Home AMX User Forum AMXForums Archive Threads AMX Hardware AutoPatch Forum
SONY 232
jackygrossjackygross Junior MemberPosts: 10
Anyone has a sample of how to use the 232 KDL protocol?
I'm not familiar with the checksum method
trying to control power on/off
input switching
Aspect modes
Help is greatly appreciate it
thanks
  • John GonzalesJohn Gonzales Junior Member Posts: 609
    I don't have anything written for the KDL series, but from the protocol documentation it seems that the checksum is just the sum of the values of the data being sent. If the total is greater than $ff, then only the last byte is used, e.g. if the data adds up to $01FF then the checksum would be $FF. You can try the following to control the device:
    dvTelevision  =   5001:1:0
    dvTP          =  10001:1:0
    DEFINE_CONSTANT
    INTEGER nTPButtons[] = { 81,  //Video 1
                             82,  //Video 2
                             83,  //Video 3
                             84,  //Component 1
                             85,  //Component 2
                             86,  //HDMI 1
                             87,  //HDMI 2
                             88,  //HDMI 3
                             89,  //HDMI 4
                             90  // PC
    DATA_EVENT[dvTelevision]
      ONLINE:
    	 SEND_COMMAND dvTelevision,'SET BAUD 9600,N,8,1'
    BUTTON_EVENT[dvTP,nTPButtons]
        STACK_VAR INTEGER nButtonPressed
        nButtonPressed=GET_LAST(nTPButtons)
        SWITCH (nButtonPressed)
          CASE 1:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$02,$01,$03" //(*$8C = STX, $00 = Category (always $00 for this device), $02 = command for "Input Select", $03 = Length of Data to follow including checksum (3 bytes in this case), $02 = "Video", $01 = "#1 input", $03 = $02+$01)
          CASE 2:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$02,$02,$04"
          CASE 3:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$02,$03,$05"
          CASE 4:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$03,$01,$04"
          CASE 5:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$03,$02,$05"
          CASE 6:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$04,$01,$05"
          CASE 7:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$04,$02,$06"
          CASE 8:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$04,$03,$07"
          CASE 9:   SEND_STRING dvTelevision, "$8c,$00,$02,$03,$04,$04,$08"
          CASE 10:  SEND_STRING dvTelevision, "$8c,$00,$02,$03,$05,$01,$06"
    I'm confident that this would work. If someone else has a functioning code block hopefully they'll post it for you but this should get you started in the meantime.
    --John
  • TonyAngeloTonyAngelo Code Monkey Posts: 315
    I just put an XBR5 in a system I'm working on the other day. I could not get it to work with "Control a Device." As soon as I dropped the codes into a program, everything worked. Not sure if this is your problem.
    Here's the code I'm using, you can just drop this in an include file (the Structure for the Sony vars is not defined here) and reference the channel event for on/off:
    CHAR sSonyXBR5_Header[] = {$8C,$00}
    CHAR sSonyXBR5_Function[] = {$00,$01,$02}
    CHAR sSonyXBR5_Length
    CHAR sSonyXBR5_Cmd[] = {$00,$01,$02,$03,$04,$05}
    CHAR sSonyXBR5_Checksum
    INTEGER nHeaderPos
    CHAR sSonyXBR5_NewCmd[20]
    PERSISTENT _Display stSonyXBR5
    DEFINE_FUNCTION fnSonyXBR5MsgBuild(INTEGER nArgFunc, INTEGER nArgState, INTEGER nArgSub)
    {// Funcs 1=power,2=enable,3=inputs,4=channel,5=volume,6=muting
        STACK_VAR CHAR sMyLength
        STACK_VAR CHAR sMyData1
        STACK_VAR CHAR sMyData2
        STACK_VAR CHAR sMyMsg[20]
        STACK_VAR CHAR sMyCheckSum
        SWITCH(nArgFunc)
    	CASE 1: // power
    	    sMyLength = $02
    	    sMyData1 = sSonyXBR5_Cmd[nArgState+1]
    	CASE 2: // enable
    	    sMyLength = $02
    	CASE 3: // input
    	    IF(nArgState<=2) // length is two
    		sMyLength = $02
    	    ELSE
    		sMyLength = $03
    		sMyData2 = sSonyXBR5_Cmd[nArgSub]
      // add rest of funcs!
