Master Freezing
Scottpulman
in AMX Hardware
I have a question for you guys out there.. has anyone seen anything like this??
We have a couple of NI-3100 installed in a location that suffers from common blackouts.
One of the Masters after a blackout does not reboot, it actually freezes prior to program load
One loads with no issues
The only way to restore the master is to pull the power ( i.e. give it another blackout ) and then restore the power and then it reboots fine..
We have not been able to "force" this to happen, it only happens when there is a system wide blackout.
Anyone seen anything similar?
Put the master on a UPS and all will go away!
Either way - UPS should be a standard consideration for all masters in my view.
Cheers
Jim
We put a UPS on every AMX system we do.
