Switch/case compile error
Could somebody explain to me why this code compiles fine:
CASE 'NEWS/SPORTS=':
  SWITCH(DATA.TEXT)
    CASE'0':
      QUE_CMD("$FA,$A6,$00,$CA,$FF,$FF")     //CNN
     CASE'1':
      QUE_CMD("$FA,$A6,$01,$63,$FF,$FF")      //CNBC
     CASE'2':
      QUE_CMD("$FA,$A6,$01,$5E,$FF,$FF")       //CSPAN
     CASE'3':
     QUE_CMD("$FA,$A6,$01,$5F,$FF,$FF")      //CSPAN2
      CASE'4':
      QUE_CMD("$FA,$A6,$00,$F3,$FF,$FF")      //COURTV
      CASE'5':
      QUE_CMD("$FA,$A6,$01,$64,$FF,$FF")      //MSNBC
      CASE'6':
      QUE_CMD("$FA,$A6,$01,$68,$FF,$FF")       //FOXNEWS
      CASE'7':
      QUE_CMD("$FA,$A6,$01,$6A,$FF,$FF")       //TWC
      CASE'8':
      QUE_CMD("$FA,$A6,$00,$CE,$FF,$FF")       //ESPN
      CASE'9':
       QUE_CMD("$FA,$A6,$00,$D1,$FF,$FF")      //ESPN2
      CASE'10':
      QUE_CMD("$FA,$A6,$02,$78,$FF,$FF")      //SUN SPORTS
And this one doesn't:
  SWITCH(DATA.TEXT)
    CASE'0':
     CASE'1':
     CASE'2':
     CASE'3':
      CASE'4':
      CASE'5':
      CASE'6':
      CASE'7':
      CASE'8':
      CASE'9':
      CASE'10':
Here is the error at compile:
---------- Starting NetLinx Compile - Version[2.4.0.1] [02-20-2008 06:36:19] ----------
C:\Documents and Settings\Owner.Gateway\My Documents\AMX\Modules\DIRECTV\DIRECTV_Comm.axs
ERROR: (0): C10580: Internal Error: Major system error occurred during code generation
C:\Documents and Settings\Owner.Gateway\My Documents\AMX\Modules\DIRECTV\DIRECTV_Comm.axs - 1 error(s), 0 warning(s)
NetLinx Compile Complete [02-20-2008 06:36:19]
  • yuriyuri Posts: 861
    CASE '10' is indeed your problem...
    Strange thing is that when you change CASE '10' to CASE '1' (which already exists), your code compiles fine... instead, you should get a 'DUPLICATE CASE' error.
    fix it like this:
    LOCAL_VAR test
    test = ATOI(DATA.TEXT)
    SWITCH(test)
    CASE 1:
    //etc
    (but you probably worked that out yourself ;) )
  • flcusatflcusat Posts: 309
    Thanks Yuri. But it didn't work. Here is the code with the local variable you suggested.
      LOCAL_VAR FIX
      FIX=ATOI(DATA.TEXT)
      SWITCH(FIX)
        CASE'0':
         CASE'1':
         CASE'2':
         CASE'3':
          CASE'4':
          CASE'5':
          CASE'6':
          CASE'7':
          CASE'8':
          CASE'9':
          CASE'10':
    And here the compiled error :
    ---------- Starting NetLinx Compile - Version[2.4.0.1] [02-20-2008 07:39:52] ----------
    NetLinx Compile Complete [02-20-2008 07:39:52]
    You are switching off an integer now so you need to lose the quotes as yuri showed in his code example.
    You need:
    Case 1: thru Case 10:
    instead of
    Case '1': thru Case '10':
    Thanks Joe. My bad. I was in a hurry.
  • mpullinmpullin Posts: 949
    The problem with this is that when the compiler sees case '1' it thinks:
    Ok, these are all going to be single characters!
    But then when it sees '10' it thinks:
    That's not a value of the type I was expecting, so I'm going to take a nap. Helpful error message? Nah, too tired. Zzz.
    You can do all integer, all character, or all multi-character strings, but don't try to mix & match. One solution I have used in the past is to append a character to every item, e.g.:
    SWITCH("'>',DATA.TEXT"){
       CASE '>1': // stuff
       CASE '>2': // stuff
       CASE '>10': // stuff etc.
    Since they all happen to be numbers in your situation, Joe's solution with atoi is simpler.
       CASE '>1': // stuff
       CASE '>2': // stuff
    Good idea. I?ll have to remember that trick.
    Actually it was yuri?s solution, I just reiterated it. I think yuri?s Dutch accent threw Pedro off the first time. :D
    this is one of those cases when SELECT-ACTIVE might be a good alternative.
    Joe Hebert wrote:
    Good idea. I’ll have to remember that trick.
    Actually it was yuri’s solution, I just reiterated it. I think yuri’s Dutch accent threw Pedro off the first time. :D
    there IS no accent! :p
    btw. is it that bad?
    Yours is no worse than everyone else. The only people that don?t have an accent are those of us that are from Shi-KAH-go, home of Da Bears.
  • michux1michux1 Posts: 1
    I had the same problem today and, after reading your posts, decided to reorder my case statements from longest to shortest
    ie.
    CASE 'ERR':
    CASE 'OK':
    CASE '32':
    CASE '16':
    CASE '8':
    CASE '4':
    CASE '3':
    CASE '2':
    CASE '1':
    ...you get the picture. Worked like a charm and I didn't have to use ATOI (especially because 'OK' and 'ERR' kind of want to be ascii.
