Command for Showing a Button State
Greetings,
I have a 6-state button on G4 panels. Is there a send_command to tell the button which state to show from code?
Thanks!
Thanks!
"'^ANI-<variable text address range>,<start state>,<end state>,<time>'"
send_command ui,"'^ANI-500,5,5,1'"
"'^ANI-<variable text address range>,<start state>,<end state>,<time>'" Run a button animation. Time is in 1/10 seconds and is optional. 0 for state means current state. Syntax: SEND_COMMAND <DEV>,"'^ANI-<vt addr range>,<start state>,<end state>,<time>'" Variables: variable text address range = 1 - 4000. start state = Beginning of button state (0= current state). end state = End of button state. time = In 1/10 second intervals. Example: SEND_COMMAND Panel,"'^ANI-500,1,25,100'" Runs a button animation at text range 500 from state 1 to state 25 for 10 second.Jeff
That won't work with a multi-state general button will it?
Thaks for all of your suggestions.
