PC to NI RS Cable Pinout
                                  in AMX Hardware
                    Hi all,
I lost the cable I used for years between the PC and the new NI-XXXX before setting the IP parameters. I tried with a standard 2-3-5 on RX-TX-GND cable, but no communication. Tried then with RX-TX inverted on one side, still no communication.
Do I need more than 3 pins connected? Anyone knows the correct pinout on both sides?
I guess this info is so clearly written somewhere that I'm completely overseeing it, so sorry if the question is too stupid. Thanks a lot in advance!
PC ? AMX
2 -- 3
3 -- 2
5 -- 5
7 -- 8
8 -- 7
HTH
DB9 Female to DB9 Female
2 -- 3
3 -- 2
5 -- 5
