Newbie question about arrays
I haven't really used arrays that much for tracking information but here is what I would like to do. Any ideas would be great:
I am writing code to do the Party Mode on an ADA Suite 16 digital ( not using amx module too bloated ) any way I want to create an array for the 4 different party modes and based on which mode is selected it will tell you which rooms are currently in that preset via feedback on the touch panel. There are 23 rooms that might be apart of that array.
Chris
  • AMXJeffAMXJeff Posts: 450
    Here is one way to do it, I am sure there is a thousand ways to do it...
    dvTP = 10001:1:0
    (*               CONSTANT DEFINITIONS GO BELOW             *)
    DEFINE_CONSTANT
    // MAX STUFF
    MAX_ROOMS = 12;
    // PARTY_MODES - WHATEVER THEY ARE
    PM_ROCK_MODE = 1;
    PM_JAZZ_MODE = 2;
    PM_RB_MODE   = 3;
    PM_RAP_MODE  = 4;
    (*              DATA TYPE DEFINITIONS GO BELOW             *)
    DEFINE_TYPE
    VOLATILE INTEGER nRoomMode[MAX_ROOMS];
    VOLATILE INTEGER nRoomSelect;
    VOLATILE INTEGER btnRoomSelect[] =
    	1,  // Room 1
    	2,  // Room 2
    	3,  // Room 3
    	4,  // Room 4
    	5,  // Room 5
    	6,  // Room 6
    	7,  // Room 7
    	8,  // Room 8
    	9,  // Room 9
    	10, // Room 10
    	11, // Room 11
    	12  // Room 12
    VOLATILE INTEGER btnRoomModeSelect[] =
    	20, // PM_ROCK_MODE
    	21, // PM_JAZZ_MODE
    	22, // PM_RB_MODE
    	23  // RM_RAP_MODE
    (*               LATCHING DEFINITIONS GO BELOW             *)
    DEFINE_LATCHING
    (*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
    DEFINE_MUTUALLY_EXCLUSIVE
    (*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
    (*                STARTUP CODE GOES BELOW                  *)
    (*                THE EVENTS GO BELOW                      *)
    BUTTON_EVENT[dvTP,btnRoomSelect]
    		nRoomSelect = GET_LAST(btnRoomSelect);
    BUTTON_EVENT[dvTP,btnRoomModeSelect]
    		IF (nRoomSelect > 0)
    			nRoomMode[nRoomSelect] = GET_LAST(btnRoomModeSelect);
    (*            THE ACTUAL PROGRAM GOES BELOW                *)
    DEFINE_PROGRAM
    	[dvTP,btnRoomModeSelect[PM_ROCK_MODE]] 	= (nRoomMode[nRoomSelect] == PM_ROCK_MODE);
    	[dvTP,btnRoomModeSelect[PM_JAZZ_MODE]] 	= (nRoomMode[nRoomSelect] == PM_JAZZ_MODE);
    	[dvTP,btnRoomModeSelect[PM_RB_MODE]] 	= (nRoomMode[nRoomSelect] == PM_RB_MODE);
    	[dvTP,btnRoomModeSelect[PM_RAP_MODE]] 	= (nRoomMode[nRoomSelect] == PM_RAP_MODE);
  • ondrovicondrovic Posts: 217
    Thanks Jeff
    Here is the code I am working with. I have setup the arrays but I can't seem to get the information I want populated into those arrays. Any ideas on what I am doing wrong?
