Minor bug in Find
I just ran across a very minor bug in the find dialog within NetLinx Studio. If you perform a search in the up direction, then close the find window, then perform another search (using CTRL-F both times), the second search shows that the direction is down, but it searches up.
Nothing big, but it could cause a problem if you are searching from the top of file and don't have loop around set.
  • yuriyuri Posts: 861
    you are right... that's some crazy bug checking you did :p
    i never search up, always use loop around :)
    Do you have the "Start at top on First Find" checked?
