Quick question:
Under Define Function fn ProjInput()
IF(nSource = 3 ) //PC
sProjTxBuf = "sProjTxbuf,sProj_cmds[3]" // RGB INPUT
Else
sProjTxBuf = "sProjTxbuf,sProj_cmds[5]" // Video Input
Basically can I amend the IF line to read= 3,4)
In other words can I have it go to sProj_cmds[3] with either input ??
Thanks for the input
    Define Function fnProjInput()
         if(nSource == 3 || nSource == 4) // = will work but == is a clearer meaning
    	  //do something ;
    or
         if(nSource > 2 && nSource < 5)
    	  //do something ;
    or
         SWITCH(nSource)
    	  CASE 1:
    	       //do something for source 1
    	  CASE 2:
    	       //do something for source 2
    	  CASE 3:
    	  CASE 4:
    	       //do something for source 3 or 4
    or
         SELECT
    	  ACTIVE(nSource == 1):
    	  ACTIVE(nSource == 2):
    	  ACTIVE(nSource == 3 || nSource == 3):
  • MWNE2MWNE2 Posts: 15
    Thanks, I was fairly sure I could , just wanted to throw it at the wall and see if it stuck.
  • Wow, that code looks familiar.
    Even when it is possible to make such a conditional work with an IF...ELSE, I will frequently put it in the form of a SWITCH...CASE or SELECT...ACTIVE (depending on the condition tested) just so it is easily expandable if the project changes in the future. Both branching statements support default condition (DEFAULT: for a SWITCH, and ACTIVE(TRUE) for a SELECT), and sometimes I'll even make one where that is the only choice. Nested IF's are a royal pain to keep track of and maintain, where you can cut and paste ACTIVE or CASE lines and add them in very easily. If there is ever more than one choice, or any possibility the conditional might need to be expanded, that is the way I go.
    Tony, it should you had a MAJOR part in it.
    thanks again.
    Mark