    PROGRAM_NAME='Party Mode'
    (*  FILE_LAST_MODIFIED_ON: 04/05/2006  AT: 09:00:25        *)
    (* System Type : NetLinx                                   *)
    (* REV HISTORY:                                            *)
        $History: $
    dvADA_Port	=	5001:1:1		/// ADA Comm Port
    dvPanel_24a	=	10024:1:1		/// ADA Control over MVP8400
    dvPanel_25a	=	10025:1:1		/// ADA Control over MVP8400
    DEFINE_CONSTANT
    Volatile Integer Party_Room_Buttons[]=
        3001,	//Room 1-Salon
        3002,	//Room 2-Wine Room
        3003,	//Room 3-Kitchen
        3004,	//Room 4-Guest Living Room
        3005,	//Room 5-Guest Bed 1
        3006,	//Room 6-Guest Bed 2
        3007,	//Room 7-Her Study
        3008,	//Room 8-His Study
        3009,	//Room 9-Library
        3010,	//Room 10-Master Bedroom
        3011,	//Room 11-Her Master Bath
        3012,	//Room 12-His Master Bath
        3013,	//Room 13-Exercise Room
        3014,	//Room 14-Guest Bed 3
        3015,	//Room 15-Conservatory
        3016,	//Room 16-Screen Porch
        3017,	//Room 17-Breakfast Room
        3018,	//Room 18-Guest Screen Porch
        3019,	//Room 19-Enclosed Porch (Master Sitting)
        3020,	//Room 20-Roof Terrace
        3021,	//Room 21-Lawn/Pool
        3022,	//Room 22-His Master Closet
        3023	//Room 23-Her Master Closet
    Volatile Integer Party_Room_Inputs[]=
        3050,		//iPod			1
        3051,		//XM			2
        3052,		//AM/FM		3
        3053,		//CD			4
        3054,		//REQUEST		5
        3055		//MAX Audio		6
    Volatile Integer Party_Room_Take[]=
        3060		/// Take Button
    Volatile Integer Party_Room_Numbers[]=
        3065,		/// Party 1
        3066,		/// Party 2
        3067,		/// Party 3
        3068		/// Party 4
    Volatile Integer Party_Mode_Set[]=
        3075		/// Mode Set 0=Select Party; 1; Setup Party
    DEFINE_TYPE
    Volatile Panel_Total = 26
    Volatile Integer nRoom_Index[Panel_Total]	/// Store the room index for each panel: [] = the total number of panels on the systemVolatile Integer nRoom_Index[Panel_Total]	/// Store the room index for each panel: [] = the total number of panels on the system
    Volatile Integer nMode
    Volatile Integer nInput
    Volatile Integer nParty
    /// [Party Mode][Room]
    Volatile Char strParty_Status[4][23]		/// Stores the current party mode preset; 4 total prests available
    Dev dvADA_Array[]=	{dvPanel_24a,dvPanel_25a}
    DEFINE_LATCHING
    ([dvPanel_24a,Party_Room_Inputs[1]] .. [dvPanel_24a,Party_Room_Inputs[6]])
    ([dvPanel_25a,Party_Room_Inputs[1]] .. [dvPanel_25a,Party_Room_Inputs[6]])
    ([dvPanel_24a,Party_Room_Numbers[1]] .. [dvPanel_24a,Party_Room_Numbers[4]])
    ([dvPanel_25a,Party_Room_Numbers[1]] .. [dvPanel_25a,Party_Room_Numbers[4]])
    Define_Function ADA_Debug(Char strMsg[])
        Send_String 0,"'ADA Party Debug: ',strMsg"
    Define_Function ADA_Party_IptOffset(Integer nSource_Input, Char Input[2])
        IF(nSource_Input < 10)
    	Input = "'0',ITOA(nSource_Input)"
        Else
    	Input = ITOA(nSource_Input)
    Define_Function ADA_Party_RoomOffset(Integer nRoom, Char Room[2])
        If(nRoom < 10)
    	Room = "'0',ITOA(nRoom)"
        Else
    	Room = ITOA(nRoom)
    nMode = 0			/// Set nMode to 0 when system reboots or starts up
    Data_Event[dvADA_Array]
        Online:
    	Local_Var Volatile Integer nCount
    	For(nCount = 1; nCount<=23; nCount++ )
    	    [dvADA_Array,Party_Room_Buttons[nCount]] = (strParty_Status[nParty][nCount])
    Button_Event[dvADA_Array,Party_Mode_Set]
        Push:
    	Local_Var Volatile Integer nButton
    	nButton = Get_Last(Party_Mode_Set)
    	If(nMode >= 1)
    	    nMode = 0
