This is your system on juice....
This is what happens when a house is not properly grounded. This is the 2nd time this has happened over there. I should have saved the other pieces & card frames, to show you more - but this is just an NI-4000. Check out the relay housing and some of the chips on there.
First time - smoke was coming out of the walls from a lightning hit. Twice in one year. I think I'd be after the electrician or whoever wired the high voltage stuff. The house's circuit breaker has never tripped after a lightning hit, and all surge protects say they were fine. Talk about insane.
We haven't had to connect to anything relay driven recently, but the incident has caused us to do some research. We found a part that attaches inline to protect against power surges. It's like a standard fuse, but they were better. I, for the life of me, can't find the information at the moment, but as I recall, they were better than just putting fuses inline. Regardless, on the rare occasions where we have to use the relays on a processor, that is included.
Regardless of what kind of system / precautions you take, I think very little is going to protect you with a near direct hit (12 ft. from house.)
The relays were probably not in use - they only controlled shades. Anyone ever taken an NI-4000 apart - big case for little circuit boards!
