writing all of the strings back and forth. Actually, there isn't a need to create anything other than an array of pointers. Here is the modified code.
    dvTP	= 10001:1:0
    DEFINE_CONSTANT
    INTEGER nMaxProfiles	= 100
    LONG  lTL_ID = 1
    DEFINE_TYPE
       INTEGER 	ID
       CHAR		LastName[32]
       CHAR		FirstName[32]
    LONG 	lTL_Times[5] = {100,100,100,100,100}
    LONG	lINDEX_TIME
    LONG	lSTRING_TIME
    STACK_VAR INTEGER x;
    STACK_VAR INTEGER y;
    STACK_VAR INTEGER z;
    STACK_VAR CHAR RNDM_NAME[20];
    	FOR(x=1;x<=nMaxProfiles;x++)
    		z = RANDOM_NUMBER(15) + 5 //Determine Random length for Last Name 5 Char Minimum
    		SET_LENGTH_ARRAY(RNDM_NAME,z)
    		FOR(y=1;y<=z;y++)
    			RNDM_NAME[y] = (RANDOM_NUMBER(26) + 65)
    		sProfiles[x].LastName	= RNDM_NAME
    		z = RANDOM_NUMBER(10) + 3 //Determine Random length for First Name 3 Char Minimum
    		FOR(y=1;y<=z;y++)
    		sProfiles[x].FirstName= RNDM_NAME
    		sProfiles[x].ID	= x
    DEFINE_FUNCTION fnSortByLastName_Index() {
      INTEGER 	x
      INTEGER 	y
      INTEGER 	tempID
      INTEGER nPTR[nMaxProfiles]
    	TIMELINE_CREATE(lTL_ID,lTL_Times,5,TIMELINE_RELATIVE,TIMELINE_REPEAT)
    	FOR(x=1; x<=nMaxProfiles; x++)
    		nPTR[x] = x;
      //bubble sort
    			IF ("sProfiles[nPTR[y]].LastName,sProfiles[nPTR[y]].FirstName" >
    	       "sProfiles[nPTR[y+1]].LastName,sProfiles[nPTR[y+1]].FirstName") {
    				tempID 			= nPTR[y]
    				nPTR[y]			= nPTR[y+1]
    				nPTR[y+1] 	=	tempID
    	FOR(x=1;x<=nMaxProfiles;x++) {
    		tempID = sProfiles[x].ID
    		tempLastName = sProfiles[x].LastName
    		tempFirstName = sProfiles[x].FirstName
    		sProfiles[x].ID = sProfiles[nPTR[x]].ID
    		sProfiles[x].LastName = sProfiles[nPTR[x]].LastName
    		sProfiles[x].FirstName = sProfiles[nPTR[x]].FirstName
    		sProfiles[nPTR[x]].ID = tempID
    		sProfiles[nPTR[x]].LastName = tempLastName
    		sProfiles[nPTR[x]].FirstName = tempFirstName
    		y=x
    		while(y<=nMaxProfiles AND nPTR[y] <> x)
    			y++
    		IF(y<=nMaxProfiles)
    			nPTR[y] = nPTR[x]
    	TIMELINE_PAUSE(lTL_ID)
    	lINDEX_TIME = TIMELINE_GET(lTL_ID)
    	TIMELINE_KILL(lTL_ID)
    DEFINE_FUNCTION fnSortByLastName_String() {
      INTEGER 	x
      INTEGER 	y
      INTEGER 	tempID
       //bubble sort
    	lSTRING_TIME = TIMELINE_GET(lTL_ID)
    fnInitPofiles()
       PUSH: {
       PUSH: {
          fnInitPofiles()
    BUTTON_EVENT[dvTP,3] {  //sort the profiles by last name
       PUSH: {
    I also bumped up the number of records to 100 and randomized the population of the data.
    I then added a timeline to track execution time as closely as I could come up with in the last couple minutes. These are the results I got from an NI-3000 running nothing more than this code.
