Radia Feedback strings
I have 3 Radia Control cards, and they are working fine, except they are not sending any feedback strings.
These cards are connected to AxLink bus of NI-3100 processor
Any Ideas?
  • SensivaSensiva Posts: 211
    Althoug...
    As mentioned here
    Known Issues: This firmware disables most of the return responses from ProLink programming strings. AxLink responses and feedback will work as normal.
    Note that it says disables ProLink port not AxLink
    And after hitting few stuff against the wall :confused: , I contacted Support ...
    The strings back from the Radia cards have been disabled in newer firmware. This is because of issues with the strings causing netlinx masters problems. There is no way to turn this back on with the new firmware. You can still watch channels and levels on the Radia.
    Please people... Kindly.. give us a break!! :mad:
