Ugh! 2.83.9 Firmware
in AMX Hardware
Yet again, another issue.
If you've got 2.83.9 loaded in a panel that has the old 802.11b cards - beware that they can fall offline, and lose site of the access point. Just ran into the problem. It seems to be though that the muddier the wireless network is, obviously the worse it is. So if you've gone a clean Wi-fi network, you may not have to worry about this.
If anyone else has had this problem - let me know.
Do you have remote access to the system? I'll be interested to know which firmware you have.
nope, no remote access. You'll have to wait 'till monday
The initial flavor shows the data rate with, I think, 1 decimal place after the data rate whereas V2 cards show it with 4 decimal places.
btw. it's running firmware 2.81
From what I understand, is it happens more when there's a mess of interference on the WiFi channel.
I for one have a big problem with devices that get that hot....
....amplifiers and management meetings excluded.
true, we use linksys products, but sometimes an Experience kit gets sold, which contains a standard AMX WAP