    Run Number\ Indexed | String
    1 | 1989ms | 4029ms
    2 | 1978ms | 4121ms
    3 | 1951ms | 3896ms
    4 | 1967ms | 4038ms
    I also checked a completely sorted list and got these numbers:
    Indexed : 1606ms
    String: 2670ms
    I would appreciate somebody checking my time measurements as well as the methods I'm using for timing. As I type this up, I could have probably set the timeline times to be very large to minimize timeline events from happening during the sort, but I'm lazy, so someone else can do that if they like :)
    Have fun,
    Ok, I was having a VERY Rough time with the shell sort algorithm. I worked through the implementation based on the website provided and the AMX code that mhermanns provided. It took me a few to get it parsing correctly, and once I did, I was VERY disappointed. I was expecting fairly quick sorting, but running the shell sort took so long I thought I was stuck in an infinite loop. A little debugging showed that everything was moving along as it should, it just took FOREVER. I upped the qty to 250 for this last round of testing, and the shell sort was taking soooooo long that the timeline milliseconds were wrapping around. I was getting reports of 20000, but it was taking MANY MINUTES for it too complete. I was just about to give up on the shell sort and be ok with the fact that either I coded it wrong or it wasn't that fast. In a last ditch effort, I changed the LONG_WHILE to a standard WHILE....OMG! HUGE Difference!
    DO NOT USE LONG_WHILE in Netlinx code. I think they talk about it in the help file stating that it should not be used in an event. Based on this experience...DO NOT EVER USE IT :)
    Anyway, here are the new times:
    250 data elements
    String Sort: 28369ms
    Indexed Sort: 12275ms
    Shell (Pratt): 3577ms
    Shell (mhermanns): 2370ms
    There wasn't a big difference between running the Papernov-Stasevic, Sedgewick, and the mhermanns column number break down. The Pratt column numbers did take a little longer.
    Here are the time on a presorted list:
    250 data elements
    String Sort: 17322ms
    Indexed Sort: 10036ms
    Shell (Pratt): 1733ms
    Shell (mhermanns): 591ms
    I think it's clear which algorithm is the fastest :)
    Here is the newest version of code I was using that has all three functions. They are not what I would call polished and complete, but they should give a fairly good jump to anyone that needs to use them.
    dvTP	= 10001:1:0
    DEFINE_CONSTANT
    INTEGER nMaxProfiles	= 250
    LONG  lTL_ID = 1
    INTEGER NumColumns1[] = {108,96,81,72,64,54,48,36,32,27,24,18,16,12,9,8,6,4,3,2,1} //Portion of Pratt
    INTEGER NumColumns2[] = {701,301,132,57,23,10,4,1} // best known h-sequence (average)
    INTEGER NumColumns3[] = {4592,1968,861,336,112,48,21,7,3,1} //Sedgewick
    INTEGER NumColumns4[] = {8191,4095,2047,1023,511,255,127,63,31,15,7,3,1} //Papernov-Stasevic
    DEFINE_TYPE
       INTEGER 	ID
       CHAR		LastName[32]
       CHAR		FirstName[32]
    LONG 	lTL_Times[5] = {10000,10000,10000,10000,10000}
    LONG	lINDEX_TIME[6] //1-5 = last values, 6 = running avg of all
    LONG	lSTRING_TIME[6]
    LONG	lSHELL_TIME[6]
    LONG  lINDEX_AVG_CNTR = 0
    LONG  lSTRING_AVG_CNTR = 0
    LONG  lSHELL_AVG_CNTR = 0
    INTEGER nSHELL_SELECT = 1
    INTEGER nCNTR_STRING = 1
    INTEGER nCNTR_INDEX = 1
    INTEGER nCNTR_SHELL = 1
    INTEGER nWORK_IN_PROGRESS = 0
    nWORK_IN_PROGRESS = 1
    		FOR(y=1;y<=z;y++)
    		FOR(y=1;y<=z;y++)
    		sProfiles[x].ID	= x
      INTEGER 	x
      INTEGER 	y
      INTEGER 	tempID
    		nPTR[x] = x;
      //bubble sort
    				tempID 			= nPTR[y]
    				nPTR[y]			= nPTR[y+1]
    				nPTR[y+1] 	=	tempID
    		y=x
    			y++
    		IF(y<=nMaxProfiles)
    			nPTR[y] = nPTR[x]
    	lINDEX_TIME[nCNTR_INDEX] = TIMELINE_GET(lTL_ID)
    	lINDEX_TIME[6] = ((lINDEX_TIME[6]*lINDEX_AVG_CNTR) + lINDEX_TIME[nCNTR_INDEX])/(lINDEX_AVG_CNTR + 1)
    	lINDEX_AVG_CNTR++
    	IF(nCNTR_INDEX == 5)
    		nCNTR_INDEX = 1
    	ELSE
    		nCNTR_INDEX++
      INTEGER 	x
      INTEGER 	y
      INTEGER 	tempID
       //bubble sort
    	lSTRING_TIME[nCNTR_STRING] = TIMELINE_GET(lTL_ID)
    	lSTRING_TIME[6] = ((lSTRING_TIME[6]*lSTRING_AVG_CNTR) + lSTRING_TIME[nCNTR_STRING])/(lSTRING_AVG_CNTR + 1)
    	lSTRING_AVG_CNTR++
    	IF(nCNTR_STRING == 5)
    		nCNTR_STRING = 1
    	ELSE
    		nCNTR_STRING++
    DEFINE_CALL'ShellSort' {
    STACK_VAR INTEGER nLength;
    STACK_VAR	INTEGER hSequenceLength;
    STACK_VAR INTEGER i;
    STACK_VAR INTEGER j;
    STACK_VAR INTEGER k;
    STACK_VAR INTEGER h;
    STACK_VAR INTEGER 	tempID;
    STACK_VAR CHAR		tempLastName[32];
    STACK_VAR CHAR		tempFirstName[32];
    STACK_VAR INTEGER nPTR[nMaxProfiles];
    STACK_VAR INTEGER hSequence[40];
    	SWITCH(nSHELL_SELECT)
    		CASE 1:
    			hSequence = NumColumns1
    			hSequenceLength=LENGTH_ARRAY(NumColumns1);
    		CASE 2:
    			hSequence = NumColumns2
    			hSequenceLength=LENGTH_ARRAY(NumColumns2);
    		CASE 3:
    			hSequence = NumColumns3
    			hSequenceLength=LENGTH_ARRAY(NumColumns3);
    		CASE 4:
    			hSequence = NumColumns4
    			hSequenceLength=LENGTH_ARRAY(NumColumns4);
    		nPTR[x] = x;
    	FOR(k=1;k<=hSequenceLength;k++) {
    		h=hSequence[k]
    		IF(h< (nMaxProfiles/2)) {
    			FOR(i=h+1;i<nMaxProfiles;i++) {
    				j=i
    				WHILE((j>=h)AND("sProfiles[nPTR[j-h]].LastName,sProfiles[nPTR[j-h]].FirstName" >
    						 "sProfiles[nPTR[j]].LastName,sProfiles[nPTR[j]].FirstName")) {
    					tempID = nPTR[j]
    					nPTR[j]=nPTR[j-h]
    					nPTR[j-h] = tempID
    					j=j-h
    		y=x
    			y++
    		IF(y<=nMaxProfiles)
    			nPTR[y] = nPTR[x]
    	lSHELL_TIME[nCNTR_SHELL] = TIMELINE_GET(lTL_ID)
    	lSHELL_TIME[6] = ((lSHELL_TIME[6]*lSHELL_AVG_CNTR) + lSHELL_TIME[nCNTR_SHELL])/(lSHELL_AVG_CNTR + 1)
    	lSHELL_AVG_CNTR++
    	IF(nCNTR_SHELL == 5)
    		nCNTR_SHELL = 1
    	ELSE
    		nCNTR_SHELL++
    fnInitPofiles()
       PUSH: {
       PUSH: {
          fnInitPofiles()
       PUSH: {
    BUTTON_EVENT[dvTP,4] {  //sort the profiles by last name
       PUSH: {
          CALL 'ShellSort'
    You can use the debug window to change between the 4 different column number sets I have in the code if you want to play around with 4 different sets of numbers for testing purposes.