    	   If(nParty > 0)
    		OFF[dvADA_Array,Party_Room_Numbers[nParty]]
    		nParty = 0
    	Else
    	    nMode = 1
    	    If(nInput > 0)
    		OFF[dvADA_Array,Party_Room_Inputs[nInput]]
    		nInput = 0
    	[dvADA_Array,Party_Mode_Set[nButton]] = (nMode = 1)
    Button_Event[dvADA_Array,Party_Room_Buttons]
        Push:
    	nButton = Get_Last(Party_Room_Buttons)
    	/// Set the room state of the button
    	If(strParty_Status[nParty][nButton] >= 1)
    	    strParty_Status[nParty][nButton] = 0
    	Else
    	    strParty_Status[nParty][nButton] = 1
    	/// Feedback
    	[dvADA_Array,Party_Room_Buttons[nButton]] = (strParty_Status[nParty][nButton])
    Button_Event[dvADA_Array,Party_Room_Numbers]
        Push:
    	nParty = Get_Last(Party_Room_Numbers)
    	/// Feedback
    	[dvADA_Array,Party_Room_Numbers[nParty]] = (Party_Room_Numbers[nParty])
    	For(nCount = 1; nCount <= 4; nCount++)
    Button_Event[dvADA_Array,Party_Room_Inputs]
        Push:
    	nInput = Get_Last(Party_Room_Inputs)
    	If(nMode = 0)
    	    /// Feedback
    	    [dvADA_Array,Party_Room_Inputs[nInput]] = (Party_Room_Inputs[nInput])
    Button_Event[dvADA_Array,Party_Room_Take]
        Push:
    	Stack_Var strRoom[2]
    	nButton = Get_Last(Party_Room_Take)
    	Switch(nMode)
    	    Case 0:	/// Use Preset
    		ADA_Debug("'Preset Use Mode'")
    		ADA_Debug("'Using Party : ',ITOA(nParty),' Input : ',ITOA(nInput)")
    		Send_String dvADA_Port,"'`SPTY',ITOA(nParty),'G0',ITOA(nInput)"
    		Break
    	    Case 1:	/// Setup Preset
    		ADA_Debug("'Preset Setup Mode'")
    		For(nCount = 1; nCount <=23; nCount ++)
    		    If(strParty_Status[nParty][nCount] = 1)
    			ADA_Party_RoomOffset(nCount,strRoom)
    			ADA_Debug("'Add to Party : ',ITOA(nParty),' Room : ',strRoom")
    			Send_String dvADA_Port,"'`SPTS',ITOA(nParty),'R',strRoom"
    		    Else
    			ADA_Debug("'Remove from Party : ',ITOA(nParty),' Room : ',strRoom")
    			Send_String dvADA_Port,"'`SPTC',ITOA(nParty),'R',strRoom"
    		For(nCount = 1; nCount<=23; nCount++)
    		    OFF[dvADA_Array,Party_Room_Buttons[nCount]]	/// Clears active rooms when switched to use mode
    		    strParty_Status[nParty][nCount] = 0			/// Resets the room state to 0 when switched to use mode
    		Break
    	Things to do for this program :
    	1.>-Need to have it turn off the room feedback once the party preset is set [X]
    	2.>-Issue: Forgot to set Room_State[nCount] = 0 [X]
    	3.>-Move to Take Button_Event so there isn't an additional set if all presets want to be setup at one time [X]
    	4.>-Need to setup 4 arrays 1 for each party preset [ ]
    	5.>-Need to track what rooms are in each array when specified party preset is selected [ ]
    	6.>-What input the current party mode is on [ ]
    	7.>-If nMode == 0 then only allow for the inputs to be selected, if nMode = 1 clear nInput and turn off feedback for input [X]
    	    Getting error :: Ref Error  ^PARTY_ROOM_BUTTONS  Index 0  Line=244 when nMode = 1 [X]
    	    nInput & Feedback for Inputs not resetting, will let you manually select the input that is already lit up and deselect then everything resets
    	8.>-Clear Party When Switch Modes
    DEFINE_PROGRAM
    (*                     END OF PROGRAM                      *)
    (*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
    I wouild say to start with you are using a two dimension array where one dimension array will work. Because you are using a two dimension array, you are not clearing the other values when you change what party mode you are in. Unless you can have more then party mode active at the same time for each room, which I doubt is true.
