DEFINE_MUTUALLY_EXCLUSIVE Section
Anyone know if there is anyway to use FOR() Loops in the DEFINE_MUTUALLY_EXCLUSIVE section of a module? I am passing an array of touch panels to the module, but I never know how many touch panels are in the array. I need to make some of the buttons mutually exclusive and it would be nice if I could do something like:
FOR(x=1;x<=LENGTH_ARRAY(dvTPS);x++)
([dvTPs[x],nUSER_SELECT_BTNS[1]],
[dvTPs[x],nUSER_SELECT_BTNS[2]],
[dvTPs[x],nUSER_SELECT_BTNS[3]],
[dvTPs[x],nUSER_SELECT_BTNS[4]],
[dvTPs[x],nUSER_SELECT_BTNS[5]])
I have a feeling that I will just have to turn OFF/ON all buttons accordingly to handle this properly, but it the season of hope, so if anyone has any thoughts or ideas on the situation, I'd appreciate them. I am going to try the FOR loop and see if it will even compile.
Ok, here it is. This will only work when the mutually exclusive set is contained in an array, but I think this should work. I will edit it if needed after I finish the module that uses this.
DEFINE_CALL 'EXCLUSIVE ON' (DEV dvTP,INTEGER nBTNS[],INTEGER nON_INDEX) { STACK_VAR INTEGER x; STACK_VAR INTEGER y; y = LENGTH_ARRAY(nBTNS); FOR(x=1;x<=y;x++) { IF(x == nON_INDEX) ON[dvTP,nBTNS[x]] ELSE OFF[dvTP,nBTNS[x]] }; }Oh, I also did a quick test between using the y variable and just putting LENGTH_ARRAY in the FOR statement. Using an array of 10 buttons, it took an average of 1ms for the call to execute using the y variable and an average of 2ms for it to execute with the LENGTH_ARRAY. Obviously this isn't a big difference, but eventually it could add up to a bigger fraction of a second :P
I'm not even opening up my NetLinx, but what if you kept it in mutually exculsive, use the length array outside of the for loop...say in the constants? so # of touch panels = length array then just in your mutually exclusive reference that variable?
DEFINE_CALL 'EXCLUSIVE ON' (DEV dvTP,INTEGER nBTNS[],INTEGER nON_INDEX) { OFF[dvTP,nBTNS] ON[dvTP,nBTNS[nON_INDEX]] }Also as small aside, I believe a true mutually exclusive set is a break before make and your original code doesn?t do that (it?s possible for two buttons to be on for a split second). I?m sure it doesn?t matter for your case since it?s TP buttons, however, it were relays it could make a difference.
Good call Joe. I will try to switch it to that. I do tend to hesitate when manipulating arrays that deal with touch panels, because early on I recall having some problems with it functioning properly, but I wouldn't be surprised if it was just my coding that caused the problems
Thanks for the ideas.
OFF[dvTP,nBTNS]
Works like a champ.
I still use it. Seems to work fine. There are other ways to get it done. I suppose if it ever fails me, I'll make the switch.