    Have fun,
    The more advanced we are getting with our programming, the more then not-quite-really-multi-threaded nature of NetLinx is rearing it's head. A LONG_WHILE should, by all rights, just lock the thread running it until it times out, not the entire controller. Similarly, Recently had needed something to calculate a fractional exponent, and of course, there is no such function in NetLinx (nor Java ME, for that matter). I found an algorithm on java.net to approximate it, but it seriously impacted my NetLinx master ... one line of code freezing the entire master for a good 5-10 seconds. I optimized it a bit so it now only takes about a second ... but really, we need a good idle() function to give up processor ticks to other threads. We aren't just turning TV's on and off anymore, we are acquiring and handling data, and the language needs to expand accordingly ... and it does not seem Duet is fitting the bill as it ought to have
    Preach it brother! I'm running into these kind of issues as well. I also find myself avoiding the whole 'Java-think' in my programming as well because I just don't feel the NetLinx hardware/software model fits into strict object-oriented programming. Not that I think that's necessarily a bad thing. Object oreinted programming has a LOT of mental overhead and for a good chunk of what we do with Netlinx boxes I just don't think it's needed. However, for a lot of things that we are supposed to be 'in theory' able to do, the hardware/software tools just aren't there yet.
    I'd still like to be able to make a decent simple web browser for the touch panels. But I can't.
    Just some follow up. I was curious to see how much faster the 3100 is than the 3000, so I ran the benchmarks on a 3100 we have here. I ran each test 10 times to give me a fair average and here are the results:
    |Test Type                |     NI3000      |    NI3100     |
    |************************ Random Data **********************|
    |Bubble Sort              |     23364ms     |     9226ms    |
    |Bubble Sort Indexed      |     11976ms     |     4560ms    |
    |Shell Sort (Pratt)       |      3380ms     |     1321ms    |
    |Shell Sort(mhermanns)    |      2194ms     |      878ms    |
    |********************** Presorted Data *********************|
    |Bubble Sort              |     16880ms     |     6442ms    |
    |Bubble Sort Indexed      |      9713ms     |     3753ms    |
    |Shell Sort (Pratt)       |      1704ms     |      639ms    |
    |Shell Sort(mhermanns)    |       536ms     |      207ms    |
    Anyone know if any of the other processors are supposed to be faster or slower?
    Not undertanding this. Everyday I curse Netlinx for not being object oriented. Trying to create complex systems without being able to say, pass structures to modules, or use polymorphism or abstraction is just a huge drag, and would be hugely beneficial in this kind of work where there are many devices that do basically the same thing (power on , power off, play, stop, pause etc). I would like to be able to do this:
    dvCD.play()
    dvDVD.play()
    dvIpod.play()
    and have the right thing happen regardless of what the device is.
    I also miss not being able to have functions that take variable arguments like Java or C++ like this:
    define_function switch(integer input, integer output) {}
    define_function switch(integer input[], integer output) {}
    so that I don't have to rename the functions if the argument is slightly different.
    If they had at least given us pointers then we would have a fighting chance, but no ponters either, sheesh.
    Oh how I pine for OO.
    Duet
    You can write in Java if you want. That's what DUET is all about. No?
    I don't know, I typed System.out.println("Hello World") into my program and it wouldn't compile :)
    Seriously, I started down the Duet route but realized that it would require AMX training to really understand how they set things up. Plus the Java IDE they make you use I don't like (Eclipsed). I have paid for my own Java IDE (Jetbrains) and can't use it for Duet which really burns me. I wish that they had set it up so that you could add Java code into a netlinx program by calling a lib function similar to calling native functions from Java.
  • AuserAuser Posts: 506
    Spire_Jeff wrote:
    ... Anyone know if any of the other processors are supposed to be faster or slower?
    From memory, AMX suggest that the NIx100 series run code about three times faster than the NIx000's. From your figures it seems like the reality is closer to 2.5 times.
    So of the currently available controllers, the 2100, 3100 and 4100's will run code about 2.5x faster than the 700's and 900's.
    Merry Christmas peoples *<:-)
