Panasonic Plasmas ChUP/ChDN
I have noticed one various Panasonic plasmas RS232 command list, that it hasn't a channel up/down command.
Am I right??
Does this mean that I should control the plasma using both IR and RS232??
Am I right??
Of course, it's possible the function is just hidden behind some other. For example, the arrow up on the menu control might also be the channel up ... that's not uncommon with set top boxes.
the comercial ones dont have an in-built tuner and the plug in card is only IR control (bad panasonic, bad boy)
The residential plasmas have in-built everything except rs232.
But with new models released almost every year I could be wrong. Hard to keep up with it all. Leave that up to the sales team.
I meant that the RS232 protocol doesn't have any channels handling commands, either up/down or digits. so I had to use IR control , to handle channels changing.
and I am still wondering , how could it be? a protocol without this essential function?
LOL! Isn't that the question of the century???
that's how we do it. WantedState.TVChannel is an integer so it's 1 digit
Thank You!
Unfortunately , Not working... giving invalid command