    // This shows how you can have four party modes in the same room.
    // In order to continue to use a two dimensional array, you must clear the other party modes when you change one.
    // Party 1, Room 1
    strParty_Status[1][1] = 1;
    // Party 2, Room 1
    strParty_Status[2][1] = 1;
    // Party 3, Room 1
    strParty_Status[3][1] = 1;
    // Party 4, Room 1
    strParty_Status[4][1] = 1;
    // All clear except for party mode 1
    // Party 1, Room 1
    // Party 2, Room 1
    strParty_Status[2][1] = 0;
    // Party 3, Room 1
    strParty_Status[3][1] = 0;
    // Party 4, Room 1
    strParty_Status[4][1] = 0;
    // Using a single dimensional array makes more sense. When you set the party mode, you can only have one active party mode per room.
    // Room 1, Party mode 1
    strParty_Status[1] = 1;
    // Room 1, Party mode 2
    strParty_Status[1] = 2;
    // Room 1, Party mode 3
    strParty_Status[1] = 3;
    // Room 1, Party mode 4
    strParty_Status[1] = 4;
    // Room 1, Party mode none
    strParty_Status[1] = 0;
    Thanks Jeff i have rewritten the code as follows I am having an issue with the status resetting to 0. I know it is something simple but I just cant seem to find it
    If(nParty_Status[nParty_Setup][nButton] >= 1)
    	    nParty_Status[nParty_Setup][nButton] = 0
    	Else
    	    nParty_Status[nParty_Setup][nButton] = 1
    	    /// Note : Flag always resets to 0; because its looking at nParty_Setup once selected is always >=1; need to add a different variable
    Here is the whole workspace
    PROGRAM_NAME='ADA Party Mode'
    (* REV HISTORY:                                            *)
        $History: $
        Notes :
        Note : Line 150 : ADA_Debug is sending 2x the debug information not sure why
        Note : Line 267 : Flag always resets to 0; because its looking at nParty_Setup once selected is always >=1; need to add a different variable
    dvADA_Port	=	5001:1:1		/// ADA Comm Port, ISO2CAT
    dvPanel_24a	=	10024:1:1		/// Port 1 Touch Panel
    dvPanel_25a	=	10024:1:1		/// Port 1 Touch Panel
    DEFINE_CONSTANT
    /// Outputs on the Switcher : Rooms
    Volatile Integer nParty_Room_Buttons[]=
        3001,	/// Room 1-Salon
        3002,	/// Room 2-Wine Room
        3003,	/// Room 3-Kitchen
        3004,	/// Room 4-Guest Living Room
        3005,	/// Room 5-Guest Bed 1
        3006,	/// Room 6-Guest Bed 2
        3007,	/// Room 7-Her Study
        3008,	/// Room 8-His Study
        3009,	/// Room 9-Library
        3010,	/// Room 10-Master Bedroom
        3011,	/// Room 11-Her Master Bath
        3012,	/// Room 12-His Master Bath
        3013,	/// Room 13-Exercise Room
        3014,	/// Room 14-Guest Bed 3
        3015,	/// Room 15-Conservatory
        3016,	/// Room 16-Screen Porch
        3017,	/// Room 17-Breakfast Room
        3018,	/// Room 18-Guest Screen Porch
        3019,	/// Room 19-Enclosed Porch (Master Sitting)
        3020,	/// Room 20-Roof Terrace
        3021,	/// Room 21-Lawn/Pool
        3022,	/// Room 22-His Master Closet
        3023	/// Room 23-Her Master Closet
    /// Inputs on the switcher : Sources
    Volatile Integer nParty_Inputs[]=
        3050,		/// iPod			1
        3051,		/// XM			2
        3052,		/// AM/FM		3
        3053,		/// CD			4
        3054,		/// REQUEST		5
        3055		/// MAX Audio	6
    /// Save rooms to party mode preset
    Volatile Integer nParty_Save[]=
        3060		/// Save
    /// Party buttons under setup mode
    Volatile Integer nParty_Setup_Buttons[]=
        3065,		/// Party 1
        3066,		/// Party 2
        3067,		/// Party 3
        3068		/// Party 4
    /// Buttons to set nFlag to 1 & 0
    Volatile Integer nParty_Flags[]=
        3075,		/// Setup Button - Sets nFlag to 1
        3076		/// Exit Button - Sets nFlag to 0
    /// Party buttons on main selection page
    Volatile Integer nParty_Buttons[]=
        3077,		/// Party 1
        3078,		/// Party 2
        3079,		/// Party 3
        3080		/// Party 4
    DEFINE_TYPE
    Volatile Integer nFlag	/// Stores current nFlag state; 0=Use mode,1=Setup mode
    Volatile Integer nInput	/// Stores current switcher input
    Volatile Integer nParty_Setup 	/// Store current party mode under setup menu
    Volatile Integer nParty	/// Store current party mode under main menu
    Persistent Integer nParty_Status[4][23]	/// Stores which rooms are in each party mode
    DEV dvADA_Array[]= {dvPanel_24a, dvPanel_25a}
    DEFINE_LATCHING
    /// Source on main page
    ([dvPanel_24a,nParty_Inputs[1]] .. [dvPanel_24a,nParty_Inputs[6]])
    ([dvPanel_25a,nParty_Inputs[1]] .. [dvPanel_25a,nParty_Inputs[6]])
    /// Party # on main page
    ([dvPanel_24a,nParty_Buttons[1]] .. [dvPanel_24a,nParty_Buttons[4]])
    ([dvPanel_25a,nParty_Buttons[1]] .. [dvPanel_25a,nParty_Buttons[4]])
    /// Party # on setup page
    ([dvPanel_24a,nParty_Setup_Buttons[1]] .. [dvPanel_24a,nParty_Setup_Buttons[4]])
    ([dvPanel_25a,nParty_Setup_Buttons[1]] .. [dvPanel_25a,nParty_Setup_Buttons[4]])
    /// ADA Debug sent to the master
    Define_Function ADA_Debug(Char  strMSG[])
        Send_String 0,"'ADA Debug : ',strMSG"
    /// ADA Party Input Offset
    Define_Function ADA_Party_Ipt_Offset(Integer nSource_Input, Char Input[2])
        Else
    /// ADA Party Room Offset
        If(nRoom < 10)
        Else
    	Room = ITOA(nRoom)
    /// Make sure that nFlag is set to 0 on system reboot
    nFlag = 0
    /// Set the length of the party status arrays
    Set_Length_String(nParty_Status[1], 23)
    Set_Length_String(nParty_Status[2], 23)
    Set_Length_String(nParty_Status[3], 23)
    Set_Length_String(nParty_Status[4], 23)
    /// Touch Panel Online event for feedback
    Data_Event[dvAda_Array]
        Online:
    	For(nCount = 1; nCount <= 23; nCount ++)
    	    [dvAda_Array,nParty_Room_Buttons[nCount]] = (nParty_Status[nParty][nCount])
    /// Tracks / Sets nFlag
    Button_Event[dvADA_Array,nParty_Flags]
        Push:
    	nButton = Get_Last(nParty_Flags)
    	Switch(nButton)
    	    /// Setup button - sets nFlag to 1
    	    Case 1:	{nFlag = 1	Break}
    	    /// Exit button - sets nFlag to 0; also sets nParty_Setup to 0
    	    Case 2:
    		nFlag = 0
    		nParty_Setup = 0
    		Break
    /// Tracks / Sets nParty for preset under setup menu
    Button_Event[dvADA_Array,nParty_Setup_Buttons]
        Push:
    	nParty_Setup = Get_Last(nParty_Setup_Buttons)
    	/// Turn on feedback for party #'s on setup menu
    	[dvADA_Array,nParty_Setup_Buttons[nParty_Setup]] = (nParty_Setup_Buttons[nParty_Setup])
    /// Tracks / Sets rooms under setup menu
    Button_Event[dvADA_Array,nParty_Room_Buttons]
        Push:
    	nButton = Get_Last(nParty_Room_Buttons)
    	Else
    	/// Tracks feedback for select rooms under each party
    	[dvADA_Array,nParty_Room_Buttons[nButton]] = (nParty_Status[nParty][nButton]) //- not working
    	nParty = 0
    /// Saves the Rooms to the Selected Party
    Button_Event[dvADA_Array,nParty_Save]
        Push:
    	nButton = Get_Last(nParty_Save)
    	/// If there isn't a party selected; popup reminder to select
    	If(nParty_Setup = 0)
    	    Send_Command dvADA_Array,"'@PPN-[Ada] - Party Setup Reminder;[Ada] - Party Setup'"
    	Else
    		If(nParty_Status[nParty_Setup][nCount] = 1)
    		    ADA_Debug("'Add Room to Party : ',ITOA(nParty_Setup),' Room : ',strRoom")
    		    Send_String dvADA_Port,"'`SPTS',ITOA(nParty_Setup),'R',strRoom"
    		Else
    		    ADA_Debug("'Not adding Room to Party : ',ITOA(nParty_Setup),' Room : ',strRoom")
    		    Send_String dvADA_Port,"'`SPTC',ITOA(nParty_Setup),'R',strRoom"
    /// Tracks / Sets the Party # on main page
    Button_Event[dvADA_Array,nParty_Buttons]
        Push:
    	nParty = Get_Last(nParty_Buttons)
    	/// Sets feedback for party # on main page
    	[dvADA_Array,nParty_Buttons[nParty]] = (nParty_Buttons[nParty])
    /// Tracks / Sets the input on the main page
    Button_Event[dvADA_Array,nParty_Inputs]
        Push:
    	nInput = Get_Last(nParty_Inputs)
    	/// If no party is selected; pop reminder to select party
    	If(nParty = 0)
    	    Send_Command dvADA_Array,"'@PPN-[Ada] - Party Reminder;[Ada] - Party Mode'"
    	Else
    	    /// Sets the feedback for the party inputs on the main page
    	    [dvADA_Array,nParty_Inputs[nInput]] = (nParty_Inputs[nInput])
    DEFINE_PROGRAM
    Because both dvPanel_24a and dvPanel_25a are the same address, the button event is actually tripping twice. Resetting your variable on the second trip... Still think your overcomplicating this with a two dimensional array.
    You should also be checking to make sure these variable that you are using to access index of these arrays are not zero or greater then max_length_array, especially if they are set in another button_event/
    IF (nParty_Setup >= 1 && nParty_Setup <= MAX_LENGTH_ARRAY(nParty_Status))
    Else
    // This line is giving you a runtime error, because you set nParty to Zero, next button_event causes the runtime error.
    nParty = 0
    Thanks Jeff that fixed it
    On my initial glance at your code, here are some thoughts:
        Push:
    I think you need to change the feedback to be:
    ON[dvADA_Array,nParty_Setup_Buttons[nParty_Setup]]
    If you don't, the mutually exclusive statement won't take effect. (see technote: http://amx.com/techsupport/techNote.asp?id=757 )
    I think there may also be some problems with referencing arrays.
        Push:
    	Else
    	nParty = 0
    Why are you setting nParty = 0 at the end? If this gets activated again, it will cause problems with the array reference being 0.
    You can check for these types of errors by enabling internal diagnostics and watch for errors while you push the buttons. Another tool to use is the debugger. Set some break points where you are having problems and then add the variables being used in that section to the watch list. This will let you see if the variables contain the values they should.
    Oh Yeah,
    You should not use Volatile in Local_Var and Stack_Vars
    // Wrong
    Local_Var Volatile Integer nTest;
    // Correct
    Local_Var Integer nTest;
    Thanks for the tip
