PC to NI RS Cable Pinout
Hi all,
I lost the cable I used for years between the PC and the new NI-XXXX before setting the IP parameters. I tried with a standard 2-3-5 on RX-TX-GND cable, but no communication. Tried then with RX-TX inverted on one side, still no communication.
Do I need more than 3 pins connected? Anyone knows the correct pinout on both sides?
I guess this info is so clearly written somewhere that I'm completely overseeing it, so sorry if the question is too stupid. Thanks a lot in advance!
    quasimodor wrote: »
    Hi all,
    I use a premade null modem (crossed) cable for the programming port. You may need to add pins 7 and 8 to your cable.
    PC ? AMX
    2 -- 3
    3 -- 2
    5 -- 5
    7 -- 8
    8 -- 7
    HTH
  • Only 3 conductors required
    DB9 Female to DB9 Female
    2 -- 3
    3 -- 2
    5 -- 5