    // Build string
        sMyMsg = "sSonyXBR5_Header,sSonyXBR5_Function[nArgFunc],sMyLength,sMyData1"
        sMyChecksum = fnSonyXBR5CheckSum(sMyMsg)
        stSonyXBR5.TxBuf = "stSonyXBR5.TxBuf,sMyMsg,sMyChecksum"
    DEFINE_FUNCTION CHAR fnSonyXBR5CheckSum(CHAR sArgCmd[])
        STACK_VAR CHAR sCheckSum
        STACK_VAR INTEGER nLength
        STACK_VAR INTEGER nCount
        nLength = LENGTH_STRING(sArgCmd)
        FOR(nCount=1;nCount<=nLength;nCount++)
    	sCheckSum = sCheckSum+sArgCmd[nCount]
        RETURN sCheckSum;
    DEFINE_FUNCTION INTEGER fnSonyXBR5AckParse(CHAR sArgAck)
        STACK_VAR INTEGER nMyReturn
        SWITCH(sArgAck)
    	CASE $00:
    	    nMyReturn=1
    	CASE $01: // data too high
    	    nMyReturn=0
    	CASE $02: // data too low
    	    nMyReturn=0
    	CASE $03: // command canceled
    	    nMyReturn=0
    	CASE $04: // error
    	    nMyReturn=0
        RETURN nMyReturn;
    DATA_EVENT[dvXBR5]
        ONLINE:
    	SEND_COMMAND DATA.DEVICE,'SET BAUD 9600, N, 8, 1, 485 DISABLE'
    	SEND_COMMAND DATA.DEVICE,'RXON'
    	SEND_COMMAND DATA.DEVICE,'HSOFF'
    	SEND_COMMAND DATA.DEVICE,'XOFF'
        STRING:
    	WHILE(LENGTH_STRING(stSonyXBR5.RxBuf))
    	    IF(GET_BUFFER_CHAR(stSonyXBR5.RxBuf)=$70)
    		IF(fnSonyXBR5AckParse(GET_BUFFER_CHAR(stSonyXBR5.RxBuf)))
    		    // command acknowledged
    		    ON[stSonyXBR5.CTS]
    		    GET_BUFFER_CHAR(stSonyXBR5.RxBuf) // remove the checksum
    		ELSE
    		    // something went wrong
    	    ELSE
    		// not the beginning of the response string
    CHANNEL_EVENT[dvXBR5,255] // power cmd and fb
        ON:{fnSonyXBR5MsgBuild(1,1,0)}
        OFF:{fnSonyXBR5MsgBuild(1,0,0)}
    DEFINE_PROGRAM
    IF(LENGTH_STRING(stSonyXBR5.TxBuf) && stSonyXBR5.CTS) // stuff in the buffer and clear to send
        OFF[stSonyXBR5.CTS]
        // cancel related waits
        CANCEL_WAIT 'Cancel SonyXBR5 CTS'
        nHeaderPos = FIND_STRING(stSonyXBR5.TxBuf,$8C,2)-1
        SEND_STRING dvXBR5,REMOVE_STRING(stSonyXBR5.TxBuf,LEFT_STRING(stSonyXBR5.TxBuf,nHeaderPos),1)
    ELSE IF(!LENGTH_STRING(stSonyXBR5.TxBuf) && stSonyXBR5.CTS) // nothing in buffer and clear to send
        // poll?
    ELSE IF(!stSonyXBR5.CTS) // not clear to send
        WAIT 25 'Cancel SonyXBR5 CTS'
    	ON[stSonyXBR5.CTS]
  • Chad ReynoldsonChad Reynoldson Junior Member Posts: 12
    What was the pin-out of the cable that you used to control the Sony KDL display?
  • kbeattyAMXkbeattyAMX Junior Member Posts: 358
    Sony_Command[1]= "$8C,$00,$00,$02,$01,$8F" //PON
    Sony_Command[2]= "$8C,$00,$00,$02,$00,$8E" //POF
    Sony_Command[3]= "$8C,$00,$01,$02,$01,$90" //Standby ON
    Sony_Command[4]= "$8C,$00,$01,$02,$00,$8F" //Standby OFF
    Sony_Command[5]= "$8C,$00,$02,$03,$05,$01,$97" //RB1
    Sony_Command[7]= "$8C,$00,$02,$03,$02,$01,$94" //VID1
    Sony_Command[8]= "$8C,$00,$02,$03,$02,$02,$95" //VID2
    Sony_Command[9]= "$8C,$00,$02,$03,$02,$03,$96" //VID3
    You need to send standby on before turning off the KDL or you will not be able to turn it back on.
    The check sum is just an addition of all the bytes and take the least significant byte.
    $FF + $FF = $01,$FE $FE is the least significant byte.
    What is the cable pin-out that you used?
    Nothing weird. I'm working remotely so I wasn't onsite. 2,3,5 The manual says 2 is RX 3 is TX and 5 is GND for the Sony. So swap 2 and 3.
    Of course the Display should be ON when you begin to test the code because the KDL will never be in a Standby ON state until the command is sent when the display is on.
  • JeffJeff Junior Member Posts: 374
    If you're using checksums and you don't want to have to do the math, here's a checksum calculating function I stole off this forum a while back. No idea who to credit it to, but its useful
    define_function integer calcchecksum(char cMsg[])
    	stack_var integer nLoop
    	stack_var integer nCheckSum
    	off[nCheckSum]
    	for (nLoop=1;nLoop<=length_string(cMsg);nLoop++)
    		nCheckSum=((nCheckSum+cMsg[nLoop])& $FF)
    	return nCheckSum
    J
    I'm convinced that 232 control of the Sony KDL units is problematic. The code and cable seem to be very straight-forward, but I've had no success and we've given up, moving to IR control with discrete ON/OFF/INPUT (http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=discrete&br=sony&dv=television).
    I post this reply so that others do not waste as much time on this as I have.
    Keep in mind that a large amount of KDL XBR5's were shipped with wrong firmware making the 232 port useless. I'm not too sure of the cut off date when Sony fixed the problem. Probably last November.
    That was the key piece of information that I wasn't aware of, and am not surprised to hear. Thanks for that. Any hints on acquiring the new firmware, so that others who may read this post can use?
    Feb 2008 is the cutoff date and the firmware is only available from Sony.
